Question about Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b Wireless Adapter
Lost signal My wifes brand new gateway computer keeps droping her wireless conection to our router. She has an internal wireless Intel 3945ABG card. Just to check the signal, I placed my 5 year old Dell, with and external Linksys Wireless G in it, for a few days and it never droped the signal. All her drivers are up to date. She is running a Gateway NX570X if that helps. Its still under warantee so if its a bum card, I can swap it out. Thanks
  • Saltypup77 Jan 28, 2008
    Tried your soultion. I think the card ust gave up. I disabled it and plugged in an external wireless card and it worked fine. Called gatway customer service and they are sending out a replacement card. On a side note, their customer service is not too handy. They insisted that the part was built into the motherboard and could NOT be changed or removed. I told them they were wrong because i was holding the part in my hand. They STILL said that the part could not be removed and I informed them that I got instructions off their web site on HOW TO REMOVE THE PART. Then they got snippy with my wife and my darling lil 5 foot blond put them in their place! Hence... our part is on its way. Thats for the ideas guys.
  • ppilenok Oct 24, 2008
    I Have acer 5920g with Intel 3945ABG and windows update manage to update it's driver to 45....something since that i can't connect to network at all, i can see the network in "connect to" with excelent signal, but cant connect. Before I managed to fix this problem by rolling back the old driver for 3945ABG but since the last update it doesn't help any more!
    Genius:
  • 1,601 Answers
Saltypup77:
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Try going to the usb and the wireless adapter in device manager, properties. And make sure that the computer does not shut them off to save power.
Please let me know how you make out.
thanks
Posted on Jan 25, 2008
  • Thomas Christopher
    Thomas Christopher Jan 29, 2008
    Saltypup77, Thanks for the update.I am your darling lil 5 foot blond put them in their place. They need it sometimes...
    Thomas Christopher Jan 31, 2008
    Could you please rerate this to at least Helpful.
Lost security code for 3 dongle. need it to set another computer up
ya ya ya , you blame your wife!!! don't do that again as gentleman. Well do this,:
open this link in the computer which is connected to wireless,
http://www.nirsoft.net/utils/wireless_key.html
download the program and run this utility you will find your wireless key
Jan 11, 2012 | LG ANWF100 Wireless dongle
Do I need two wireless network adapters? I looked in the device manager folder in network adapters and there are 2... Intel (R) Pro/1000 PL Network Connection #2 and Intel (R) Pro/wireless 3945ABG...
You should have only 1 wireless adapter, the other 1 is the ethernet adapter. If you experience low signal strength even after updating the drivers, you need to customize wireless settings on the router.
You need to change the wireless mode to "802.11b and 802.11g" or "802.11g", whatever you have in your router. If this is the same with all wireless networks, wherever you go, then its an issue with the adapter, you should get a replacement.
Feb 05, 2010 | Intel PRO/Wireless 3945ABG Network...
My card will not connect to my wireless router. Why? It's installed and recognized as working properly in my system. Is their another program that needs to be installed to connect to the verizon dsl...
Is the internal wireless turned on? Depending on the computer, there may be a switch on the outside, and, there is also a software switch on some computers to turn the internal wireless on and off.
What type of computer is the computer that has the "internal wireless"?
Security can be setup following the instructions int he router manual, but I can help you as well. If you want, I can set you up remotely, for a charge.
Dec 17, 2009 | Intel PRO/Wireless 3945ABG Network...
Intel 3945ABG - no connection
usually, on board wireless cards need to be enabled, or physically switched on via a toggle switch, or by pressing a button or a keyboard key (something like Fn + F2). Once it's enabled, a wireless light should turn on. If it appears to be enabled, you can further isolate the problem by checking if other wireless computers can see your router. If not, then the router probably needs to be configured properly.
Jul 12, 2009 | Computers & Internet
Linksys N router drops signal
Its not dropping you because of the spectrums, it works on line of sight. If you are in a basement and your router is upstairs it has to go thru a floor and the strength is weakened. Go into your router and increase the signal strength. But you have to mod your firmware.
http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
Here is a link to update your firmware.
Jan 24, 2009 | Linksys Wireless-N WRT150N Router
Connect wireless g devices to D-Link 615 (wireless n) router
Try to able the WI-FI Protected Setup that you have in your router.
Make sure that the MAC filtering is OFF in your Network Filter under the Advanced tab.
Jan 23, 2009 | D-Link DIR-625 (790069292637) Wireless...
Intel Pro Wireless 3945abg not connecting to higher speed DSL
router wireless limitations. if it was N type router it would go faster.
Oct 14, 2008 | Intel PRO/Wireless 3945ABG Network...
Compatibility between linksys WRT54G Router and Intel PRO/Wireless 3945ABG Network Driver
from what you say, it sounds as if you have your wired and wireless card connected at the same time. This will confuse the router as it is trying to give two different ip addresses to the one pc, which it cannot do. If you are using the wireless adapter, make sure you dissable the wired adapter as the router will continually look for the wired ip address while allocating your wireless adapter causing instability. Next ensure you have a good clear signal from router to notebook as this can obviously cause problems. Lastly ensure that the wireless cards TCP/IP properties are set to obtain ip address automatically, especially if your router is DHCP enabled to allocate ip addresses automatically.
May 17, 2007 | Linksys Wireless-G WRT54G Router
Intel 3945ABG 802.11a/g/b Wireless Adapter Problem
look in your routers settings and see if there is an idle time setting and set this to '0'
Feb 13, 2007 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b Wireless Adapter Logo
209 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
