Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Blue vertical lines
I have blue vertical lines that go from top to bottom across the whole width of the tv about 1/4 inch wide. can still see the picture behind it. any idea what would cause this.
  • 2 more comments
  • smclaren76 Jan 25, 2008
    is this the only thing that would cause this?
  • Anonymous Apr 11, 2008
    I just had my optic block changed. It worked fine for a day, I turned it on this morning and there are green vertical line running the whole width of the tv. Could they have installed a bad optic block?
  • DRIVERDOG3 Jun 16, 2008
    I HAVE MULTI COLORED VERTICAL LINES RUNNING THE ENTIRE WIDTH OF HE SCREEN. BLUES , REDS, GREENS. THE UNIT DOSEN'T RESPOND TO ANY VIDEO FUNCTION. I TRIED RESETTING TO FACTORY DEFAULT WITH NO SUCCESS. THE UNIT IS ONLY 2 YEARS OLD.
  • Anonymous Mar 21, 2014
    Eprom was upgraded in 2009. The line looks like a glare and can only see it sometimes
  • 3 Answers
Yes...your light engine/optical block is shot... 1500 dollars.
Posted on Jan 25, 2008
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Panasonic plasma tv th42px8ob 2 inche vertical line showing
do the proper isolation proceedure and try unhooking the Su from the SC board to see if you then get a normal picture all the way across the bottom half of the screen? I am assuming the Vertcal extends extends all the way from top to the bottom of the screen?
Aug 06, 2012 | Panasonic Televison & Video
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
No picture on screen
No,Ur vertical/horizontal IC is shorted or cold soldiers.Could be the parts that support the IC is also.
Aug 19, 2009 | Sanyo DS27820 27" TV
Red line across top/blue line across bottom of screen
Adjust your convergence. Under menu I think its the last choice at the bottom of settings or picture menu
May 05, 2009 | Sony KDF-50E2000 50" HDTV
TV picture won't open.
The vertical sync circuit has gone bad...you'll have to have it repaired if you want to keep it
Jan 03, 2009 | Televison & Video
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
322 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
