Quintum DX Issues connecting to a static route which used to work before
Quintum DX2060 Issues connecting to a static route which used to work before (24 hours before) .Curently it works with other static routes.The provider of that IP blames my equipment.
I use H323
  • aergen Jan 25, 2008
    The gateway is curently in production and sends calls to other static addreses.I am not sure that cooling the box would fix the problem.Normally, should stop sending traffic to the other IPs.
  • Anonymous Mar 24, 2014
    does quintum as series support H323
    Genius:
  • 1,067 Answers
Could be bad rought u unplug it fr wiel and cool it down plug back in is it getting hot do u have fans on your roughters
Posted on Jan 25, 2008
Tanor dx licensefile.dat file
sir quintum license.dat file
sn=A0423028BA plz send the mail.
mail id-avatar.netspace@gmail.com
Feb 25, 2012 | Quintum Tenor DX2060 (501-0122-00)...
NEED QUINTUM PASSWORD RESETTING
The detailed description of Configuring Terminal Software/Assigning IP address to Tenor DX is given below.If you need only RESETTING GOTO STEP 18.
1.From your PC, click on Start> Programs> Accessories> Communications> HyperTerminal. The Connection Description is displayed.
2.Enter a connection name (i.e., name for each unit such as Tenor DX 1 and click Ok.
3.Choose the connection port on your PC from the Connect Using drop down list box (i.e., Direct to Com1). Click Ok. The Com1 Properties window will be displayed. See Figure 3.
4.From the Bits Per Second drop down list box, choose 38400.
5.From the Data Bits drop down list box, choose 8.
6.From the Parity drop down list box, choose None.
7.From the Stop bits drop down list box, choose 1.
8.From the Flow control drop down list box, choose None. Click Ok. A connection to the Tenor unit is established.
9.Click on Call>Call. A connection to the unit will be established. The login prompt appears.
10.Enter a login name. The default login name is admin.
11.Enter a password. The default password is admin. (Once you are up and running, changing the password is a good idea for security purposes). Step through each of the following parameters and enter the correct values for your installation: IP address, Subnet Mask and Default Gateway.
12.At the Quintum prompt, type ei to reach the Ethernet prompt and then type config to change to the configuration mode.
13.To set the IP address, type set ipa followed by the IP address.
14.To set the Subnet Mask, type set subnetmask, followed by the subnet mask.
15.Type siprd to change to the Static IP Route Directory.
16.To set the Default Gateway IP, type change 1 g followed by the IP address for the default gateway IP.
17.Type submit.
18.Type maint to reach the maintenance mode and then mc. Type reset. A confirmation message will ask if you want to reset the unit. Type yes to reset the unit. The reboot enables the Tenor to incorporate the new settings.
19.Once the IP information is set, you are ready to configure the unit.
Jun 04, 2011 | Quintum Tenor DX2060 (501-0122-00)...
Static routing "Advanced Routing" on Linksys WRT55AG
Any reason why they're not both on the same subnet?
Jun 15, 2008 | Linksys WRT55AG Router
Which Affordable VOIP Gateway to Buy?
contact me so that i can send you list of voip gateway
khap_termination@hotmail.com
Mar 30, 2008 | Quintum Tenor DX2048 (501012100) 2x10/100...
I minute remainding voice message
This can only be done via DTMF signaling, not by a wav file.
Sep 17, 2007 | Quintum Tenor DX2048 (501012100) 2x10/100...
Setting up Call Progress Voice Announcement
This is not possible, it is done by DTMF tones only.
Internet down when give gateway
yes, it will work fine. But there is no need to formate. You do one thing try once more. Check modem which is provided by your vender. Switch off & on your modem. Right click on internet explorer -> properties->Delete cookies , delete history-> go to advance -> restore default. Switch off and switch on of your modem. Check four light should be blink. If it is glowing definitely it will work. Good Luck
Sep 06, 2007 | Quintum Tenor DX2060 (501-0122-00)...
Quintum DX2060
http://www.quintum.com/support/products/2G/tenor_2G/sysdoc/webhelp/calleridgeneration.htm
Try the search box at this URL: http://www.quintum.com/support/
Just copy & paste the parameter name into the box.
Jan 13, 2007 | Quintum Tenor DX2060 (501-0122-00)...
Computers & Internet Logo
283 people viewed this question
Alun Cox
David Payne
David Payne
