1994 52in. RCA projection TV
I had this TV in my basement for the past 13 years with hardly any use. Maybe 100 hours total. I recently moved and sold the unit and during the move the unit fell on its back. The buyer said they first had to reset the convergence and then they kept having to do it. They finally left it like it was and then the picture just started "zigging & zagging& jumping". Now they cannot get any clear picture. The unit has never given me trouble up until the move.
  • 8,617 Answers
Sounds like a solder issue either in the horizontal / Vertical deflection circuits due to the fall. I would check out the solder joints especially around the heat sinks. Hope this helps. If you provide the Chassis number for the RCA I can be better equipped to give you component locations to inspect.
Posted on Jan 25, 2008
Lost picture
When was the last time u replaced the projection bulb,yes it could be that simple the projection bulb it dead.The bulb last only about 1 or 2 years,by using the tv on about 4 or 5 hours a day.
Jun 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52' Projection TV Model 52W19B Need help with bulb replacement
bulb? what model do you have....is this a d52w19? if this is a rca itc222 chasis unfortunatly it has no bulbs.. it should have tubes and these are not fesable to change
Oct 07, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 - turns on and off, blue screen, tech said need picture tube
It does sound like the tube, have the shop use a tube restoration machine to rejuvinate the tube, and replace the eprom to try to correct the no power down situation.
Aug 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv turning off by itself occasionally
Just had mine repaired yesterday.
They relaced a TD4611 voltage regulator and a C2200uf 50v part.
Total including service call $188.00 in Western Canada.
Phil
Jul 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 56 inch projection TV
six inches will just reach the bottom of the main cuircit board. Does the units green light flash? there is no reset hutton there is a fuse. but i would suspect if it got wet then something blew
Feb 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59, Serial: G075CN0AO, Chassis # 1TC222A
ask your service depot about the service flash on the covergence connector,causes intermittant faults and deflection problems /
Aug 22, 2007 | RCA HD52W59 HDTV Projection Television
Tv turns black and white
No, the tube is not bad. There are a couple of very small surface mount components mounted by the main microprocessor that could be causing what you are seeing. They are very small and quite hard to unsolder and replace without losing them. The set should be serviced by a qualified tech familiar with the new RCA chassis.
Aug 21, 2007 | RCA F27650 27" TV
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
