Question about Frigidaire GLEQ2152ES Electric Dryer
Drum Stuck I purchased my dryer in March of 2006. The drum will not move. I have taken off panels and checked to motor and the belt. The area behind the drum is difficult to access. It appears to have leaked some cream colored oil in the back outside of the drum area. I have had 3 service people cancel. One is due out next week. I have been without a dryer for over a week. Any help would be appreciated.
  • 1 more comment
  • amyjoness Jan 25, 2008
    While researching bearings, I've noticed it commonly associated with screeching. I had not noticed any noises prior to the problem.
    Thanks in advance,
    Amy
    Glass in the door
  • robert samples May 11, 2010
    either you have something jamming the tub or there bearing has failed give me the model number and are you going to repair it yourself
I do appreciate that you are trying to help me. I have the back service panel off already ( the bottom front and the top also) The belt wraps around the drum and the wheel that it goes on is accessible from the back. I need to know what will be requiredto fix the problem. If parts need to be ordered, I will wait until the service man can come out, or I will repair it when the part comes in. I am not sure we are discussing the same dryer type.
Posted on Jan 25, 2008
    President:
  • 1,314 Answers
Don't rate me till we are done first a word of caution sheet metal is sharp and can cut you now is this model drier have a solid door or glass in the door
  • robert samples Jan 25, 2008
    ok facing the drier get a putty knife and come over from each edge about 2-3inches insert the putty knife and you will feel a spring depress lift the top as you push in on the spring now have the drier pulled out from the wall a little bit and when you get the top up lay it against the wall.now if you look on the inside on the front panel you will see two 5/16 in screws remove these then kind of jerk back on the front panel to dislodges the retaining clips and the front will come off un plug the wires from the door switch and remember how they go back .then remove the belt from the motor pulley standing to the side of the drier pull up on the belt with one hand and the other on the drum front depending on the condition of the rear bearing this can be a little difficult so be careful and remember what i said about sheet metal being sharp and of course un plug the unit before you start safety first let me know what you find if you get stuck just reply ill be here
Frigidaire GLEQ2152ES Electric Dryer. I have checked the dryer pretty thoroughly and can't find anything jamming. I believe it is a bearing. Something on page two of the manual. If I can, I will repair it myself. That area has been diffucult to access.
Thank you
Moved dryer abour 5ft to replaced tile on floor.went to use dryer today,makes a swevere grinding sound.almost like the drum is off track.immediately shut off.rotated drum by hand grinding sound is very...
Your drum rollers are in need of lubrication or replacement.
I have included a link to the pictures of the routing of the belt.
http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Jan 23, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
My dryer is about 3 years old suddenly won't dry a load in one cycle. Recently moved and moved the dryer with. Haven't had any problems.
Installing the belt
facing down.
Please RATE me
Jan 15, 2011 | Kenmore 500 6952 Dryer
Maytag neptune MDE4000AYW dryer -- will not start -- humming noise when pushing "Start" button.
Your drum belt is broken, the motor is running, but the drum is not turning.
I also included a link to show the route of the belt
Installing the belt
facing down.
Please RATE me
Jan 03, 2011 | Dryers
How do i remove motor from whirlpool dryer model LER5620KQ1
You will follow these instructions for replacing the belt, it will get you to the motor.
Installing the belt
facing down.
Please RATE me
Dec 27, 2010 | Whirlpool LER5636P Electric Dryer
Hotpoint tumble dryer VTD001 (31330) had snapped drum belt with drum not turning but motor making humming sound. Have replaced belt but still not working. Any advice welcome.
Installing the belt
facing down.
Please RATE me
Dec 27, 2010 | Hotpoint Dryers
How to fit a belt for a indesit dryer ISL70c
Hi
Thanks for using FixYa. Please follow the step-by-step procedure---
1. Remove the front panel.
2. Reach underneath drum and behind motor to locate idler pulley. Push idler pulley to left to release drum belt tension. Remove the belt from the motor pulley.
