Question about Hitachi 42PD6600 42 in. HD-Ready Plasma Television
TV Problem Hi There Had TV 2 Years Turned on yesterday Sound perfect but blue screen, magic eye in spare room is fine and TV works Has my picture board blown? Thanks
  • Tomaz Feb 15, 2008
    thanks Techy Steve - is it relatively easy to fix? We have been quoted £350 to fix which we prob wont as a new telly wont cost much more. We will never buy Hitachi again.
    thanks
    Problem Solver:
  • 6 Answers
NO IT HASNOT .. IT SOUNDS LIKE YOUR EPROM
Posted on Feb 15, 2008
6ya staff
SOURCE:
Hi we have lost all channels of our hisence tv just blue screen saying no signal please help had channels yesterday
Nothing to worry, You change to AV mode to TV mode and wise verse,
If nothing happen then call the service center, It only two months old.
Jul 23, 2012 | Hisense LCD1504 15 in. Television
Hi, I have had my TV for a few years now and it's always worked perfectly. Just yesterday, I turned it on and there is a picture and no sound. Any advice??
Take your remote press menu and scroll down to audio, check the audio settings carefully, if you find speakers off turn it back on that will restore the sound, failing that! check to see if the mute is on if it is turn it off to get the sound back. If none of these work I suggest a tv technician to remedy the situation.
Jan 10, 2011 | Sansui DTV2760 27" TV
Sky magic eye not working on hd
I work for Sky as an Engineer.
on your Sky HD remote:
service,
4,
0 1 select
make sure the power is turned ON
now go to the room you can not change the sky channels over with.
you should notice on the magic eye itself should now have a Red led light on it now. you should now be able to change the channel over just remember to press the blue sky button on the remote at the top otherwise this will not operate the sky box.
If not unplug this magic eye and try this directly into RF out 2 to make sure that its not the magic eye that is at fault. If it is working correctly then the light will appear.
Hope this helps
Little dish fitter
Aug 16, 2009 | Televison & Video
Samsung LCD -no picture/sound from any input source-Cable,DVD,PS3
Use the menu button in the front screen of your tv.Maybe your remote control need a battery.
Jul 24, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
Feb 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
TV turned off itself
Can you still turn it on?
If so, does it stay on with sound?
If the sound is ok and the picture is blue (even when changing channels, inputs, etc.) the lamp may have gone out.
Can you see the TV menu when you press the menu button on the remote or TV?
Jan 07, 2009 | Sony KP-51HW40 51" Rear Projection...
No Blue
The bulls eye is what us TV repair guys call it. It is a perfect description. The tube is good. The automatic degausing circuit is not working because the black square thermistor D805 needs resoldering on the bottom of the board. You will find that a magnet will affect it, and a degaussing coil will make it look perfect for 1 week. Soldering the thermistor is a permanent solution.
Mar 24, 2008 | Panasonic CT-27G21 27" TV
Olevia 30 HVS
I had the same problem. I unplugged my tv to move to another room and it will not cut on at all. I have only had the tv for three years
Dec 12, 2007 | Syntax LT30HV 30 in. HD-Ready LCD...
SONY KP57WV600-Turns Blue
yes ,it sounds like screen adjustment or focus block, should be around $200- $325 to repair.
Sep 08, 2007 | Sony KP-57HW40 57" Rear Projection...
Hitachi 42PD6600 42 in. HD-Ready Plasma Television Logo
215 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
