Question about DeLonghi DR-18TG Oil Filled Radiator Heater
Delonghi DR18T Timer Replacement
My Delonghi heater will not turn off and on in relation to what time the timer is set for. Works fine manually and with the thermostat. Any advice on how to replace the timer? Where can I find a repair manual for the heater.
Thanks,
Mike
  • mikenirish Jan 27, 2008
    To be honest with you I can't figure out how to get the timer out. I see no way to access it. Any suggestions?
    Thanks,
    Mike
The timer on my delonghi conventor heater keeps knocking the heater off how do i turn the timer off permanently
Posted on Mar 25, 2014
Open up the front panel and get to the timer panel. if you can see a battery compartment, open it and replace the battery.
Posted on Jan 28, 2008
  • 45 Answers
Before you replace the timer, check and see if the timer has a battery in it. if it has, then change the battery. it will work fine.
Posted on Jan 27, 2008
Hi i have a new DeLonghi Dragon 3 heater. The timer seems to work opposite to your instructions - i.e. the instructions indicate that the notches must be pushed to the outer ring to indicate the operating...
This is from the instruction manual online:
To set the heating periods proceed in the following manner:
- Check the time by your watch. Supposing it is 10.00 a.m. turn the numbered dial of the
time-clock in a clockwise direction until the number 10 coincides with the reference mark s
on the time-clock. Set the time period during which you wish the appliance to work by
pushing the notches towards the centre. Each notch corresponds to a period of 15 minutes.
At this point sections will be visible corresponding to the working periods.
Set in this way the radiator will function automatically every day during the set period.
(Important: the plug must remain connected to power supply).
- To change the programmed time period, just bring back the black notches to their original
position and set the new working periods required.
- If you wish the appliance to function without programmed working periods push all the notches
towards the centre. In this case, to turn the appliance off totally the plug must be pulled
out apart from switching off, so as to avoid unnecessary working of the timer.
Jan 29, 2011 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Timer will not turn water heater ON at set time, has to be done manually. However, it will turn water heater OFF at set time.
If this is new installation, check wiring. Hot and Load wires might be reversed.
Check that ON OFF trippers are both attached to yellow dial.
http://waterheatertimer.org/How-to-wire-WH40.html
If timer worked fine before, and started missing recently, then tripper pins probably worn out.
Trippers contact mechanical lever, and push lever on-and-off.
Trippers are softer metal and designed to wear out before lever.
If lever is worn out, timer needs to be replaced, but try new trippers first.
Buy trippers at Grainger
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How WH40 timer works:
Clock motor rotates dial.
ON-OFF trippers on dial contact lever.
ON tripper pushes lever one direction.
OFF tripper pushes lever other direction.
Lever moves electrical contacts together, or pulls contacts apart.
When lever moves on-and-off, manual override lever also snaps back and forth with audible clicking sound.
Using q-tip, add touch of white grease to lever where trippers contact.
Nov 25, 2010 | Intermatic WH40 - Water Heater Time Switch...
Delonghi dragon oil filled heater with timer. How does the timer work, is there a way to set it so that it stays on all the time? Do not have the manual
Within the timer is a 3 point switch. Push the switch to the end closest to the arrow and away from the clock icon. It will stay on
Oct 04, 2010 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Clock Stopped Turning
Most likely, the timer motor has failed and needs to be replaced. As the timer motor is constantly running 24/7, getting 19 years of use is significant and is well beyond the typical life of a mechanical timer of this type. I know, I've got the same ones on my pool and usually have to replace them every 10-12 years.
As the timer IS 19+ years old, it would be best to replace the entire unit instead of looking to tyr to get just a replacement timer motor, since the cost for a new timer isn't all that much compared to the cost for just the motor.
Intermatic also makes a digital timer version of this type of timer, but for the relatively low price of a new, replacement mechanical timer, it might be a good idea to get another one like you have and expect another long working life.
Sorry that there really isn't much to repair in such an old timer, since the motor is the critical part.
The replacement should be easy to do yourself, just remember to turn off the power breaker and disconnect the power to the timer. All you need to do is exchange the wires into the new replacement timer I find that taking a picture of the timer as it is, will help you get the connections correct for the new timer.
Also, check the model number of your present timer and voltage, (some pool equipment is 100V-AC while others are 220V-AC) to get the correct replacment timer.
Hope you find this Very Helpful and best regards.
Sep 09, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
I need instructions for operating the MG15T heater
Basic ...set to desired heat setting...it will turn itself on and off to maintain that temp in room (This is made for small rooms)
Dec 12, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Manual lever setting for water heater timer
post a close up of the timer and i will tryto assist you.
normally it dosent matter where the lever is as it should reset itself after each comlete operation . ie if you turn it on it should turn off when it reaches a preset off cam pin. or position indicator lever.
Nov 25, 2008 | Intermatic WH40 - Water Heater Time Switch...
Set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
http://www.delonghiusa.com/search_results.cfm?sp_q=oil+filled+heater&sp_p=all&sp_f=ISO-8859-1&sp_w_control=1&sp_w=alike&sp_a=sp1003e79d&sp_c=5
Hope this was helpful.
have a great day!
Oct 29, 2008 | DeLonghi 6707E Oil Filled Radiator Heater
Delonghi TRD0715T heater
turn timer knob clockwise till arrow points to correct time (your time), there are plastic protrusions "ticks"around the knob, they move in and out, move them in for on, and out for off
select time sectors that you wish hearted to heat, each tick is 15 minutes, experiement and become profecient
Oct 27, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
I hope this helps.
Oct 13, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Delonghi Incredible heat machine can't turn off the timer.
Timer is set by moving the little black switches out over the orange ring. You may need to use a coin--but slide it so that if the orange ring is visible when looking at it dead-on (crouching down, obviously) then it's off at that time and vice-versa.
Jan 13, 2008 | Heating & Cooling
DeLonghi DR-18TG Oil Filled Radiator Heater Logo
465 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
