Question about Maytag CWG3600A Gas Single Oven
Warranty registration i would like to rerister my warranty for my maytag CWG3600AB OVEN . MODEL .NO.CWG3600AAB SERIAL. NO. 24773199LA my email is please verify regestration thank you. mr. bomba
  • 1,314 Answers
Re: warranty registration
Posted on Jan 25, 2008
0 characters
3 Points
Hello John,
Having replaced the ignitor and the gas valve having continuity the problem has be the gas safety valve bimetal is stuck. The only thing you check is amprage draw on ignitor it should be between 3.2-3.6 (as label on gas valve states) with a new ignitor and again continuty on gas valve its the gas valve its stuck and wont open.
Good luck,
Aug 09, 2011 | Maytag 27" Built-In Double Electric Wall...
My Maytag oven works when it wants to when I heat it up it take forever and then sometimes it will stay heated at the temperature I set it at and sometimes it just quits and wont start heating again after...
The number one problem for these ovens is the ignitor. This one is your ignitor according to your model number When it is weak it is intermittent. Sometimes you can get the oven to work if you give it a swift kick. This video explains how it works:
The next likely suspect is your oven sensor. That is the link to your oven sensror according to the model number you posted. Here is a video which shows how to check it:
Jun 14, 2011 | Maytag Ovens
Model CRE9600CCM Serial 24625851SK. When we turned on the oven, we got an error message "F-5". What does this mean? What do we need to do?
Here is a list of codes for Maytag-- Does this help:
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Let us know if we canhelp further,
Mack B
Jan 23, 2011 | Maytag Ovens
I am trying to register my Maytag Electric Dryer and can't seem to get the website to open? HELP!
The maytag website is currently "down" - basically, not working. As it's Sunday, they may be doing maintenance on the website or it's possible that nobody (except you) has noticed yet.
Please try again in a few hours or tomorrow. You can access the product registration page directly from this link - when it's working again:
Dec 05, 2010 | Maytag CWG3600A Gas Single Oven
Maytag walloven m# cwg3600aab Try to start. F5
Hi and welcome to FixYa, I am Kelly
I checked both types of Maytag oven fault codes and they both come up with the same fault.
Sadly this is telling you the Clock assy / ERC has failed.
F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC
F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
The clock assembly is item 1 this link:
Close up view(s) Click pictures
Thanks for choosing FixYa.
Oct 06, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
Maytag gas range, model MGS5770ADW,serial 34735247GG. Cooling fan comes on when temperature is set. Continues to run after cancel. Replaced control panel and igniator. Fan is still running.
I have run into this and I would bet you have a bad oven sensor.Im sure this model only has one pcb. so there is no fan board.try the oven sensor.
Mar 10, 2010 | Maytag Ovens
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Cant find serial number - model AOGD2750
open the doors it should be on one of the door frames on a metal tag
Mar 24, 2009 | Amana AOGD2750 Gas Double Oven
Free owners manual
hi there,
go to
then scroll down to the bottom right and you'll see customer support and then manuals & literature.
click on that and then type in your model #.
all the manuals are in .pdf, so make sure that you have Acrobat Reader.
May 20, 2008 | Maytag CWG3100A Gas Single Oven
Maytag CWG3600A Gas Single Oven Logo
469 people viewed this question
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Maytag Oven Expert? Answer questions, earn points and help others
