Question about Bloomfield 8571 Coffee Maker
3-Pot coffee Maker instructions
We received a Bloomfield 3-pot Coffee Maker as a donation to our church, lacking instructions. There are various opinions about running it. Do we fill the reserviour first, then turn on the switch? Some are saying turn the switch on first, wait for the green light and THEN add the water. We would like accurate instructions.
Thank you.
  • kdau Jan 26, 2008
    This was very helpful and clarified the controversy. Thank you.
  • 60 Answers
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
Posted on Jan 26, 2008
Bloomfield coffee maker overflows, even with plain filter
The outlet of the cone filter holder is clogged. Normally its just a hole you can clean out but some units have a valve that is pushed up/open by your coffee pot. That valve may be clogged or if you changed the coffee pot it may not be opening due to the different pot. Clean valve or just remove it so the coffee will run into coffee pot.
Nov 13, 2013 | Lands Phones
Can the amount of water coming from the waterline be adjusted to ensure a stronger cup of coffee?
Yes there is a timer located behind a removable plug behind the pot to control how long the valve is open. Simply pop the cover off with a standard bit screwdriver and turn counter clockwise to reduce the amount of water in the pot.
Nov 06, 2012 | Bloomfield 8571 Coffee Maker
Makes a slow pot of coffee
Run some CLR, Lime Away, products that removes cdeposits that constrict water flow. Make sure you rinse plenty, to remove any tracr of the product. You can buy these at most super markets, hardware stores.
Jun 04, 2010 | Bloomfield 8572 Coffee Maker
Bloomfield Coffee Maker not brewing
Remove top panel and check the electrical wires for damage.
May 06, 2010 | Bloomfield 1088 Coffee Maker
Coffee only pours a half a pot at a time when I
Check / set the timer for a longer brew cycle.
Mar 10, 2010 | Bloomfield 8572 Coffee Maker
Our church received a Bloomfield Koffee King model 8571 and no instructions on how to set up and use the coffee machine.
Hi, Get 2 pots place one under the spray head with the filter cone in....now fill the other coffee pot and start to pour water through the lid top front...keep pouring water through (about two and a half pots) until water starts to pour through the cone....now the tank is full plug her in and turn on the power switch at the back and also the front if there is one....place filter in cone..put coffee in filter...pot on burner...wait about 25 minutes until water in tank is hot...when light on front comes on pour another pot of cold water through the top and you will get a pot of hot coffee in bottom....I also think this machine can be hard wired into water main....get plummer to hook up...follow same procedure but instead of pouring water through top for coffee..hit brew switch. if it poors too much of too little you will find a timer in the machine you can adjust to allow more or less water...hope this helps.
Jun 25, 2009 | Bloomfield 8571 Coffee Maker
Bloomfield 3-pot coffee maker won't brew
These macines have an internal water heater that should be clened periodicly (monthly per manufacturers instructions but I do it quarterly/semianually/when it gets noisy :) ). The machine will have to be disasembled to do this since the tank will have to be flushed when you do this to get the chemicals out of it (vs running a pot of vinegar through your Mr. Coffee machine at home), Depending on how much scale has built up in the tank this could take several cleaninings. Scale deposits can over time impair/damage the heater or thermostat but replacement parts are cheaper than a new machine and the machine will outlast and outperform a standard coffee maker. BTW, my 8572 3 burner was built in 1972, I bought it at a flee market for $25 10 years ago put $100 in parts to get the push to brew and hot water on tap working again and it made two great pots of coffee this morning.
Nov 18, 2008 | Bloomfield 8571 Coffee Maker
Instructions for bloomfield 8752 same as 8571?
I have a 8571. Bought it used. No instruction Manual. Plug it in, turn on the left burner, poor in water water immediately drains through. I that a valve problem?
Oct 23, 2008 | Bloomfield 8571 Coffee Maker
Bloomfield 8571 Coffee Maker Logo
294 people viewed this question
Top Bloomfield Coffee Makers & Espresso Machines Experts
Leakfixr
frankecoffee
Level 1 Expert
rhodesworks
Are you a Bloomfield Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
