I have an Inglis Model no ID47600 Ser. No. CG1003381 and it wont spin, lots of black rubber under machine, is a direct drive model. is there a website I can find a schematic for this machine.
  • cinbad Jan 28, 2008
    My wife could not wait for a repair so it went to the dump and we bought a new one. Why did they go away from belt drive machines, cause they were too easy to repair.
  • 770 Answers
Who is the manfacturer?? From first thought you burnt out a drive coupling but will need the complete model # from the unit so i can see what you have and get ther the part number
Posted on Jan 25, 2008
  • Gary Davd
    Gary Davd Jan 28, 2008
    The belt drive units were a nightmare the #95405 Belt change was a @#$%# . The direct drive units are so easy to work on the whole cabniet removes so you can get to everything without pulling the unit out from the wall..
My Inglis by Whirlpool washer doesnt spin. Its a Direct drive unit so Im guessing that the clutch is bad?
does the motor run when its supposed to spin? if not its probebly a lid swich problem. if the motor runs it may be a coupler or poss. cluch. sometimes a sock in between the tubs.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
May 07, 2014 | Whirlpool Inglis IP4400 Washer
THE SPIN CYCLE WILL NOT WORK ON ANY CYCLE THE PUMP WORKS BUT WILL NOT SPIN OUT CLOTHES PLEASE HELP
If you have a direct drive washing machine you need a new motor coupling. Do a search online with your make and model number and see if you have a direct drive washing machine. The motor coupler is 2 pieces of plastic and a rubber gasket. Its about a $20 part and depending on how mechanical you are, should take about 30 minutes to fix. There are a lot of website and videos showing how to fix step by step. Do a search online like: How do I replace my motor coupler on a MODEL NUMBER. Good Luck!
Feb 22, 2011 | Washing Machines
I have a inglis that is 5yrs old but will not spin they say my machine is drict drive it will was and drain but will not spin on any setting ... thanks.... townie
This is usually caused by the motor coupler. This is very inexpensive and easy to replace. Here is a video this will walk you thru this disassembling and replacing a motor coupler in a direct drive machine. It may be a different model but the troubleshooting and replacement will be the same. You can also enter your model # for your specific model to get diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Feb 04, 2011 | Whirlpool Washing Machines
Machine will not spin out water,does this machine have a belt driven drum or is it direct drive? found under unit what was thought to be rubber material on floor
depending on the model you have it can be either or.
if you can lean the machine back and take a llok under neath you might be able to see the motor and the drain pump might be attached to the front of the motor. look just behind the motor and you should see a black rubber piece with two white plastic pieces this is a drive coupler and if it is broken then you need to replace it
Jan 31, 2010 | Washing Machines
It wont rise or spin.
you probably need to replace the direct drive coupler on the motor shaft. easy to do, not expensive either.
Nov 13, 2009 | Whirlpool Inglis IP4400 Washer
MY ADMIRAL WASHER WONT SPIN FAST ENOUGH..IT DOES SPIN BUT WHEN IT STOPS THE CLOTHES ARE STILL DRIPPING WET
Sounds like a whirlpool or inglis type belt drive with a loose belt or bad basketdrive[clutch].
Could be the set screw backed out on the basket, thats a pretty common problem.
I'd need a model number to know who made it though.
May 19, 2009 | Admiral AW22 Top Load Washer
Dry-spin doesn't work, because after rinsing the clothes are still wet. MOD- VBXR1070WOWW SER-SZ107967H
I'm assuming this is a G.E. brand because of the model number. Take the four screws off the very bottom panel of the front of the washer. Inside you will see a twist off rubber cap. Place a pan under it big enough to hold 2 quarts, and twist the cap open. When the water comes out and it is empty remove any accumulation of lint, loose change, etc. This should be done monthly to help the washer discharge the water on spin cycles.
Also, inside the door is a flat rubber ring. At the bottom pull the flap back. There are small holes there for the water to drain out. Lots of stuff accumulates there too, even as large as a pocket knife or ball point pen. Check that daily when washing.
May 19, 2009 | Washing Machines
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Jan 31, 2009 | Whirlpool Inglis IP4400 Washer
Washing Machines Logo
90 people viewed this question
Top Washing Machines Experts