3. Remove the drum and belt from the cabinet.
1-- Prepare for replacing the dryer belt by lifting the lint-screen cover on the top of the dryer. Then remove the lint screen. Skip this step if your lint screen is inside the door. Remove the 2 Phillips screws inside the door instead.
2-- After removing the lint screen, lift the cover and remove the screws that hold the lint-screen housing to the dryer top.
3-- Slide a putty knife between the front panel and the top near a corner. Lift the corner and repeat on the other side.
4-- To remove the lower panel, insert the putty knife between the panel and each side. Then twist to release clip.
5-- Place a few wood blocks under the drum. These support the drum when the front panel is moved away from the sides.
6-- Loosen the screws that secure the bottom of the front panel to the dryer sides. Do not completely remove the screws.
7-- Remove the screws that secure the front panel to the dryer sides at the top. These are accessed from the inside of the cabinet.
8-- Lean the front panel away from the sides and slip the new dryer belt over the drum. Then re-secure the front panel.
9-- Check that the lip on the back of the dryer drum fits properly against the seal on the rear bulkhead of the dryer.
10-- Locate the original position of the old belt, and slip the new belt in place. Keep the grooved side of the belt down.
11-- Push the idler pulley toward the motor and loop the doubled-up belt around the idler pulley. Slip belt around motor pulley.
12-- Rotate the drum counterclockwise a few turns to check belt tracking. Then replace remaining components and test run.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 20, 2010 | Washing Machines
I need to replace the belt in my GLER341AS2 model Frigidaire dryer. How do i open up the dryer to do so?
Unplug the dryer and using a 1/2 inch pait scraper locate the spring loded clips holding the top down to the front of the cabnet. They are located about one to two inches from the front corners of the dryer.
Lift the top and rest it on the wall behind the dryer.
Looking inside the dryer locate the screws holding the front panel to the cabnet and remove the screws.
Mark the wires to the door switch and remove.
Go behind the dryer and remove the small rear panel near the bottom of the dryer.Observe how the belt is attached to the pulleys.Release the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go to the front of the dryer and grab the belt on the top of the dryer drum. Holding the belt lift the drum straight out holding the drum with the belt.
Check to see if all the rollers are in good shape and rotate freeley. Oil if needed.
Check to see if the teflon gliders located on the front panel that hold the drum are in good shape. Replace if needed.
Vaccum the inside of the dryer.
Put the new belt over the drum and line the drum up and install back into the dryer.
Put the front panel back on and reinstall the two screws.
Replace the door switch wires.
Make sure the grooves on the belt are flat to the dryer drum
Put the top down and go behind the dryer'
Locate the belt.
Pinch the belt and insert it under the tention pulley and slide it over the motor pulley. Make sure the belt is positioned straight and located where the old belt was positioned on the drum.
Jan 03, 2010 | Frigidaire GLER341A Electric Dryer
Dryer belt broke on my kenmore series 80
With the front cabinet panel off, place the drum against the back and on the rear rollers. The roller on the right will sometimes move toward the rear so reach from underneath and pull it forward. The rollers should sit in the groove. The drum will tilt forward but shouldn't fall off. Route the belt around drum, pulley and motor. Tilt the drum back and support it while placing the front panel back onto it's hooks. With the front panel on (don't screw it on yet), rotate the drum by hand to make sure the seal is not kinked and the belt won't slide off the pulley or motor. If all is well screw in the front panel and re-assemble the rest.
Feb 16, 2009 | Kenmore 62622 Electric Dryer
GE Electric Dryer Older model
it could be the motor capacitor. to check, turn on and carefully give the drum a push in the direction of rotation. if the drum picks up speed and goea ok, then the motor capacitor is faulty. cheap part
Jun 26, 2008 | Dryers
Estate Dryer Model TEDS680EQ1
check the thermostats and see if your belt is still there if not put a new belt in
Mar 25, 2008 | Estate TEDS740JQ Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
73 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
