Question about Microsoft Windows 98 for PC
Cd-rom defect windows98 se
My cd- rom windows98 for instalation is defect is not instalation finish
    Problem Solver:
  • 12 Answers
Sounds like ur screwed. You are dealing with 9 year old software, that was out of date, and not supported for the last 8 years.
Time to upgrade.
Posted on Jan 25, 2008
6ya staff
SOURCE:
Installing canon pixma 310 printer to windows 98 os
  • Connect the printer to the computer.
  • Insert installation disk into CD/DVD ROM.
  • Go to my computer and double click on the printers icon to run setup,
  • Follow instructions till setup finishes installations.
If you don't have windows98 drivers for the printer download from here.
Hope this helps.Thanks!
Oct 15, 2011 | Canon PIXMA MX310 All-In-One Printer
How do i reformat my pc?
This is a pretty drastic process and takes several hours. If you have system slow downs and ongoing bugs you may be able to repair with software tools (see here), however that said, on with the show.
The procedure will decimate the data on your C: drive, so it's crucial that you back up all the data you don't want to lose.
Don't forget items like e-mail data and address books (see: How to backup e-mail.). Back up all your documents including your "My Documents" folder and all the data you've stored on your Windows Desktop which you'll find in c:\Windows\Desktop or c:\Windows\Profiles\<yourname>\desktop, where <yourname> is your Windows log-on.
Don't worry about backing up programs that you can reinstall later, unless you want a complete backup of your C: drive in the event of a problem.
Now, create a boot disk. Creating a Windows 98 boot disk is easy. If Windows 98 came factory-installed with your machine then one may have been supplied with your documentation. If not, you can create one through the Control Panel. In Windows, go to Add/Remove Programs and click the "StartUp Disk" tab and click the "Create Disk" button. It will create a boot disk on a blank floppy for you with CD-ROM support.
This is important, as you'll need access to your CD-ROM drive to do a new Windows98 install.
Once the boot disk is created, test it to see if you can access your CD-ROM drive. To do this reboot the machine with the floppy disk in the floppy drive and when the machine restarts choose "Start with CD-ROM support".
At the prompt type d: and hit the Enter key. If the machine responds with D:\> you are in business.
Next type "format c:" without the quotes (and hit ENTER).
The C: drive (main hard drive) will then be wiped clean.
Once the reformat is finished put your Windows CD-ROM disk in the CD-ROM drive, and type "D:\setup" at the prompt.
Once Windows is finished installing, reinstall your backup software and restore your data to the hard drive.
And Thanks.
Mar 05, 2010 | Microsoft Windows 98 for PC
How to install a new operating system on my hp laptop
In almost all instances a new operating system will be installed from a CD or DVD.
1. Start your computer and enter BIOS to make sure CD/DVD is your first bootable device. 2. Have your CD/DVD in the CD/DVD drive and boot the computer 3. Boot the computer and generally you will be prompted to hit any key to boot from CD 4. A guided setup process will walk you through the installation of your given operating system
Oct 08, 2009 | HP OmniBook XE3 Notebook
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
DELL C400 LAPTOP
you may need a separate hard drive, you could try to boot off of that
Oct 24, 2008 | Dell Latitude C400 Notebook
Bad disk
agri-man
low-lable format can solve ur problem.
at first create windows98 startup disk from any win98 pc or use windows98 bootable cd. and download disk manage 9.54 for samsung hard disk. and copy it in a cd. then boot ur pc with windows98 bootable disc or startup disk. then inseart disk manager cd go to cd rom drive give "dm" commnad. run low lable format form advance --->utility ----->maintanance------> low lable format. after complete low lable format (it can take saveral time) then creat partition and format each partion.
Jun 25, 2008 | Samsung (SP0411N) 40 GB Hard Drive
LG CD-ROM CRD-8521B driver
go http://www.cdrom-drivers.com/drivers/77/77204.htm (thats driverguide: name temp; pass 512)
but that CD reader does not need drivers if you use windows98 Me 2000 XP 2003 or Vista... if its not working and your computer is ok you surely have connected something the wrong way.
Mar 15, 2008 | LG CRD 8521B Internal 52x CD-ROM Drive
Dvd rom detecting problem
You need to find what DVD reading and CD and also DVD burning software you had, then download versions of the programs compatible with Win 98--then they should work fine. Your CD/DVD drives will be ignored until you get the correct burning software installed. Go t Samsung, which hopefully will have the appropriate downloads for Win98. If Samsung no longer has what you need, find any software for Win98 such as Roxio, or hopefully freeware, and you should be back in business.
Feb 12, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Re:CD ROM
when you boot up the computer does the drive show up in POST?
Does the drive show up in the device manager?
Jan 03, 2008 | Microsoft Windows 98 for PC
Microsoft Windows 98 for PC Logo
63 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
