Question about Dryers
Kenmore series 70 mod#110.62722100
Stops after a few minuets running will restart with start button timer still running can hear it ticking
  • karl_bartsch Jan 29, 2008
    Yes very helpful 7.95 for PTS switch vs 79.95 for timer or over 100.00 for new board works fine now.
  • 770 Answers
Check the door switch first if it is ok ..(doors not popping open) then the PTS (push to Start) switch is most likely bad as it wont hold in after it was pressed
Posted on Jan 25, 2008
  • Gary Davd
    Gary Davd Jan 29, 2008
    Great !!!!!!!!!!!! Glad I could help
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore 70 series
positon sensor or timer issue replace
Mar 09, 2010 | Kenmore 63942 Dryer
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Kenmore 70 series model 97576200
You have a bad thermal fuse , usually caused by lint blockage from the filter or vent hose .
Jul 06, 2009 | Kenmore 659 Electric Dryer
I have a kenmore 70 series electric dryer. The motor won't start, I can hear the timer ticking.
There is a circuit board that is in the control panel. It is mounted into a plastic carrier that is skrewed into the panel. You could pull it straight out and check it with a multimeter to see if there is continuty, check the two blue resisters and if no continuty, replace!
Jun 21, 2009 | Kenmore 63942 Dryer
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Kenmore 90 series won't start timer ticks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 110.96588210 Electric Dryer
you can take the top panel back off and check the start button with omes meter,push button in you should get a reading,let button out no reading ,if it fails the test replace,let me know what you find
Sep 22, 2008 | Kenmore 62602 Electric Dryer
Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Dec 23, 2007 | Kenmore 63942 Dryer
Dryers Logo
212 people viewed this question
Top Dryers Experts
