Question about Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Arrow keys I have a sharp HD TV - i got a great deal on it at best buy as an open box item, only catch: no remote. The Comcast cable remote or any universal remote works ok with the exception of the arrow keys. I can't navigate any menus because each time i press down/up it activates the input selection and the left/right keys activate the volume control. any ideas how to get the directional keys on universal remotes to work with the Sharp TV? Thanks.
    Problem Solver:
  • 40 Answers
Buy a remote for your sharp....
Posted on Jan 25, 2008
Cannot turn CC ON/OFF via remotes
Try this combination.
1) Start with the cable box turned on and TV on tuned to the cable box.
2) Press the POWER button for the cable box and then quickly press the MENU button.
3) This should bring up the user setting menu. Use the arrow keys on remote to go to Closed Caption and press right arrow button this should bring up the closed caption menu.
4) Press the OK button and this should either turn CC on or off.
5) Once Closed Caption is turned off press LEFT ARROW button to return to User Settings Menu.
6) Press the POWER button to turn the Cable box back on and the Closed Caption should be gone....
Good Luck.....
Jan 17, 2010 | Vizio VW32L 32 in. LCD HDTV
Just want to know if i can get hd channels with a regular comcast motorola dct700 box, if so how? Also, what DVD player should I buy with this, as well as type of cables. TV just given to me, no remote,...
No HD channels on a DCT700, you have to have a HD capable box from comcast. Usually $8.95 a month for box rental. Don't know a lot about DVD players. If you get a comcast HD box, and have an HD TV, you should use an HDMI cable for best picture. Second choice is component cables. Those are the red, white and yellow or red, white yellow, blue and green cables.
Jan 03, 2010 | Haier HLH32ATBB 32 in. LCD HDTV
TV CODES FOR 32'' RCA HD TV
if you bought a new rca tv, the codes have changed. until the cable companies catch up, you will need to use the remote that came with our tv AND the remote that came with your comcast box. Or, you can buy a LEARNING UNIVERSAL remote. this is different than a regular universal remote.
Jul 29, 2009 | RCA L32HD41 LCD TV
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Figuring out the TV channels for Comcast using the Sharp remote
Unfortunately there is no listing. I suggest taking a little time to sit next to the television with an notepad to go through each channel one at a time to label what stations come in on what channel numbers. Sorry.
Jan 09, 2009 | Sharp LC46SB54U 46 in. LCD TV
Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
Dec 01, 2008 | Sharp Remote Control
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
No Non-Hd sound
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Jan 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-32GD4U 32 in. LCD HDTV Logo
161 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
