to deactivate barrings go to call settings check on call barrings nd cancel all barrings... The default password is (0000)...altenatively u cn request a barring password frm ur service provider...also make sure no phone numberS ar in ur contact black list.!
just go to settings then select security settings... then select call barring services...select incoming calls only.. take note that when you select incoming calls and barred it you cannot also recieved sms or mms... ok... then activate it and it will ask for barring password.. a 4 digit password.. just put the default password 1234... ok... enjoy...
The default call barring password for N70 is 12345.So all you have to do is you have to go to menu and then after that TOOLS and the go to SETTINGS and the go to CALL BARRING and then press ACTIVATE to turn it on or CANCEL to turn it off.When calls are barred, calls may be possible to certain official emergency numbers.
Default call barring password is 1234..To change the password go to settings then call barring. Select options then edit password. Enter current password then new password two times to confirm. Make sure to remember the password. To activate call barring dial *33*1234# if your password is 1234, then press send/call. To deactivate dial #33*1234# then press send/call.
Call barring
Call barring (network service) allows you to
restrict the calls that you make and receive with your phone. To change
the settings, you need the barring password from your service provider.
Select Menu > Tools > Settings > Call barring.
Scroll to the desired barring option, and to request the network to
set call restriction on, select Options > Activate. To set the
selected call restriction off, select Cancel. To check whether the
calls are barred, select Check status. To change the barring password,
select Edit barrings passw.. To cancel all active call barrings, select
Cancel all barrings.
So try contacting your Vodaphone customer service and ask for the call barring code, see if it opens up with a code that they give.
