Question about Hoover Soft Light U4266-940 Bagged Upright Vacuum
Vaccum Bag How do I change the vaccum bag? I no longer have the booklet. I keep hearing about a zipper. I can't find a zipper. There is sliding piece of plastic at the top. My bag is full, and I need to change it...Help!
  • 126 Answers
Slide the plastic piece off the cloth bag and open the top. Looking down into the cloth bag, you will see the old bag. It is secured to the machine near the top. You will find the cardboard collar about a third of the way down. Remove it carefull. Now, stand BEHIND the machine and put your knee against the back of the handle and taking the new bag, open the hole in the cardboard collar and insert the bag into the cloth bag and put the cardboard collar onto the handle fitting. It helps to put the lower part of the hole on first and then press the top of the collar onto the handle fitting. The idea of standing behind with your knee against the handle is so that as you attach the bag, you will be pushing against your knee which will steady the machine and allow you to use the required force to complete the action. Once completed, fold the top of the paper bag down, so that when you replace the top slider, the paper bag is NOT clamped between the cloth bag and the slider.
Posted on Jan 27, 2008
How do you take this body apart to get to the to the motormotor
Look for recessed screws from the bottom and in the bag area. Take all the screws out and pull top and borrow apart. Keep track of the screws. Some may be longer than others.
Jan 29, 2015 | Black and Decker USA Black & Decker...
I have change my vacuumed bag an when start vaccum again it is not pulling and check bag light is on
Depending on the Model you have it may mean the bag is not installed properly or you May have a clog somewhere
Mar 08, 2014 | Vacuums
My vaccum is smoking help!
The motor has burnt out Cheaper to get a new unit than to have it repaired. Always make sure if you use a bag that you keep the bag clean as it requires free air flow to cool the motor.
May 26, 2013 | Vacuums
Having a terrible time keeping the bag attached during use. I am tired of cleaning the inside of the cloth zippered bag. I am using the correct Oreck vaccum bags, and using the metal clip that holds the...
I would Recommend getting a docking system. its $20 and takes place of the metal clip and ensures that the paper bag and outer bag both stay in place and to ensure no leakage.
Sep 04, 2011 | Oreck XL Ultra Bagged Upright Vacuum
I don't know how to change the bag for the machine, bag # SR 401010. Vaccum is Maytag Legacy series. Is there a diagram or picture to show how to replace the bag. Thanks
http://www.hoover.com/CustomerService/Manuals/Default.aspx Enter your model number on Hoover's website to view or print a manual. I suspect that you may have accidentally discarded the bag frame ( part # 93001544 ), which holds the bag in position.
May 21, 2011 | Maytag Hoover Duros S3590 Vacuum...
How i clean cloth bag sc886 vaccum
well if you must clean it,,(not a good idear to do so) you could throw it in the washer by its self! but its far better to put a new cloth bag into the vaccum cleaner,, a washed cloth bag wont work half as well as a new bag will,,all you will get is even more dust out of it,,,thats twice the cleaning,, buy a new bag and save the time and work
Jun 25, 2010 | Eureka SC886 Bagged Upright Vacuum
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Just powered itself off
It will shut off if your bag is full. If you are cleaning up fine dust, it will give a false bag full indication. Take the bag out and carefully, shake it down to get the dust out of the filter layers inside. This will let more air flow through the sensor.
Nov 20, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Vaccum just stopped working tried turing back on and nothing
Check and make sure that the bag emptor(bottom of bag asm.) is pushed up against the casing. There is a safety switch there that may not ne engaged. Cord may be bad, one side of the line may be open. Noozle asm. not on straight, there is another safety switch there. Problem with switch or motor.
Mar 22, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Hoover Soft Light U4266-940 Bagged Upright Vacuum Logo
182 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
