Question about HP Thin Client t5135 Eden 400MHz/64MB Flash/128MB RAM, ThinConnect (RK271AA#ABA) Network Terminal
Thin Client State
Is there a way to change your Thin Client State back to local mode once you have changed it (other then flashing it)?
  • Pascal Willemen
    Pascal Willemen May 11, 2010
    What do you mean with local mode?
    Greetings,
    DarkNeogen.
    Scholar:
  • 79 Answers
Press and hold F9 whilst starting-up.
Once the clicks have stopped, repeatedly press F9 until the grey screen with the "X" mouse pointer is revealed - you'll know then that it's worked!
You may have to be persistent and attempt several times.
Posted on May 29, 2008
I had the same issue. While reading this page, I was just on the phone to my other half nagging in my ear and accidently forget to hold F9 until the beeps stopped. I was just continually pressing F9 and it fixed the issue. Thanks Heaps.
Posted on Jul 13, 2008
Samung chromebook xe303c12 turns on to white screen chrome screen then turns black with power light on
Here is a trick you can use: You can put the Chromebook into Developer Mode, then once it is in Developer Mode you can switch it back into normal mode and it should totally wipe the Chromebook without requiring any USB flash drive or any SD flash card etc.
But remember that just like a Powerwash or a USB ChromeOS restore, this process will wipe all local files you have stored on your Chromebook's SSD.
best of luck ! And be certain to return to let us know if this helped.
-JW
PS: Remember that when using a Chromebook you should never store important files locally on the SSD HardDiskDrive shelf; Instead, store them in your Google Drive or if you must store them locally use something like flash storage media. A Powerwash or a switching into Developer Mode will wipe all SSD local files.
https://support.google.com/chrome/a/answer/1360642?hl=en for Samsung Chromebook XE303C12-A01
  1. Press ESC + Samsung Chromebook Refresh key + POWER. The screen displays a yellow exclamation point (!).
  2. Press CTRL + D to begin dev mode, then ENTER. The screen displays a red exclamation point.
  3. Press CTRL + D, then ENTER. The Chromebook deletes its local data, returning to its initial state. The deletion takes approximately 15 minutes.
  4. When the transaction completes, press the spacebar, then press ENTER to return to verified mode.
Jan 21, 2014 | Samsung Chromebook Series 3 XE303C12
Thin client
It is a network terminal, you don't have to install anything on it...
... but you need an application server to run on your LAN to use it !
Oct 13, 2013 | Microsoft VXL Itona TC4421-XP Thin Client...
My wyse laptop turns on but my screen stays black
try undo things..if problem solved then,try use different cards
May 17, 2012 | WYSE Winterm V90LE Thin Client - Thin...
I am looking for thin client with ambeded processer with 4 GB Ram please tell me about thin client configaration
Hi DB_minse. Check out the Devon IT line of thin clients here: http://www.devonit.com/hardware - I believe the TC5c units can come as 4GB ram- and as far as I know they are a very good brand!
Feb 14, 2011 | WYSE R90L Thin Client AMD Sempron 150 GHz ...
Need to change password but i dont know the old one
i advise you to get on eby and type in Windows Password in the search and get you a copy of any of the windows password reset discs there cheap and it will solve your problem
Dec 08, 2009 | WYSE Winterm V90LE Thin Client - Thin...
Low Disk space on Neoware e140 (Windows XP Embedded)
Yes, you can disable this message via the registry editor.
Click start, then Run. In the boxy type regedit. Press enter. (In Vista, click start, then in the search box, type regedit)
Navigate to the folder HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\
Explorer
Click on NoLowDiskSpaceChecks and change the value from 0 to 1. If the entry doesn't exist, click on new DWORD value, type in NoLowDiskSpaceChecks and enter 1.
Navigate to the folder HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\
Explorer and do the same thing there.
Exit out of the registry. Your computer may need to be rebooted in order for the changes to take effect.
Thanks and please take a moment to rate this solution as fixya.
Mar 02, 2009 | Neoware Systems e140 Thin Client - Thin...
Neoware ca5
True, even if you reflash the system to bring it to a fresh state, it will still need a server to do anything reasonable.
Head over to http://www.neowareftp.com/ and click on the "Tech Support" link. A password dialog box will show up: [since it may violate TOS here I won't post that info, but it's readily available on the web.] Once in, click on the FlashRecovery link, then pick the flash that relates to your machine - CA5's are usually the CE versions. Download the file.
Now, this program will work on XP systems. Install the program and follow the directions. You'll need either a cheap hub, switch, or a simple crossover ethernet cable. Hook the thin client to one end, your PC to the other, run the tftpd32 program as described in the documentation, set up the thin client per documentation.
If all is done right, your thin client will grab an ip address from the tftpd32 program and you'll see the reflash menu. Pick the number corresponding to the proper reflash, and watch the machines do the rest.
When it's done, you'll have a pristine OS on your device.
now understand, these are made primarily for accessing terminal servers in businesses or schools or hospitals, so it may be useless unless you just want to do some primative web surfing (the CE version has an embedded version of IE5, no java, no flash, and probably no room to put it on that 16meg flash disk.)
But if you buy these devices for a accessing terminal servers, this will give you a clean client.
Jan 21, 2008 | Neoware Systems c50 Thin Client Network...
HP Thin Client t5135 Eden 400MHz/64MB Flash/128MB RAM,  ThinConnect (RK271AA#ABA) Network Terminal Logo
364 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
