Question about HP LaserJet 3100 All-In-One Printer
HP 3100 LaserJet All-in-one Print Driver for Vista OS
Do you if there are companies that design print drivers for older printers? HP has no intention of manufacturing a print driver so I can run my printer on the new OS. If I can get a driver to run my printer can I set up the this printer as a "shared" printer and print wirelessly without a physical connection?
Thanks
DC
    Problem Solver:
  • 15 Answers
It doesn't work in share mode either...It prints the pages incorrectly. I have the hp3100 connected to my xp pc and my vista laptop connects to it via printer sharing on my network. the xp prints fine but the vista doesn't print ok due to lack of driver support for it.
I have to resort to print to pdf and then take the pdf to my xp for printing. Its a half *** solution but if anybody out there made his/her own driver please post.
Posted on Aug 02, 2009
    Novelist:
  • 109 Answers
You're right about the printer not being supported in Vista. Maybe you can try the XP drivers? Sometimes they work well.
About sharing your printer:
Yes, this is possible and more easily done then you might think. Just rightclick it (if you get it installed), select Sharing... and enter a share name for it.
Then on the computer you want it to be available, add a network printer and make it look in the workgroup your in.
Make sure your PC's are all in the same workgroup. You can change the workgroup when rightclicking the Computer icon and go to Properties. In the screen that pops up, click Advanced System Settings on the left. Go to the tab: Computer Name and click the Change button. Over there is a field which allows you to enter the name of the workgroup. Make sure all PC's are in the same workgroup.
Also make sure your computers both have Printe Sharing enabled, to enable:
Go to Control Panel > Network and Internet > Network and Sharing Center.
If the driver isn't supported it might get difficult to make it work. You can always try drivers from similar models (HP ones). Drivers are often based on each other.
I hope this helps, please rate my solution.
Greetings,
DarkNeogen
Posted on Jan 25, 2008
Why does my printer print black pages? I have a HP laserjet 3030.
Were you able to print color before? If not then you may want to reinstall the print driver.
Without knowing your OS (Windows XP, Vista, 7) I can't give you a direct link to the driver, however you can select the OS here : http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=378058&taskId=135&prodTypeId=18972&prodSeriesId=378056&lang=en&cc=us
And select the driver from there. Both the PCL5e and PCL6 drivers should work, but there's no need to install both at the same time.
Jun 23, 2010 | HP LaserJet 3030 All-In-One Printer
My HP Laser Jet 3330 keeps sending pop-ups and PRINTS out a message with the headline: HP LASERJET DIRECTOR: shortcuts and more..This occurs every time I start (boot?) my new Compaq CQ5110F PC with Vista...
Sounds like you have a software or driver conflict. Go to hp.com Support & Drivers and check to make sure you have the correct driver for Vista. Even if you do, try uninstalling and reinstalling the driver.
Also, while at hp, check for the latest Firmware update. Go to the printers menu and scroll to INFORMATION (or REPORTS). Select that sub-menu, then scroll to PRINT CONFIGURATION PAGE. Select thi and print out the page. Look for what is beside Firmware Datecode. If it is older than what is on the hp website, print out the instructions for installing the update.
Apr 30, 2010 | HP LaserJet 3330 All-In-One Printer
Driver installed, does not print!
did u get a test print when u installed it....
do u c the printer hardware installed in the Control Panel/Printers and Faxes/
if yes then check to see if that printer is the default printer selected (a tickmak will appear in front of that)
else uninstall the printer from the Control Panel and re-install
Dec 17, 2009 | HP LaserJet 1100 Printer
HP laserjet 1300n won't print duplex from vista
in the printer driver setting there is option to turn on manual duplex printing.
Go to printer driver properties go to printing default under printing default there is a option called finishing in finishing print on both sides is mentioned select that option and i m sure it should work
May 03, 2009 | HP LaserJet 1300n Printer
HP laserjer 4m plus
HP doesn't offer a driver for this on Vista, because it's so old. However, the driver is supposed to be bundles with the Vista OS. Have you looked in the add printer wizard?
May 02, 2009 | HP LaserJet 4 plus Printer
HP laserjet 1100 won't print from Vista laptop
Which version of QuickBooks are you using? Anything older than 2008 will not work with vista.
Jul 08, 2008 | HP LaserJet 1100 Printer
HP LaserJet 1320 problem
For this you first uninstall any previous Driver. Install the Drivers after restarting your system. After Installing the drivers connect the Printer. Note down now the Driver must be automatically work because HP1320 is a plug n play Printer. If not change the cable used to connect the PC with Printer and if the Printer is auto detected, you will be able to print the Test Page or any other page.
Feb 12, 2008 | HP LaserJet 1320 Printer
Won't install on Vista OS
Goto the following site and download PCL5 or PCL6 driver.
Uninstall any driver used already. Plugout your printer and then Install the downloaded driver. After finishing the download connect your Printer. You must be able to print on this Printer from Windows Vista
Feb 06, 2008 | HP LaserJet P2015dn Printer
HP LaserJet 3100 All-In-One Printer Logo
817 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
