Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag Range MER5875QAS Problem Need Help
Bake element shorted out replaced with new one. The new element will not glow can touch with finger. Have been told it could be a few possible things oven sensor or electronic keypad. Any ideas.
Thanks Jon
  • 2 more comments
  • Jon71 Jan 25, 2008
    The broil works fine clock works fine. I have a meter dont use it that much what would i set it to and what would i touch with the prongs. Thanks
    Bake element shorted out replaced with new one. The new element will not glow can touch with finger. Have been told it could be a few possible things oven sensor or electronic keypad. The broil element works fine. Thanks Jon
    First time using web site sorry about that. No power to bake element, broil element is fine. The only thing I can trace it back to is the electrical board. I'm asuming that shorted out when the element went bad. Thats the only thing left and it cost $150.00 to replace. What do you think?
    Thanks for your time Jon
  • 48 Answers
It would be better to check your service manual if you want to do it yourself. Usually bake element is unseen for easy oven cleaning (newer ones specially) Getting to these hidden bake elements vary from manufacturer to manufacturer and could be as simple as going in from the rear, just lifting an oven bottom panel covering it or in some cases, as much as partially lifting the cooktop and removing the right or left hand side panel to gain access to it! It might be the wiring.
Posted on Jan 25, 2008
  • 770 Answers
Do you have the back off yo will need to turn it on and see if you are getting 220v to the element
  • 5 more comments
  • Gary Davd
    Gary Davd Jan 25, 2008
    If you are not getting power it can be several things from a burnt terminal to a bad relay in the ctrl board check the pwr first
  • Gary Davd
    ok the bake and the broil are controlled by the clock board You will need to have the back off and set it to bake then pwr up and set to bake where the element sticks thru the back test for voltage there
  • Gary Davd
    Sorry I could not be better help for you Good luck now
  • Gary Davd
    You have not decided to accept my solution?? we are not not done trouble shooting it yet Sorry you feel that way i really feel i could have helped yo fix it
  • Gary Davd
    on the board there is a set of relays (Black boxes) you can tap on them with the back of a screw driver and see if the y close to turn on the element?? either way the board will have to eventually be replaced as the relay will get stuck again down the road it may work for awhile try it and see
  • Gary Davd
    The Clock Part # 74008658 is what you will need to buy it runs around $190.00 If that is the problem
  • Gary Davd
    Gary Davd Jan 26, 2008
    Did thatt fix Ya ?? if so please rate the service you received
  • 94 Answers
It could be a fuse or some wireing it also could be the heat monitor in the back of the oven
You may have a serious electrical problem. Or you may need a new element.
Please provide more info as to the source/location of the smoke.
Brian
Jan 19, 2008 | Maytag MER6772 Gemini Electric Kitchen...
My Maytag range Model # MGR5720ADW does not want bake. When calling to bake, the igniter glows, the flame comes on, then shuts off. Then repeats itself. After a short while, I smell gas. The Boiler...
-Sounds like the oven safety valve is not working properly.
-Check it out and replace it.
You possibly can't bake turkey this thinks giving.
Good luck
Mai Lor
Nov 27, 2017 | Maytag Kitchen Ranges
Wife put the oven on clean cycle last night. This morning the heating element will not turn off, a one inch section glows orange. Turned oven off, put it back on clean, broil and off again, no change.
You probably just need a new bake element. Many ranges supply 120 volts to one side of the bake element at all times, switching the other side of the 240 voltage to it (and completing a circuit) when it needs to heat. If the element shorts to ground, the 120 volts can heat though a section of the element to the ground. OK, so much for the technical stuff. Turn power off to range. Replace bake element. Re-connect power. If it works, great. If it heat without turning oven "on" now, that would indicate that the electrical contacts in the bake relay on the control board have welded themselves together, necessitating replacing the control board. Let's hope you are not unlucky enough to have had that happen. (sometimes that happens as the result of an element failure)
Mar 06, 2011 | GE Profile Spectra JBP95 Electric Kitchen...
I have a Maytag Glasstop stove (Mer5875qas). THe left front dual burner only heats on the outside ring. The inner portion does not heat. Could it be a wiring problem or is it more likely that the burner...
There are 2 likely causes. It is more likely that the element is open circuited and needs replacing. The hotplate controller could also be faulty. The circuit needs to be tested to determine the faulty part.
Feb 18, 2011 | Maytag MER5875QAS Electric Kitchen Range
Mer5875QAS electric range won't heat
Maybe bake element is bad or bake relay on board is bad.
Nov 05, 2017 | Maytag MER5875QAS Electric Kitchen Range
My oven won't work on bake but everything else is operational
Most likely have a bad heating element. Check for continuity in the element. Make sure to trip the breaker or unplug the unit before removing the element. 120 volts still run through the element even though it is not turned on. Takes 240 volts to make it glow red.
Apr 03, 2009 | Maytag MER5530 Electric Kitchen Range
Bake element doesnt work everything else does
hi there,
the bake element can melt for various reasons, however, i think that you problem lies somewhere else.
here is the service manual. have a look through it and let me know if i can be of more help.
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Sep 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
120 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
