Question about Panasonic DMR-ES25 DVD Recorder
I can't play any DVD's. It keeps saying cannot read.
It was working fine until I tried to record a tv show onto DVD+RW format (which didn't work). Now every time I put in a dvd (even movies that I just bought), it says "Cannot read, please check the disk" on the tv and on the dvd player it says "noREAD". I've tried just about every option there is on the remote and can't figure it out.
  • 8 more comments
  • Anonymous Jan 29, 2008
    I tried to clean the lens, but I still get the same error. I called the Panasonic support and they are sending me a firmware upgrade. Hopefully that works....we'll see.
    Same problem. It played DVD just fine until I tried to record a few shows (that didn't work but it may have been an error on my part). I was not able to record any shows AND now it will not recognize any disk. It just says "no disk" no matter which disk I put in.
  • JerPlum May 21, 2008
    DVD worked fine until we tried to play a DVD that had been burned on our new PC. It wouldn't read that DVD, and now will not read any DVDs. Have tried DVDs that we have watched several times before. This is very disappointing for a Panasonic product. I will contact Panasonic about the firward upgrade discussed above.
  • kvntms Sep 29, 2008
    Same problem.  I have a DMR-es25 and until this morning it worked fine.  Tried to record from the TV and after formatting the new disk (DVD+R) it locked up.  Now it will not read any disk - even the one it formatted.  I have tried to clean the lens without success.
    Any suggestions?
  • TVbobtv Oct 11, 2008
    Drive makes movement like sounds, then say "No Read" with ever kind of disc , upgrade CD from panasonic does not work since DVD can not read CD also!
    Cleaning lens did ****.
    Bob
  • jsobotka Dec 12, 2008
    I have had zero problems with this box until now. I tried to record Cinderella from an old VHS tape for my kids... apparently, it had macrovision protection... the Panasonic reported that it was copyrighted, flashed a message up on the screen for such a short time that I didn't get to read it. Immediately after that, when I put in a disc, it makes a lower pitched noise after the normal noises during reading, and reports that it can't read the disc. This happens for all discs. Why would Panasonic disable my entire DVD recorder due to macrovision protection? That's a pretty stiff penalty for recording a kid's moving off a VCR.
  • dwastchak Jan 02, 2009
    This just happened to me the other day. Panasonic tech support will fix it for $130. They'll even send me a shipping label to get it to them.
    They never mentioned a firmware upgrade. Did anyone receive that and try it??
    I'd prefer applying a firmware update vs. shipping it to them for $130.
    thanks
  • Anonymous Mar 06, 2009
    I have the same problem. It actually happened to me while I was recording. Now every time I try to play it says nodisk
  • Anonymous Mar 26, 2009
    I have the same problem. Any body find a solution?
  • MavSlate May 20, 2009
    I have the same problem. Has anyone fixed or just tossed the unit.
    President:
  • 4,402 Answers
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Posted on Jan 25, 2008
6ya staff
SOURCE:
What fix to apply to HL-DT-ST DVD+-RW GWA4164B in Dell Dimension E310 so it can read/play a dvd movie?
Try the following:
1. Go to the Dell.com support site and be sure you have the latest updates for your computer's operating system and the DVD drive, especially the DVD drive's drivers BIOS.
2. Make sure you have the software to play the movie, like Sonic, Windows Media Player, Power DVD, Quicktime, etc. and be sure they are the latest versions.
3. Depending on the movie format, not all DVD drives will play all DVDs. The most common discs are DVD-R and DVD+R and file types like *.avi, *.mpeg, *.mp4, *.mov and then commercial formats. Also try the movie in another machine or DVD player and see what happens.
Jan 13, 2012 | Dell Dimension E310 PC Desktop
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I was wondering if you could help us with our DVD recorder. Its a Toshiba DVD Recorder Model: D-R18DTKB and up until recently has been in good working order. A while back I bought some Sony+RW...
Hi Tony
Although I am a member of this site I came across your post while searching Google for answers to the same issues as you are having.
From what you say and what I have tried I can only put fault with the DVD recorder itself and probably the LASER.
This thing just seems to hate reading recorded media of almost any format including those which it's stickered front panel boasts about. It also doesn't leave you with many other options as there is no USB port either.
I dont use the unit to record or the Freeview facility and never have as we have Sky+ and no TV ariel.
I bought it for the varied formats of video it says it can play but out of 6 different formats that I recorded onto DVD with my PC (and I am an advanced user and work in I.T) it only played back one and badly which was a mpeg-1.
I put the same 6 disks into my sons (apparantly DVD only) player bought from ASDA for £15 and it played 4 of them perfectly as good as the originals!
Logically this would suggest this model is a Lemon. I just hope your not a £130 light lemon as I am!
Oct 27, 2010 | Televison & Video
Anything I have recorded onto DVD from TV wont play on any other machines. It will only play on this machine I recorded on. It is the same make and model mentioned here.
If you're not using DVD+RW blanks (VERBATIM work fine), then try them. DVD-RW blanks will not play on any machine but the one that recorded the disk (according to the manual.)
Nov 24, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
MY PIONEER DVD RECORDER WILL NOT RECORD BUT PLAYS
hi have you tried to format the discs this sometimes work check your manual and it should tell you how to format
Dec 15, 2008 | Televison & Video
Is my DVD burner to blame for this problem?
with DVD Cloner,It copy the DVD to dvd, burn movies to DVD-R/RW and DVD + R / RW,rip one DVD9 into two DVD5,or compress one DVD9 into one DVD5 ,or compress a DVD9 into a DVD5 format.free download http://www.eztoosoft.com/eztoo-dvd-copy.html step by step guidance ========================= http://www.eztoosoft.com/eztoo-dvd-copy.html#guide,with DVD Cloner,It copy the DVD to dvd, burn movies to DVD-R/RW and DVD + R / RW,rip one DVD9 into two DVD5,or compress one DVD9 into one DVD5 ,or compress a DVD9 into a DVD5 format.free download http://www.eztoosoft.com/eztoo-dvd-copy.html step by step guidance ========================= http://www.eztoosoft.com/eztoo-dvd-copy.html#guide
Oct 21, 2008 | Optorite DD1603 DVD±RW Dual Layer...
Some blank DVD+R discs will not read on my DVD player
The JVC DR-MV1S DVD Recorder / VCR Combo does not suppport DVD+R, only DVD-R, -RW etc.
At least mine only supports these formats, as when I first bought mine, I got some blank DVD's they were DVD+R.
I recorded a movie onto one on my PC, then tried playing it in the JVC unit... no go!
Instruction manual (available for D/load online) proved to me that I could not play +R disks!!
Jun 11, 2008 | JVC DR-MV1S DVD Recorder/VCR
Can't view a DVD Recorded on RCA DRC8335
whats the format of the dvd writer you used,? cus sometimes the computer cant really read a unknown format of dics. try to use a nero or divx to read it.
Jan 25, 2008 | RCA DRC8335
Panasonic DMR-ES25 DVD Recorder Logo
725 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
