Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
XP Pro In my control panel add and remove there is a huge gap between the first entries and the last starting after E's and with a black area and white verticle stripes that get wider until it starts again with G's (I have to move the slider almost to the bottom before the G's show up and I am not sure what caused this. I have 3.5 gig of Ram and 2 - 250 gig hard drives. I want to reinstall my XP Pro (I have an upgrade CD) since I feel this will fix the problem and since my computer does not respond as fast as it should and programs open slowly, is it possible to reinstall the uograde? Will I loose any information or data? Thank you
  • MrRam333 Jan 25, 2008
    I forgot to mention that I previously upgraded from 98SE to XP Pro with the upgarde CD I purchased. I wanted to know if the upgrade CD be used to check for errors or reinstall over itself to fix any missing registry entries?
    Novelist:
  • 113 Answers
The problem is with one of your installed programs that has a bad custom uninstall icon registrations - likely the last one listed before the gap, though it could be the one listed after the gap. And in one case, the program that was causing the gap was not otherwise displayed at all in the add/remove programs list!
If you go to the registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall, you'll find a list of programs that have registered for appearing in the Add or Remove Programs control panel. Some of them might have been so kind as to provide a "DisplayIcon" value, thereby saving the control panel the indignity of having to guess at an appropriate icon.
Unfortunately, if they put a bad icon registration in that registry value, the result is a bunch of blank space since the control panel is trying to reserve space for a bogus icon.
The format of the icon registration is a filename, optionally followed by a comma and a decimal number.
C:\full\path\to\icon\file.dll
C:\full\path\to\icon\file.dll,123
Since this is not a command line, quotation marks are not necessary (although they are tolerated). Furthermore, the number can be any value except for -1. Why is -1 forbidden? Because the ExtractIcon function treats the value -1 specially.
If the icon file does not exist in the icon file, or if the icon number is -1, then the icon specification is invalid and the Add or Remove Programs control panel will reserve an odd amount of space for an icon that doesn't exist.
Posted on Jan 25, 2008
    Novelist:
  • 109 Answers
Reinstalling Windows can be done in two ways...
1. Install it over your current installation.
2. Install from scratch.
The best thing to do is back-up data on some other disk that you cannot miss. Make s since a clean install will erase all data. Installing Windows over your existing installtion is not advised since it makes a huge mess out of things.
I'm not sure about the upgrade CD. It should work, if it doesn't you need to install a copy of XP first and then use the upgrade CD over it.
I hope this helps you out. Please rate the solution.
Greetings,
DarkNeogen.
  • Pascal Willemen
    Pascal Willemen Jan 25, 2008
    You can boot from the CD. There are some options in the setup. Do not choose for the Recovery Console but accept the license agreement and select the installation you want to repair, using the R key. If there's no option to Repair, do not continue because you will install a new version.
    When it has copied the files, let it reboot but don't let it boot from CD anymore.
    For reference, you can see this article:
    [How to perform a Windows XP Repair Install]
    Greetings,
    DarkNeogen.
  • Pascal Willemen
    Official Microsoft reference: link
Optimizer Pro virus
You can try to remove it as under:
A. Please click start, click control panel, click Programs and Feature(Add or remove if you have Windows XP) and then find Optimizer Pro listed there. Please try to remove it from there.
B. Please scan your computer using free version of Superantispyware.
http://www.superantispyware.com/
Please run quick scan.
Thank you.
Jun 01, 2013 | Computers & Internet
My windows xp pro games are gone
Do you meant the Microsoft Games (ie Freecell, Hearts,etc...) in XP?
You will need the XP CD to reinstall the Games if the Games had been removed.
Click Start -> Control Panel ->Add or Remove Programs(under catergory view)->Click Add/Remove Windows Components, this will bring up the "Windows Component Wizard", Check or tick - Accessories and Utilities (you can click on ->details to view the options your are installing)-> click next & follow the wizard to finish the installations.
Hope it helps.
