Question about Minolta DiALTA Di250 All-In-One Laser Printer
Hi eerror c0070
I have the error c0070 and i want to ask you how much it cost to solve the problem?
  • STBMJ Apr 23, 2008
    Getting error code C0070 (says to call technician)- Problem began occuring when toner cartridge was replaced. Replacement cartridge was installed (used correct one). Tried to remove cartridge and turn off and restart the machine and then put cartridge back in and no luck. Any other suggestions before calling service rep.?
Toner moter drive fault. Bottle been put in wrong position. now jammed up machine. remove and turn machine off/on may work. If not have to reset error code in trouble mode. not a problem but engineer needed to do it.
Posted on Feb 14, 2008
HELP! Minolta Dialta Di350 Showing Error Code C0F35
Well the C0F35 is because there is no toner in the image unit so replace the image unit. just buy a whole new unit. as for the c0070 try this
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 12, 2017 | Minolta Office Equipment & Supplies
What causes error code c0070 on konica 7118
Remove the toner bottle. power off the machine, leave the bottle out turn on the machine let it goes thru normal op, when asking for toner install properly
Jun 12, 2014 | Konica Minolta Copier Tnr,...
Minolta Di250 copier malfunction C0070; please help me my boss wont buy a new and i need it to make my application; please help me
Re: Error Code c0070
If the machine is throwing the C0070 code without the bottle being inserted than likely the worm gear of the little drive motor of the toner bottle holder is damaged.
If C0070 is only coming up with the bottle inserted, than the bottle may be wrong or damaged from previous attempts.
To reach the toner bottle holder ("hopper") mechanism you have to remove the rear cover.
Apr 02, 2014 | Minolta Office Equipment & Supplies
Error code c0070 konica minolta copier service code c0070
Sir/Mam
Feb 05, 2014 | Konica Minolta DiALTA Di200 Copier
Imagistics dl270 code c0070
A error code C0070 means that the toner bottle can not find home position. Did you just install a new toner bottle??? If so, carefully remove the toner bottle and close the front door and let the copier warm up... Once it is warmed up install the toner bottle again.... If it will not clear you have more of a problem with the toner hopper... Good Luck
Jun 08, 2012 | Pitney Bowes 460-4 Toner for Imagistics...
Error code c0070
Power off the machine and gentlly take out the toner bottle. Then with the bottle out turn on the machine let the machine go thur its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
Apr 17, 2010 | Konica Minolta DiALTA Di183F Copier
Panasonic fp7781 error code c0070
Re install toner after shaking it up and reset main power
Oct 13, 2009 | Panasonic Office Equipment & Supplies
Code C0070 durning the working time
Have you replaced the toner lately? I beleiv it is a toner motor fail to turn, check the toner bottle, remove it and reinstall the bottle.
Close up the machine and try it again.
Hope this works for you.
Ed
Apr 26, 2009 | Minolta EP1030/1030F CS/PRO Copier
Is there a reset button, asking for service
What is the error code? Is it a C0070 code? If so that means that the toner bottle can not find home potion. Take the toner bottle out and let the copier come to ready and reinstall the toner bottle.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Error
while power on display massage eerror c00e0402 . how to solve problem?
Oct 23, 2007 | HP PSC 750 All-In-One InkJet Printer
Minolta DiALTA Di250 All-In-One Laser Printer Logo
448 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
