Canon NP-6035 persistent E002
I get a friendly error "E002 Switch the power OFF and ON again." Following those instructions yields nothing. It's a bit of an endless loop at this point. Any advice on this one is greatly appreciated! I keep getting Error Code E002. It tells me to turn machine off and on again but the same message keeps coming up. How do I fix this?
  • 1 more comment
  • Alberto Ramirez Apr 09, 2008
    I have a 6035 also but I cant find the switch. Help
    Thanks
  • myinspiratio Dec 30, 2008
    When I turn on the copier it , tells me to turn off and then on again with the erro E002 . Do any one knows what going on with this machine. If you do please help me. I run a small Ministry and its my work. Help !!!!!
  • rafaelabrego Jan 10, 2009
    yo tengo el mismo y no puedo encontrar el interruptor tampoco
    Problem Solver:
  • 13 Answers
E002 error normally indicates that the heater {fuser} is off
to clear that in most canon models there is a small press switch is to be activated to reset the error
at the rear right side of machine there is a small cover take it out and look for that small black button, press it while or immediately after switching the machine ON , switch OFF and ON again
if the error still exist may a real damage in fuser e.g. blown thermo fuse or lamp
Posted on Feb 02, 2008
2 Suggested Answers
  • 62 Answers
SOURCE: Canon NP-6035 persistent E002
There is a heating problem connected to the fuser. It could be the heater lamp or thermal switches. Lamp is most likely.
Posted on Aug 27, 2007
Set duplexingunit canon NP 6035
codes e002 et e004 canon copier np6035
Jul 24, 2012 | Canon NP 6035 Copier
Canon NP 6035 Error code &switch on and off
What is the error code is displayed on the control panel???
Oct 01, 2011 | Canon NP 6035 Copier
My mechine display an error e002.
Error # 0002 indicates "Fuser temperature not rising at correct pace. Same possibilities as E000"
Error #000 refer to a number of possibilities "Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller
Replace the Fuser Roller also known as the Pressure Roller or Upper Roller to resolve your problem.
Mar 08, 2011 | Canon NP 6035 Copier
CANON NP 6035 The error code E224
Bagaimana cara mengatasi error e224 ???
Salam Sukses By KBG.
Feb 27, 2011 | Canon NP 6035 Copier
It displays error code e002
its your fuser section,check heater lamp,thermofuse and thermistor if it not worn out.
Dec 20, 2010 | Canon NP 6035 Copier
My Canon copy NP 6035 if in turn it does not want to live. sound briefly returned to off himself. how the solution. thanks.
The copier comes ON then it turns it's self Off , Correct? Turn the copier back ON and hold the Main power switch ON and the display will show a error code. Read it and let the copier turn Off. You most likely have a dead AC short. The error code maybe a E0202 or E000 . One of the lamps are blown or broken and shorting out. You probly have a blown scanning Lamp or fuse. You may also, have a shorted out Scanner Power Cable. It's black and powers the scanner lamp > sometimes the cable crack's and exposes the AC wire. That is a fun job. It may just be a blown fuser lamp.. Good Luck
Sep 06, 2010 | Canon NP 6035 Copier
I NEED TO DOWNLOAD CANON NP 6035 MANUAL
Send your email adress!
But I think that the best way is to buy new one digital age.Its not worthed to waste your time on this machine.
In service manual wont find nothing abaout your problem description.
Check dc controller, power supply, check fixing assy...
Jun 22, 2010 | Canon NP 6035 Copier
Canon np 6035 saya tak menyala tombol start di posisikan on mati sekitar 5 detik mati sendiri
Mesin canon NP 6035 kalau dinyalakan keluar kode E 224,kenapa yaa????mohon bantuanx....thanks.....
Oct 01, 2009 | Canon NP 6035 Copier
Code error E002// Icanot reset it
try this open the front cover on the left hand side try to look for small hole on the hole insert paper clip and press a little bit you will see asterisk on the lcd panel then press *4* then browse for resetting error then you can reset fixing error(E002)
Jul 11, 2009 | Canon NP 6035 Copier
Aug 27, 2007 | Canon NP 6035 Copier
616 people viewed this question
k24674
jasbo
jasbo