Jun 24, 2011 | Microsoft Windows XP Professional
Rmy yahoo bar disapears
Click Start
Click Control Panel
Click Add/Remove Programs
Click the entry for the software
Click Uninstall
Restart your computer.
Reinstall the software.
Feb 01, 2011 | Microsoft Windows XP Professional for PC
Hi there, I recently had to reinstall Windows XP and of course then reinstall the Airplus DWL-G510 drivers. I accidentally did this whilst the card was still installed in the PC (Which it tells you not to...
If you are not OK with editing the XP registry, then I would enlist a computer savy friend to help you. If you make a mistake the computer will be inoperative and needs Windows XP re-installed again.
The other way is to re-install Windows XP from scratch but make sure the Airplus is card removed first.
To fix your problem using Regedit follow these steps :-
1. Remove the program using Add/Remove Program.
2. Delete the Airplus folder from the Program Files folder.
3. Click on Start - Run and type Regedit (registery editor)
4. Click on Edit then Find and type Airplus
5. Click Find Next
6. When Regedit finds a Airplus entry then delete this entry and press the F3 key to find the next Airplus entry - delete and repeat until all Airplus entries have been removed.
7. Close Regedit and reboot the laptop.
8. Install the Airplus driver etc.
If this doesn't work then re-install Windows XP from scratch, it might be quicker to solve this problem in the long run.
Have fun.
Let me know how things go.
Nov 15, 2009 | Computers & Internet
Only prints color--black ink is full, just put in a new cartridge
Instead of trying to change or find a "setting", the fastest resolution is to uninstall and reinstall the Printer, If not sure how, click start, click control panel, on the left of the window if you see switch to classic view, click there, IF XP, click Add/Remove Programs, if VISTA, click programs and features, remove all entries and reinsert install disk and repeat setup
Apr 12, 2009 | Kodak ESP 5 Printer
Large space between apps in add/remove programs
Download tweak XP from the net, install it, run it, there is a tab named ADD/REMOVE programs, it DOES NOT add or remove programs, rather, it allows you to edit the Add/Remove program List only, so you should select the "blanks" and remove the from the list. ReClarify: IF you remove an entry from the Add/Remove tab using Tweak XP, It will no longer be available under windows control panel add/remove and if it IS still installed you will NOT have a way to remove the program.
Apr 02, 2009 | Computers & Internet
XP Pro desktop: I open web page and screen closes back to desktop
Could be either a virus or compatibility issue with an update. Go to Control Panel > Add/Remove Programs. Click in the SHOW UPDATES at the top of the screen. Scroll down until you find Windows Internet Explorer 7. Look for the newest date of Updates to IE. Uninstall the last update by clicking on it and selecting remove. Then test IE. If this does not work, look for the last Windows update and do the same.
Mar 14, 2009 | Intel Computers & Internet
A large gap/divide in add/remove programs
just restore your system to an earlier date it may solve the problem: start - accessories - system tools - system restore ....
Mar 13, 2009 | Microsoft Computers & Internet
Uninstall XP Professional
If the computer was upgraded, then go into START | CONTROL PANEL | ADD/REMOVE Programs, see if uninstall Windows XP Pro is there. If it is you can uninstall it and not loose anything and the computer will reveert back to the operating system that was on there, before th upgrade.
Sometimes it is there, sometimes not.
If that doesn't work, then go to START | CONTROL PANEL | ADD/REMOVE Programs | windows components, and take out any uneeded components. Also check your system tray (bottom right by the clock) and see if there are eny programs there that you can close or better still uninstall as they eat memory and slow down your system.
Jan 08, 2009 | Microsoft Windows XP Professional for PC
Add/remove list
Download CCleaner,from here:
http://www.filehippo.com/download_ccleaner/
the link is on the top right in the green area...
Install, Run.... Click on tools on the left, and there you are your add/remove programs can be deleted from there...
Have a nice day!
Dec 24, 2008 | Microsoft Windows XP Media Center Edition...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
67 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
