Question about IBM Wheelwriter 30 Typewriter
WHEN TYPING THE WRONG LETTERS PRINT
The letter I hit on the keyboard do not print on the paper....I can hit B and it prints 6, I can hit t and there is a 3 like to the 3rd power to the upper right of the t......On the display the letters are all garbled as well as on paper The display also shows "APAGE" and KYBD 099, but we have no manual and do not know the solution. The keyboard seems to be connected properly.
  • 4 more comments
  • Andiepoo Feb 06, 2008
    I am having a similar problem as roxie211, I the code button with x and it is not working. HELP!
  • Anonymous Feb 19, 2008
    When typing the number 5 we are getting 1/2 typed instead. Where do we find an instruction booklet online? This is for the IBM Wheelwriter 2500
  • bethamic Mar 03, 2008
    I have the same problem my display shows KYBD099 and is printing the incorrect letters code x did not help? Any other suggestions?
  • Magikist Mar 05, 2008
    My problem is similar. When I type a m the letter y types right after...and when I type a t the letter v types first. But when I type the letter d, the whole keyboard freezes and nothing works. I've restarted this thing a dozen types. and I've hit the code-lang key a thousand times. Nothing's helping!!
  • anbarasu Jun 25, 2008
    i also a similar problem when i type shift+2 it print as " and when i type shift+' it prints as @...when shift+ 3 is typed it prints as£
  • Reuben Prinzing
    Reuben Prinzing Jan 17, 2014
    where is the key code
  • 478 Answers
Keyboard 99 is Laten supplemental. Try holding down the code key and pressing the x key it should reset the keyboard.
Posted on Jan 26, 2008
My Brother ML100 is not printing what I type
Hammer sticking and typing incorrect letters (and or skipping letters): 1) make sure daisy wheel installed correctly. 2) hold down CODE key & Q (RESET) to reset wheel...if still not corrected 3) WD40 the hammer at the base & joints where moving parts are, keep typing until oil seeps in (this last one fixed it for me)
Typing light and inconsistant-top part of letter okay but bottom too light or not there: to left of hammer (at base) are 2 screws, I losened them and adjusted hammer to different forward and backward spots..finally found the ideal location where full letter printed and had the correct force it needed to print correctly.
Feb 21, 2013 | Brother ML-100 Typewriter
Wrong letters are printed
The Daisy wheel is probably in wrong..reinstall it until it spins to the home position. Its either that or an adjustment to the print wheel motor.
Oct 07, 2009 | Swintec Office Equipment & Supplies
IBM wheelwriter not printing letters during typing the letters on the keyboard
The print solenoid has a plastic cap it is probably broken. They are available but a little tricky to install.
DickyO
Mar 06, 2009 | IBM Wheelwriter 30 Typewriter
DL PRT how to release this function??
On the rt. side of the keyboard is a key that says print mode.
press that key the dl print should go off on the display and you should be in business.
DockyO
Feb 23, 2009 | IBM 3500 Typewriter
TYPING II IN PLACE OF LETTERS
the mark you are seeing is the print hammer hitting the paper. remove the ribbon. corr. tape & print wheel. turn on the typewriter. close cover let it home it's self. open cover put in print wheel. close cover let it nome. put in ribbon close cover. try typing if marks are still ther. you will need a new print wheel. if working then put in corr. tape or if you are better at spelling then me you will not need it
Jan 21, 2009 | Smith Corona Wordsmith 200 Typewriter
Brother EM530 Typing Wrong Letters
Hi there. Take out the printwheel and see if any of the spokes are bent. That would cause wrong letters. . Also if the print solenoid(piston) does not go in and out freely. Lawrence
Aug 06, 2008 | Brother ML-500 Typewriter
Types wrong letters
It sounds like you have the 10,12,15,PS selector switch on PS with a 10, or 12 print wheel installed. Return to the left margin, move the switch to 10 and type.
Jun 25, 2008 | Swintec 7040 Typewriter
Printing wrong letters and numbers
Typing wrong letters.
Please help immediately
Apr 28, 2008 | Brother GX-6750 Typewriter
Not printing correct letters
check to make sure the selection lever for pitch is not in the ps position and that the keyboard selector is in kb1 position
Feb 21, 2007 | Brother ML-100 Typewriter
IBM Wheelwriter 30 Typewriter Logo
560 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
