If you have downloaded the software for your Sharp AR-5316E printer, but encounter a paper problem message when trying to print from your desktop while photocopying from the same printer works fine, there could be a few potential issues to consider:
Paper settings: Make sure that the paper settings on your computer match the paper size and type configured on the printer. Check the printer properties or print settings on your computer and ensure they are correctly set to match the paper loaded in the printer tray.
Paper tray configuration: Verify that the paper tray is properly loaded with the correct paper size and type. Make sure the paper is aligned correctly and not jammed or skewed in the tray.
Printer driver: Ensure that you have installed the correct and up-to-date printer driver for your Sharp AR-5316E printer. If you downloaded the software from the manufacturer's website, it should include the appropriate driver. Consider reinstalling the driver or updating it to the latest version to ensure compatibility with your operating system.
Printer firmware: Check if there are any firmware updates available for your printer model. Firmware updates can address compatibility issues and improve overall performance. Refer to the manufacturer's website or user manual for instructions on how to update the printer's firmware.
Paper sensor or other hardware issues: If the problem persists after checking the above steps, it's possible that there may be a hardware issue with the paper sensor or other components in the printer. In such cases, it's recommended to contact Sharp customer support or a professional printer technician for further assistance. They can provide specific troubleshooting guidance and help diagnose and resolve any hardware-related problems.
It's important to ensure that all connections are secure and that the printer is in good working condition. If necessary, consult the printer's user manual or contact customer support for detailed instructions specific to your printer model.
You try to full reinstall and also u should select the windows 7 driver. And its 32 bit & 64 bit available.You check it your system aalso,its 32 bit you installed the same 32 bit.
Try to use another USB port or another USB cable otherwise there appears to be a virus in your computer system. Try to format the computer and install the software again.
you may gey the driver software for AR=5316 printer install sotware inthese websites http://nodevice.in/driver/AR-5316/get47086.html http://ptf.com/sharp/sharp+ar+5316+printer+drivers+to+support+windos+7/
You can install it from the cd that came with the copier and then share the printer on the network and assign it a name.It will appear on the list of available printers.
According to sharp information the 5316e is not supported by Vista, the 5316n version is ( N for networking). They would require different drivers because they are different in the way they print. However, here is a link for a vista driver for the "E" version. This is for 32bit vista and not 64bit. http://esupport.sharp.at/html/driver/DataOutputDetail.php?TemplateLang=en&ID=3758 You are more than likely going to be connecting to the copier with a USB cable. Install the software first and plug in the USB cable. Hope this helps.
