Question about T-Mobile Wing™ Smartphone
Ghost Moving Screen
My Wing has some type of ghost in it. The screen scrolls up and down or side to side by itself. I don't know how to fix this problem because I don't know what's causing it to scroll sporadically like this. It will do this and then stop and then start again maybe a day or so. How should I fix this problem?? Please help.
  • 113 Answers
I got a Replacement LCD for my WING for $55 at WWW.HTCLCD.COM
Posted on Apr 06, 2008
    Novelist:
    Scholar:
  • 111 Answers
Your LCD had defect or LCD Cable is bad need to be replaced
Posted on Feb 28, 2008
A Ghost is moving my Mighty Mouse (screen saver turns off)
Chances are that the mouse is just drifting a bit. like, it's sitting still on the desk and the pointer starts moving on it's own on the screen. It's caused by dust getting on the optical receiver and drifting around on it. By no means is it a ghost though.
Jul 06, 2009 | Apple Mighty MA086LL/A Mouse
Ghost and No Sound
On board sound card adapter (integrated) or separate sound card?
Which type? It is not being recognized because you failed to tell something or submit a required friver during installation and most probably it is no standard device
Mar 29, 2009 | Microsoft Windows XP Home Edition
I'm trying to instal Norton Ghost 14. Installation goes fine until reboot. I get error E1AD3212 oon Ghost startup ande can't start the Ghost service manually -- Is there a fix for this -- Windows XP SP3...
Which antivirus previously installed? If any antivirus present then remove it in safe mode.
And better to install Norton in Safe mode
Go to Safe Mode with Networking by Tapping F8 key during Bootup, a black screen with option, select the option and then login as Admin account..
If it fails, then try using the Security Configuration Tool to make sure you have privileges to Ghost. You'll find the Tool in your programs menu under Programs|Norton Ghost|Security Configuration Tool.
After then, install Norton.. Let me know the status for further assistance.
Best of Luck
Puneet Jain
Oct 31, 2008 | Computers & Internet
Ghost image
You will have to replace both the convergence IC's on your TV..
Oct 23, 2008 | Sanyo PLC-XR70N 70" LCD Monitor
Device goes into "self-generating loop"
Install the software again after formating the phone
Oct 14, 2008 | i-mate K-jam Smartphone
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Red shadows and mild distortion
Hi, relasmith did you ever fix your tv kp-57ws510
thank you
Apr 03, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Scrolling Ghost Lines
Maybe what you should do is try unplugging the wii, or you might have bad cords, my last piece of advice is maybe the audio cords are messed up?
Dec 26, 2007 | Nintendo Wii Console
Red-striped ghost images.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
Dec 24, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
T-Mobile Wing™ Smartphone Logo
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
Edward Talavera
Edward Talavera
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
