Question about LaCie Electron 19" CRT Monitor
OSD locked out
Hi, My Lacie electron19blue IV is working fine but when I try to calibrate it using the control buttons below the screen I get a message: OSD locked out...meaning that I do not have access to the RGb menu etc....talk about a bummer when you are retouching with Photoshop. Does anyone know how to put it back on? Thanks in advance
Hello you have Resolved ?
thanks andrea
Posted on Mar 11, 2008
  • OMMatrix Dec 29, 2010
    To unlock the OSD on the Electron Blue 4 monitors:
    # Open the OSD by pushing the “EXIT” button. (If you open it with the <,>, - or press “EXIT” once). You should have one green tab (if it is yellow, press the “EXIT” button to turn it green. You should see the message “OSD LOCKED OUT”.
    # Press simultaneously “ ” and “SELECT”. (If the tab becomes yellow it means that only “SELECT” was taken into account.. Press the “EXIT” button to turn the tab green and try again).
    Note: Do not hold down the buttons if the operation fails. Try again by releasing both buttons and pushing them one more time. If it still fails, test the “SELECT” button before trying again.
Philips monitor osd locked
you have to carefully force open the clipped back case of the monitor and disconnect completely the cable to the front control buttons, then the monitor works fine though no adjustments can be made
Jan 12, 2014 | Philips 190WV
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
My monitor says the OSD is locked I can't unlock it
  • If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
  • If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD
Or else you can try this method also, Hold the menu/ok button for ten seconds, to unlock the OSD. If this doesn't solve the problem, then it's probably the button that got stuck. Remove the casing, locate the menu button's contact switch on the circuit board, and try to release it using something thin like a screwdriver, x-acto knife, or set of plyers.If this doesn't work, chances are the menu button is stuck on a loop, sending a continuous signal to the board (which keeps locking/unlocking the OSD).
If so, your only solution (other than take it to a repair shop) is to remove it, by prying it off with a screwdriver or set of plyers. Of course, you'll lose access to the OSD features, but I guess this is better than to have a message stuck on front of your screen all the time..
May 18, 2010 | LG 22" FLATRON LCD Monitor
OSd lock keeps on poping up on my screen, i ihave viewsonic monitor. how can i solve this problem?
You are having a problem with the OSD lock on your ViewSonic Monitor. Is that correct?
If so, please follow these instructions to unlock or lock your monitor.
On some display devices, there is an OSD Lock that locks all current control settings and prevents access to the control menus until this mode is unlocked.
The method for unlocking the OSD is different for different monitors, but will be one of the 2 below. If the first method doesn't work, try the second.
Method 1: Press and hold both the [1] button on the front of the monitor and the down arrow button for 10 seconds.
Method 2: Press and hold both the [1] button on the front of the monitor and the up arrow button for 10 seconds.
Note: These same buttons, when pressed for another 10 seconds, will lock the OSD
Please let us know if you require any further help with this matter.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 28, 2009 | ViewSonic E70f 17" CRT Monitor
I have a Dell E173FP LCD monitor and everytime I try to access the OSD menu a lock appears on the screen. What is the solution to this problem?
Thanx for your help. That should work too, but I tried pressing the menu for 15 seconds and it unlocked.
Thanx again
Jan 03, 2009 | Dell E173FP 17" LCD Monitor
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Osd locked
Note: These same buttons, when pressed for another 10 seconds, will lock the OSD.
Nov 21, 2008 | ViewSonic E70f 17" CRT Monitor
Osd main controls locked/unlocked pops up every 5 seconds
Press the Menu button ( marked OK) for one minute, or more, and a blue/red menu list should appear on screen.
Using the adjust button (immediately to the left of the OK button) by pressing the arrows at each end up or down as required you can enter the menu and select an action by scrolling.
At the end of the list of possible adjustments on the left of the screen (brightness, contrast, etc) is the Reset section.
On the righthand side of the screen is a flashing Yes No choice which automatically alternates.
The trick is to select the Reset choice on the left and while selected press the OK button when the Yes alternative on the right of the screen is flashing.
You VDU should then Reset and all will be well.
Mar 26, 2008 | Philips 190B6CB/27 19" LCD
Osd lock problem
Hi
Try this.
PRESS AND HOLD THE SOURCE BUTTON FOR 20 SECONDS.
Should now be fine.
http://dc07.atspace.com/
Chris..
Dec 15, 2007 | Gateway FPD2275W LCD Monitor
LaCie Electron 19" CRT Monitor Logo
494 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
