Akai PT5598HDI Rear Screen Projection TV With Blue Shadowing
My Akai PT5598HDI has developed a blue shadow or ghosting around white colored objects. I purchased it late in 2004. The picture is a little better if I turn the contrast down to zero, but that makes for poor picture quality. I am an electronic technician so I possibly can perform most repairs myself. Just need ideas or direction to follow.
Thanks, Jim Nelson
mailto:[email protected]
  • jncurly Jan 26, 2008
    The blue halo around objects sounds like the problem. People with black hair usually appears with a bluish tint. All three colors appear very good. Can I request instructions on how to replace this coolant and where is the best place to get this fluid. Thank you very much for your help so far.
  • jncurly Feb 03, 2008
    You nailed it. I just received the CRT coolant on Friday, followed your instructions verbatim and my projection TV now looks better than new. The old coolant in the blue and green tube tank was a dark yellowish color with a slime built up on the tube face. I used alcohol and cleaned all three tubes and replaced with new clear coolant. With a little manual convergence it now has vibrant colors and looks great again. Thanks for your help.
    Jim Nelson
  • 8,617 Answers
If the ghosting is like a 3D effect its your convergence ICs , but if its like a blue Halo around objects that usually means your CRT coolant has congealed and will need replacement. The blue is the first tube to congeal for some reason, followed by green. Red seems to be not quite as prone to this. It is a normal occurrence n sets about 4 years old to need the coolant changed.
Posted on Jan 25, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Jan 25, 2008
    If you would like instructions on how to change the coolant let me know .
  • Sonny Berry
    Sonny Berry Jan 26, 2008
    Okay you have to remove the blue crt. First and most important is to remove the HV Lead from the HV block and then ground that lead to the chassis to discharge the CRT. The lead has to remain in the Tube. Next label the Yoke plug connections where you unplug them from the chassis. The yoke and purity rings have to stay on the picture tube. Then remove the PC board from the end of the picture tube. There will be at least one or two ground wires running from the tube pc Board up to the shield on the tube. Disconnect those. Then there will be 4 small screws holding the picture tube assembly into its mount. Remove them and lift the tube up and out of its mount. Be careful not to bump the tube or purity rings while removing it. Most tubes have a plug that is removed to gain access to the coolant chamber between the tube face and lens assembly. Remove the plug and pour the coolant into a pan and discard. After the coolant is out it is best to loosen the bolts with the springs in an alternating pattern and remove the coolant chamber form the tube face so you can clean the tube and chamber with alcohol. Dry it good. Them reassemble the coolant chamber by alternately tightening the bolts with springs until secure. Then fill the chamber with new coolant and reinstall picture tube in its mount. That's about all there is to it. It takes probably an hour to remove the tube and put it back in. just take your time and label any wires you remove. I will post a link to where you can purchase the coolant. Let me know if you need any additional info.
    http://www.matelectronics.com/cgi-bin/ss...
  • Sonny Berry
    Sonny Berry Feb 03, 2008
    Good to hear your set is back in top operating condition. The coolant definatly makes a big difference.Glad that I could assist you.
6ya staff
SOURCE:
The colors on my TV are shadowing each other in different colors. Such as blue and red.
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2010 | Televison & Video
We have a Hitachi projection tv maybe 54" that worked fine yesterday but today has shadowing/ghosting in pink & green. Wondering if there's something easy to try to fix? If not, is it worth getting it...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 03, 2010 | Philips 60PP9352 60" Rear Projection...
My picture suddenly has "ghosting" or "Shadowing." Cable is fine in the other room and I also tried the picture through my dvd. same thing.I tried the touch focus but this did nothing.
*Screen Looks 3-D
*Colors wont align
Problem #2
Oct 17, 2009 | Toshiba 42H83 42" Rear Projection...
Blue color on screen
If mostly blue shadow appears around the white objects means the cooling liquied is getting dirty and needs to be replaced.
May 27, 2009 | Philips 46PP9302 46" Rear Projection...
Blue and red overlap shadowing
convergence ic's are your culprit. they are responsible for aligning the 3 colors your tv projects onto your screen..
Mar 15, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Color ghosting or shadows
*Screen Looks 3-D
*Colors wont align
Problem #2
Jan 19, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Sony kp-48s75, shadow or ghosting picture
*Screen Looks 3-D
*Colors wont align
Problem #2
Jan 07, 2009 | Sony KP-48S75 48" Rear Projection...
Panasonic PT-60LC14 Convergence Issue
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 06, 2008 | Panasonic PT-60LC14 60" Rear Projection...
Convergence problem, blue ghosts
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Sep 01, 2008 | Samsung PCN5425R 54" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
265 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
