Panamax 1000+ I have a panamax 1000+. It recently "clicked" and now when I plug it in all that happens is that there is a little quick buzz, like a relay, and the red overvoltage light on the front lights up.  I am wondering if there is a manual reset or a fuse that needs replacement or what. Please advise. Thanks in advance. Charlie pharquarx@sbcglobal.net
  • mousetrap46 Apr 22, 2009
    When fist plugged in one relay clicks in briefly and then shuts off with only the overvoltage light on.
    Problem Solver:
  • 13 Answers
Can you please advise what is the panamax 1000 the only panamax I now is for headaches!
Posted on Mar 13, 2008
I had the same problem with the overvoltage light coming on in error right after powering up my Panamax 1000+. In fact I have two Panamax 1000+ that developed this problem so it seems to be a common problem with the Panamax 1000+. However I was playing around with one of them turning power on and off and it started working and I've been leaving it on all of the time and it's been working fine now for quite awhile now. This got me to thinking that the problem was probably a bad electrolytic capacitor which can deteriorate due to the aging or long periods of non use. Electrolytic capacitors are usually the first components to fail in older electronic equipent. I looked inside and found there were only four electrolytic capacitors so I decided to change all four in the one that wasn't working and showing a continous overvoltage light right after power up. After changing all four electrolytic caps, I powered it up and it is now working normal again with no overvoltage light anymore when powering up. I bought the four electrolytic caps for about about $7 at Fry's Electronics. You will need two 4.7uf 50V, one 220uf 35V, and one 22uf 25V. Make sure the caps you buy have both leads on the same side and one lead is marked negative. If you have soldering skills you can change these yourself being careful to make sure the polarity is correct as the negative side will be marked "--" or have a black bar on the negative side. Otherwise you could take it to a repair shop and have them change the caps for you.
Posted on Feb 06, 2011
  • Vincent Poy
    Vincent Poy Oct 05, 2014
    Thanks for the pointer, do you know what brand and product line the replacement caps were? Also, how do you get the circuit board out as I noticed to open the thing, you basically take the 4 screws at where the rubber feet is.
Im having the same problem with mine...trying to figure this out..
Posted on Aug 23, 2009
    Problem Solver:
  • 7 Answers
The problem is due to a poorly engineered power supply. The power supply puts excessive ripple on filter cap C8 - a 220uf 35V cap - and runs it warm enough so it has a limited life. Replacing C8 will fix the problem for a few years. There's also a dropping resistor, 100 ohm, that runs quite warm with 9 volts of AV across it. But it seems to stand up to the abuse, even though it looks like a 1/2 watt resistor.
Posted on Dec 28, 2011
  • 2 more comments
  • Vincent Poy
    Seems like the original cap is rated 85C, would replacing it with a higher voltage 105C cap work better or should the capacitance be increased as well? Since electricity is 120VAC, what is the 35V actually used for?
  • Anonymous Jun 05, 2017
    Would replacing C8 with a 220uf 50V capacitor help it to last longer?
  • William Grady
    William Grady Jun 05, 2017
    I have three of these Panamax 1000+. I had replaced the caps in two of them and they are still working fine but today my third one stopped working; only light that is on is the red over voltage light. I found some Panasonic 220uf 63V 105C capacitors for sale on Ebay paid $6 for six. I'm hoping the higher voltage rating of 63V and higher 105C will make them last longer. Just do a search for 220uf 63V and you will find them. Per Alan Peterman's suggestion I'm just going to change C8 first. Before I had changed the 4.7uf, 22uf, and 220uf as I wasn't sure which one was causing the problem.
  • William Grady
    Vincent, you probably have gotten your Panamax 1000+ fixed by now but I had another one of mine go bad today; only have red over voltage light showing on the front panel. I found some Panasonic 220uf 63V 105C caps for sale on Ebay for about $6 for six. If you are still using your Panamax 1000+ you might want to order some of these just in case you need to replace C8 in the future. I think the higher 63V voltage rating and higher 105C temperature rating should help to make it last longer. Just do a search for 220uf 63V at Ebay and you will find them.
