Question about Bosch 30 in. NGP 732 / 736 Gas Cooktop
Intermittent fault my gas hobb has an intermittent problem with one of the burners,sometimes will go out i am running the gas hobb off a 12 kg bottle,with a 25 metre distance from the bottle to the hobb, i have been told that the loss of pressure could be the problem,but i am not so sure as the problem is isolated to one burner
  • bretto66 Jan 26, 2008
    is on full
  • robert samples May 11, 2010
    is the burner on full or simmer when this happens
    President:
  • 1,314 Answers
I wold pull the orfice out of the burner and check for a partial obstruction hold it up to the light look down in the burner tube
Posted on Jan 26, 2008
My 5-burner 36" gaggenau has stopped working. I
Hello.
What the problem is a part in the cooktop that opens to let gas flow to the knobs as soon as they are turned on is bad and no gas coming to surface unit burners. This a safety feature that the German goverment(where Gaggenau is made) requires that part to prevent a gas leak when cooktop is off.
Gene
Aug 08, 2011 | Gaggenau 36 in. KG 291 Dual (Electric &...
Large burner elements ignite, and igniter spark fails to stop, then the burner shuts off as if ignition failed. Tiny central burner element does NOT light at any time. Apparently the safety cutoff...
There is a thermistor that must be in the flame area that needs to get hot. When hot it will turn the igniter off and keep the flame on. Check it's location and if it is in the flame then it needs to be replaced. not sure about the central flame problem. could be the switch.
Sep 20, 2010 | Gaggenau 36 in. KG 291 Dual (Electric &...
Gas stove burner will not turn on
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 29, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
Burner will not light
Try running the burner thru the dishwasher this does work sometimes, if not I would replace there not very expensive.
www.appliancehelponline.com
Mar 31, 2010 | Jenn-Air JGC8536 Gas Cooktop
How do you light gas manually when power is out?
Turn your burner on to high, then use a lighter with the long spout on it to light the flame by moving the lighted flame to towrds the burner slowly.
Make sure to use the type of lighter that allows you to stay back so you do not get burnt.
If the burner does not light do not let it on for more than half a minute.
Heatman101
Jan 21, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
Cook top burner knobs all 4 not able to turn
Just to be clear, non of the 4 burner controls/knobs will turn ? You are familiar with this unit are you ?
Typically you must push down and turn to activate them.
Let me know if that is not the solution.
Good Luck :)
Oct 29, 2009 | Gaggenau 23 in. KG 260 Gas Cooktop
Jammed knob on Gaggenau cooktop
It looks like the gas valve for FR burner has to be replaced. Very unusual for Gaggenau gas cooktops.
Nov 18, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
Burner head covers
POWDER-COATING IS THE BEST BUT PRICEY AS-WELL. GO TO THE AUTO STORE AND TRY USING HI-GLOSS HEAT RESISTANT ENGINE PAINT. THEY HAVE BLACK AND SEVERAL OTHER COLORS. MAKE SURE TO READ AND FOLLOW THE INSTUCTIONS ON THE SPRAY-CAN CAREFULLY.
Apr 30, 2007 | Gaggenau 23 in. KG 260 Gas Cooktop
Flame too low
Most probably dirty jets. If water was spuilled, there is a possibility of rust forming on some parts. Low flames are usually due to inadequate gas supply, due to dirty jets and burners. Often rust forms on the top burners in the little holes, causing slight blockage - clean the holes with a needle properly and check. Oshie
Jul 30, 2006 | Gaggenau 23 in. KG 260 Gas Cooktop
Bosch 30 in. NGP 732 / 736 Gas Cooktop Logo
109 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
Narinder Chhina
Narinder Chhina
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
