Computers & Internet Logo
Posted on Jan 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to attach seperate speakers to my acer monitor but i cant find any holes at the back of the monitor to do this
Anonymous
Level 3:
Genius:
  • Master 1,067 Answers
  • Posted on Jan 25, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1067
Questions
0
Helped
419578
Points
2624
U have to do it from sound card out puts buy new set with woofer and plug in back of computer sound out unplug others
1helpful
Remove stand from monitor
there will be screws on the back which will allow you to remove the stand, then on the back of the monitor their should be 4 screw holes, use these to attach a a flat plate wall bracket to it.
but if you can't remove the stand, then put a clap speaker bracket on the wall & just clap the base of the monitor, as this type of bracket can be adjusted both in & out & up & down.
1helpful
Replaced ph monitor with aoc,no sound. do I need seperate speaker/s? my hp had port for sound cable from computer,aoc does not.?.
attach speaker on to the green port on the back of the cpu, then play sound, before this also check whether the sound driver is installed or not in device manager
Jul 29, 2011 • AOC Monitor
2helpful
3answers
I have no sound on my Acer monitor
ACER X223W have no speakers build in. You must use exstra speakers or a headset.
2helpful
2answers
Recently, I purchased an Acer H233H LCD Monitor with the HP e9180f Desktop. However, the built-in stereo speakers in the monitor are not working. The sound card in the desktop is fine, as headphones and my...
Try installing the Acer Monitor software and disabling the the desktop sound card under 'My Computer'. 'Properties','Hardware Devices'.
Let me know if you need help doing this, or need more help.
No sound through external speakers
Although some monitors have built in speakers, most people have stand alone speakers. If the old monitor had built in speakers and now it is unplugged you won't hear sound. Even if the speaker cable is still plugged into the sound output on the back of your computer, the monitor must be plugged into an electrical outlet to have power.
I'd recommend buying a new set of external speakers if this is the situation.
If you never had speakers built into the monitor then normally changing monitors would make no difference whatever. The only explanation that makes sense under those conditions is that in the process of replacing the monitor, you dislodged the speaker jack from the sound output on the back of the computer.
Make sure your external speakers have electrical power plugged in, the power is on (green light on at least one speaker lights up) and the volume on the speakers is at least half way up.
Unplug the speaker from whatever hole it is plugged into and plug it firmly back in and test sound.
If still no sound other than some static on the speakers, try every single hole on the back of the computer that the jack will fit properly and test for sound.
Let me know if you have further questions.
Honest1abe
3helpful
2answers
I have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Speaker problems
Check to see if its plugged into the GREEN jack on the back of you computer?
Hope thid helps. Bud
1helpful
Speaker trouble
There has to be separate cord for the speakers. Look for an Audio port on the back of the monitor. It looks like a small hole and should be marked "Audio". Connect this to the Audio out on the PC using a cable with two Audio jacks at both ends.
Acer V223w monitor
Hello Cricket,
Sound/Speakers that are built into monitors, typically are pretty poor. I suggest purchasing some speaker from your local electronics store, or www.newegg.com. (New Egg has very good deals on computers and accessories, like speakers.) Here is a link to New Egg's speaker section. http://www.newegg.com/Store/SubCategory.aspx?SubCategory=60&name=Speakers
On the back of your computer, you will see little holes (3.5mm). They are usually color coded, Green is the typical speaker output jack/hole/port. When you buy your speakers, you will plug the cable with Green Head Plug (3.5mm) that is attached to your speakers, into this Green Jack. Turn them on, and you should have audio! Now, if the volume seems weak, you can double click the speaker at the bottom right of your Start Bar in windows. It looks like a little silver circle. This is your volume control There are multiple slide bars to adjust your audio.
Good Luck!
Speakers
You will need a seperate audio cale with green plugs on both sides, 3.5mm jacks, one from the screen into the green port on your computer.
Grand Canyon Tech
Grand Canyon Tech