How do I install a capacitor on ahid relay will 60volt capacitor be okay
The HID kit shouldn't require a separate capacitor. It should be fine with the one that's in the little box that the harness plugs into, that came with your kit. Which relay are you referring to, that is buzzing?
Oct 31, 2014 | Pyle 9005 8000K Single Beam HID Xenon...
Whirlpool refrigerator (purchased 9-6-11) Model # WRT579SMYW00 Serial # VS 13049911 Making buzzing sound when plugged into electric. Stops when unplugged.
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 21, 2011 | Whirlpool Refrigerators
Amana side by side refridg/freezer. Freezer not freezing, everything defrosted. Getting a buzzing noise then a click, then buzzing stops. Compressor overload?
Hi!
Leo Ponder
Aug 20, 2011 | Amana ABB1927DE Bottom Freezer...
My fridge stopped cooling properly today. For the last two days, I've been hearing a buzzing, about 15 seconds long, every 10 minutes or so. I didn't locate it until my frozen goods started...
Hi!
Leo Ponder
Aug 16, 2011 | Maytag MSD2756G Side by Side Refrigerator
Ge refridgerator model sts16abserww, stopped cooling, down at the compressor I hear a slight click then wait a few seconds and hear another click (NO buzz between clicks), then wait a few minutes and the...
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
Thats what is happening with yours
Leo Ponder
Aug 14, 2011 | Refrigerators
I have an amana abb1924des. A few days ago it stopped cooling. It was making click and buzzing sound. I changed the overload relay and capacitor. The refrigerator started working again for a few hours. The...
Hi there
Only bad news I'm afraid, the click and buzzing sound is a seized compressor, you said changed the relay and capacitor, good idea but often a seized compressor will come free if it cools for a while, unfortunately it will normally seize again fairly quickly. A job for the tech guy.
Best wishes
Gordon
Apr 17, 2011 | Refrigerators
Whirlpool upright freezer making buzzing noise and not working
I had a similar problem yesterday. I woke up and the freezer was not working anymore. It would make a buzzing noise and then it would click and shut off. I looked online for some possible solutions. Here is what I did:
I unplugged the fridge. I pulled it out and took off the cardboard backing. I used an air compressor to blow out all of the dust and dirt that had accumulated on the condenser coils. A shop-vac just wasn't powerful enough to pull out all of the dust/dirt. After that, I plugged it back in....and the same thing was happening. It would buzz, and then it would click off. I figured out that the "click" was coming from a starter relay (a small plastic piece attached to the big black compressor). I detached the plug from the relay and then detached the relay from the compressor. The relay was burned out. It turns out this is a common problem with the relay. I replaced the relay for $50 (from an appliance parts store) and put the whole thing back together in about 10 minutes.
I plugged the fridge back in and the compressor started, and now the freezer works better than other. I saved about $400 doing it myself, all in about one hour. And better yet, my wife was very impressed. Not bad for a doctor.
Jun 29, 2009 | Whirlpool 20 cu. ft. / 566 liter Upright...
I just replaced the glow plug relay dur to hard starting
HAVE YOU REPLACED ALL YOUR GLOW PLUGS RECENTLY? EVEN THOUGH THE GLOW PLUGS APEAR TO BE WORKING I FIND WITH AGE THEY NO LONGER HEAT UP QUICKLY ENOUGH BEFORE CONTROLER TIMES OUT. THEREFOR CREATES A HARD OR NO START CONDITION.
Jan 17, 2009 | 1992 Ford F250
Buzzing noise coming from under passenger side dashboard
Sorry but I would need to hear this to ascertain what it might be.
Jun 22, 2017 | 2000 Saturn SL
Panamax 5300 PM and APC UPS
The outlet that you are plugging your Flat Panel television into might have more/less voltage then what It requires/accepts. If you try to plug it into another outlet, The problem should be fixed.
Hope this Helped. - Evolution
Jul 14, 2008 | Panamax Televison & Video
Computers & Internet Logo
2,786 people viewed this question
David Payne
David Payne
