Question about Sony SLV-D300P DVD Player/VCR
Dvd player has progressive light on and wont respond to buttoms
My dvd player wont work when i press any buttoms the progressive light just comes on and doesnt do anything anyone know why?
  • 2 more comments
  • hallospace Feb 13, 2008
    Yes, I have this same problem. The progressive blue light is stuck on and when I unplug and the plug it back in the same thing happens.
  • SDFam Jul 19, 2008
    Stuck with same problem. When I turn it on just the blue light appears for a few seconds along with some clicking noises - nothing happens beyond that. Any suggestions?
  • Anonymous Feb 23, 2009
    Same problem, except mine is a SLV-D201P. Flickering blue progressive light, and nothing else works. Not the power switch. Nothing. Seems this product should have lasted longer than it did!
  • bigtill43 Apr 16, 2009
    Blue progressive light blinks and other buttons when pressed with resppond. The unit appears to be in a standby state. Unit is not that old and has few hours on it.
soldierruel
  • 175 Answers
SOURCE: Display Problem
Check the battery to see if it has the original capacity if not you may need to rejuvenate it. Also try to open the unit and reattach the LCD. Good Luck.
Posted on Aug 08, 2006
SOURCE: Magnavox MDV560VR DVD Player Stuck in Progressive Scan
it worked for me too.
make sure that you see the word stop on your dvd
Posted on May 04, 2008
SOURCE: dvd player stuck in progressive mode
ok i got a solutioN!!!
ok go to ur actual dvd/vcr player (not the remote) and press and hole the STOP botton for like 5-10 seconds.
thank goodnesss!!!!!!!!!!!!
your welcome! :]]
Posted on Jun 18, 2008
  • 1894 Answers
SOURCE: Sony DAV-C700 DVD player not working
is there any display in the LCD screen of your player??
Posted on Jun 28, 2008
SOURCE: I have Pioneer DVD 210-K Player. I pressed the progressive
dear hayds..... you must have LCD tv and rgv cable i am not sure what its called but coming with green instead of that yellow head. i hope that helpful for you.
Posted on Jun 01, 2009
Dvd recorder in standy wont work - blue standby light showing!
The main power supply board has the fault. It might be replaced. It is best to replace as card basis, rather than making 'surgery' to it.
May 30, 2012 | Televison & Video
I have a sylvania dvd vcr combo and the progressive scan light is on and it wont play dvds. How can I fix this?
Try the (Goldstar and Zenith) trick - with the unit on, but no discs inserted, press and hold STOP button on the front (not the remote) for 10 seconds, then release. This should revert progressive back to normal interlace output for your TV and may also turn off the progressive LED indicator on your unit.
I mentioned 2 other brands in parentheses - because the (press and hold STOP for 10 seconds) trick works for progressive on those.
Apr 10, 2011 | Sylvania (SRDD495) DVD Player/VCR
I changed some video imput and now i cant see anything, only audio
1. Press FUNCTION repetedly until "DVD" appears in the front panel display.
2. While holding down rewind botton, press FUNCTION.
The output signal is changed to interlace format.
Apr 23, 2009 | Sony DAV-FR10W System
Need a Code Number to work with my Dish
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
This way of finder code make the remote search 1 by one , usually dvd and other things else than television dont work , but give it a try might work but probably will just power on and off not more than that but will work fine with ur tv
Jan 11, 2009 | Curtis DVD-7600 DVD Player/VCR
Dvd player stuck in progressive mode
your welcome! :]]
Jun 11, 2008 | Zenith XBV243 DVD Player/VCR
DVD player wont show picture
to turn it off select connection method 3 above and progressive scanning mode, to set the mode, set progressive to off in the display menu so that the p scan indicator light on the front panel goes out. do all of this in interface mode. you can also do this by pressing and holding PLAY > on the front of the unit for more than 5 seconds, still watch for the p scan indicator to go off. this works best when the unit is connected directly to the television.
Dec 04, 2007 | GoVideo Go Video DVD/VCR Combo
Question on setup
If you set Progressive Scan to
ON in error, you must reset the DVD/VCR. First,
remove the disc in the DVD/VCR. Next, press STOP
and hold it for 5 seconds before releasing it.
Oct 18, 2007 | Sanyo DVW-7000 DVD Player/VCR
Cannot remove progressive scan mode
press stop and keep hold of the stop button while you eject the dvd, it worked for me, i played around with it and found pressing stop and holding it while ejecting works
Sep 30, 2007 | Televison & Video
Sudden split screen
Your dvd player is in progressive mode, and your tv isnt capable of playing progressive mode.  To fix this, look on your remote for a button called "Progressive", and press it.  If you dont have a button like that, then look through your service manual for anything that says progressive mode, and it should give instructions on how to set it back to interlace mode.  This is a very common problem I come across when servicing DVD players, as inadvertently pressing the wrong button the remote will cause this.
Sep 07, 2007 | Panasonic DMR-ES40VS DVD Recorder/VCR
Sony SLV-D300P DVD Player/VCR Logo
243 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
