Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
The dishwaser has a bad smell
Ge prfile pdw988ojss
  • Anonymous Nov 13, 2008
    any place that needs cleaning to reduce oder
  • GE Master
  • 2,651 Answers
Run unit through acycle or 2 with a bowl of vinegar on lower rack this should clear all odors from machine,does this drain into a garbage disposal?? thats where smell can be coming from if so pour some vinegar down there regularly as well
Posted on Feb 23, 2008
I have a GE GFDR270GH1WW Gas Dryer and upon starting I smell gas. There is no smell until starting.
usually that could be a bad gas valve,go outside where it vents if you smell gas at the flapper outside it's the valve
Dec 19, 2017 | GE Dryers
If the motor was humming and would not start the unit, the start relay on the motor is bad and the motor will need to be replaced. here is the motor to order.
Nov 29, 2012 | Dryers
GE Prfile GCG1580LSS 15" Trash
Hello & Welcome to FixYa
Please get back to me with a detailed question about your problem if you have any other questions as we avoid guessing.
Aug 14, 2011 | Dishwashers
On most dishwasers if you take off the bottom panel and look up inside by the water valve you will find a schematic.It's always folded up into a really small piece and tucked into a small black plastic bag.
Apr 07, 2011 | GE Dishwashers
GE Twenty-Eight Hundred Dishwaser says blocked washarm, but isn't Code C5
If you've checked that nothing is in the way (no spoons hanging down, etc) just press and hold start and it will start up again and probably won't reoccur for the rest of the cycle. Our dishwasher started doing this near the end of its life....
Feb 23, 2011 | GE Dishwashers
Ge dishwaser will run but wont spray any water
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
Sep 05, 2010 | GE Dishwashers
What is the sealed pan(bottom drawer) in a prfile for seems to rot fruit
removing clear plastic section from from solid part to get trapped dirt
Sep 02, 2010 | GE Refrigerators
I have an older ge prfile washer & the cycle knob does not work. how do you take it off. i have pulled it & tried to unscrew it but neither works
pull knob out and look behind it. You should see a white plastic clip. You have to pull this out and then knob comes off. When replacing knob, put clip on knob first and then just push knob on to shaft.
Jun 10, 2010 | GE Profile WPRE6100G Top Load Washer
Capacitor burned out? horrible burnt smell.
YOUR GOING TO NEED A NEW MICROWAVE . the cap may be bad but the real bad smell you have is most likely the HV tranformer , if the magntron shorts to ground there will be a small smell if you dont pick up on that and your microwave is set to run another few mins the transformer will overheat and burn , then the fuse blows and the controls shut down . the end result , you have more parts bad than you have good . if you google " GE SPACEMAKER MICROWAVE FIRE ' you will see your not the only one , its getting to be COMMON . good luck
Mar 08, 2009 | GE XL1800 1100 Watts Microwave Oven
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
265 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
