Question about Whirlpool ED2NTGXL Side by Side Refrigerator
Whirlpool ED22COXHW02 side ny side not freezing or cooling
This Side by Side mfd is: 08-00. The model is: ED22COXHW02
The compressor is trying to cycle but all you can hear is the solenoid clicking between 5 to 10 min. There are no service ports on this compressor to check the freeon level,or is the compressor shot?
  • Anonymous May 31, 2008
    the freezer door was left open all night.. now neither th efreezer or
    the fridge will cool. Both the frezer fan and the compressor fans
    fun but still no cooling.
    Model ED25PE Is there a solenoid or sensor O can trouble shoot or replace?
    President:
  • 1,314 Answers
Ill make it easy for you see if the compressor has a white reley on it if it does unplug the unit and pull it off if it rattles and black stuff falls out get a 3in 1 reley from your appliance store and replace it wont have no more problems after that
Posted on Jan 25, 2008
  • 770 Answers
What you are hearing the is the overload snapping open you have one of 2 problems your start system(relay/overload) for the compresser is out and will need to be replaced or your compresser is shot you will need to replace the start kit first most of the time it starts up the compresser just fine but if not the compresser will have to be replaced
Whirlpool side by side does not stay cool or frozen.
You need to check the overload relay on the compressor and make sure that the coils near the compressor are clean of debris and duct.
Mar 30, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side not cooling or freezing. Have already cleaned the condensor coils with no change. I did notice that the fan in the bottom back is not spinning.
that is most likely the problem. If this fan doesnt cool the condenser and compressor it will shut the compressor down. replace the fan and your problem will most likely be fixed.
Jul 11, 2010 | Whirlpool GS6NBEXR Side by Side...
Freezer not freezing, refrigerator warm, hear clicking sound
sounds like a bad starting capacitor ... thats about a 2 inch container mounted on or near the compressor .. it will have wires attached ... dont let the compressor keep cycling like that .. it will eventually damage the compressor and the refrigerator will quit working before long anyhow .. there is a little cooling now only because the compressor is successful at starting now an then but that wont last long ...unplug the unit until repairs are done .. move your food to another cooler .. the click you hear is the thermal overload switch shutting off the compressor power when it gets too hot .. the starting capacitors are not expensive and may have plug in electrical connectors that will make replacement easy .. it could be soldered in and that would make it a bit more difficult but usually there is a plug .. there will be numbers stamped on the capacitor .. thats what you need to get a replacement .. or you could remove it and take it with you to a parts supplier .. sometimes there are two capacitors in one container .. both have to be changed at the same time in that case (one for the compressor and one for the fan) ... there will be a part number and a value number .. the value might be something like "16 MFD " at 300VAC that gives you the value of the capacitor (not the phisical size) that example would be "16 micro farads" .. the 300VAC is the voltage rating
the part number gives you the size and mounting configuration as well as the value .. make sure the unit is UNPLUGGED before working on the capacitor .. if you call a refrigerator repairman then it should take him only about 15 min to replace the part if he has an equivalent part with him ... you could give him the model number of your frig and that you suspect the "starting capacitor" before he comes out ..so he can bring one with him ..
Oct 05, 2009 | Whirlpool ED2SHAXM Side by Side...
Not freezing or cooling
The clicking is probably the starter/overload relay which starts the compressor. If the relay is good then the compressor is bad. Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
Aug 30, 2009 | Whirlpool ED5GHGXMQ Side by Side...
Side by side refrig/freezer not cooling
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Whirlpool GS6NBEXR Side by Side...
Freezer quit freezing
HI,
you can try this suggestion first.
any further question let me know.
thanks,
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
From your description it sounds like your compressor has gone bad. Check the condenser and see if it is plugged with dust. Clean it and let the unit cool off for about an hour or so. A plugged condenser can cause the compressor to overheat which can cause the thermal overload to click cutting the power to the compressor. After the compressor has been aloud to cool off restart the system and see if the compressor will operate. If you had to remove a panel in the back to access the condenser make sure you replace it for proper air circulation.
May 31, 2008 | Whirlpool ED2FHEXN Side by Side...
FRS26KR4CB1 side by side refrigerator
It sounds as if you have a defective compressor start relay.  It is located on the side of the compressor, usually contained within a black plastic housing (box).  If ordered, it will most likely come with an overload proctector.  Change both parts.
Oct 13, 2007 | Whirlpool ED0GTQXMQ Side by Side...
Whirlpool ED2NTGXL Side by Side Refrigerator Logo
149 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
