Question about Pentax Optio S4i Digital Camera
Optio S4i will not turn on?
I have been out and bought a new charger and 2 new baateries for my Optio S4i, and the battery's are working fine, but when I try to turn on my camera, the light stays green for about 15 seconds, it beeps then turns off? Screen doesn't light up and nothing else moves?
Any suggestions would be really helpful, thanx
  • 3 more comments
  • Anonymous Feb 12, 2008
    my digital camera has the same bug... i turn it on, it beeps and then it's turning off. If i press and hold the on button the camera beeps and enters in the recordings, but when i try to enter in photo mode the camera closes...
  • Anonymous Feb 25, 2008
    Same issue with mine. The lens extends, beeps, shuts down.
  • Anonymous Jun 14, 2008
    Any time I turn it on the light just goes on for 3 seconds than makes a beep sound than turns off.
    What do I do.
  • exton21 Feb 06, 2009
    I have the same problem with the Pentax S41, bought secondhand and has not been dropped ect, press on off button, lens extends, screen activates 4 beeps, then the lens retracts and the camera switches off.
    Any ideas anyone
  • joehurst May 22, 2009
    I have a optio S4i digital camera when i try to turn on my camera
    the light stays green for about 5 seconds then turns off
    nothing else moves
    can you help me.thank you.
Your problem is part of the dreaded A90 error code these cameras get. My camera had this last year and updated firmware cured it till this month when my wife let the battery go dead and the problem returned, but firmware update won't fix it this time around.Go to Pentax site and download new firmware for camera. Follow instructions that come from Pentax on the download to install software. Its pretty easy. These are cheap cameras as far as Pentax is concerned. They only work for about 2 years, based on other users and my experience. Good luck
Posted on Mar 02, 2008
6ya staff
SOURCE:
My camera pentax optio wp wont turn on. though is
If possible, check the charger output or the charge status of the batteries with a voltmeter. That will narrow the field for you. If the charger and batteries seem OK, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 21, 2009 | Pentax Optio E40 Digital Camera
Where to find installation software for my pantax optio s4i
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
May 11, 2009 | Pentax Optio S4i Digital Camera
Pentax S5i
I have lost my cd for my optio s5i pentax camera and have a new laptop how can I get another cd or download software so I can transfer photos onto my laptop
Jan 28, 2008 | Pentax Optio S5i Digital Camera
Connecting OPtio S4i to PC
After formatting my PC to upgrade it I've been unable to install the USB driver software to save pictures from my Tentax OPtio S4i to my PC.
My computer isn't recognising my camera when I plug it into the USB port.
When I've tried to install the Driver using the disk I got with my camera, at the stage where it asks me to MODIFY REPAIR or REMOVE, the software I get the following showing up on display boxes:
Aug 19, 2007 | Pentax Optio S4i Digital Camera
Loss of button functionality
Try loading this Firmware update...
http://www.pentaximaging.com/customer_care/show_firmware?firmId=1020
I was having the same problems and my camera works great now after loading the update.
Jul 04, 2007 | Pentax Optio S4i Digital Camera
Optio S4i - Freezing problem on green switch
I don't know for sure, but it sounds like it could be a memory card problem. Have you tried it with another card or no card at all? My S4i froze up completely from a bad sd card. The green power button would light up, but nothing else would happen. Pentax recommends Lexar or Panasonic sd cards from what I have heard. My new Lexar card hasn't had any issues.
Sep 08, 2005 | Pentax Optio S4i Digital Camera
Problem in my Pentax s4i
This happens if you go from movie mode into green mode. If this wasn't the case with your freeze, it could be a problem with the memory card.
Option S4i > 512MB SD card Possible?
I have a friend who had an s4i with a 1gig sd card with no problems.
Aug 30, 2005 | Pentax Optio S4i Digital Camera
Pentax Optio S4i Digital Camera Logo
387 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
