Question about RCA DRC8052N DVD Recorder
RCA DRC8052N & RCA DRC8060 Power Capacitors
Hi there, I have a RCA DRC8052N and I did get the stuck on ''Hello'' message and was able to reset by pressing the power button for 10 Secs. I was just wondering which Capacitors are responsible for this? All the Capacitors look good on the power board, no bulges. I saw the 1000uf ones and the smaller 680uf ones and I was thinking if I should just replace all with a higher voltage just to be safe and prevent power up glitches.
Also I have the RCA DRC8060 and it never gave me any power ups until recently. It actually just didn't power on. I was able to reset it, and it seems to be working well now. But just to be safe I would also like to put in a higher voltage Capacitor. I think the Capacitor is 2200uf, but I don't know which one for sure.
Do you know which Capacitor is the one to replace?
Any feedback greatly appreciated
Thanks
  • Jerry Maharaj
    Jerry Maharaj Feb 11, 2010
    Thanks for the advise Zahc! I will get on those and replace them with the Caps you suggested.
    I'll update when finished.
    Thanks
    Jerry
  • Jerry Maharaj
    Jerry Maharaj Mar 12, 2010
    Hey, Zahc, I changed the caps on my RCA DRC8052N with the 1000uf with 50v caps and on the DRC8060 I replaced the caps with 2200uf 50v caps. Everything is working well so far, no stick ups.
    The Caps on the DRC8052N are labeled C15, C19,C22.
    Thanks for all the help Zach.
    Jerry
  • 212 Answers
The capacitors are C1260, C1270, and C1271 and don't always any sign of degredation.
Here's a pic of them, in this case obviously degraded.
http://i38.tinypic.com/nehn5e.jpg
They can be subtituted by 1000uF 25V capacitors ( they are 680uF 16V).
On your RCA DRC8060, replace the 3 2200uf capacitors with 10v items.
Make sure you use 105 degree parts, as most of these problems relate to heat stress.
Don't forget to unplug before diving in!
If I've helped, please provide feedback so I can help others.
Regards
Zahc
Posted on Feb 11, 2010
Hello...Have RCA L40FHD41YX9 ,serial number J203C40GV. Watching t.v., picture and sound go. Unplug, then replug...blue light in front, but still no picture or sound. Please advise
Fred, Unplug for a couple hours then try, if does not reset, board,capacitors or power supply gone bad.
Check the attached links for TV's problem.,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Fix Your TV Instantly
how to fix 42 RCA flat screen
RCA 276046 Power Supply Unit PSU Boards Replacement Guide for RCA LCD TV...
http://v6.tvrepairtips.org/anon/supertips?page=1&make=&model=LTV46W1%20HD&problem=
Mar 07, 2016 | RCA Televison & Video
The dvd recorder drc 8052 only said hello, hello , hello . please help me.
You are getting this screen display as you switch on and it indicates that the processor starts up but since it does not move forward there are errors in the main board/processor board which give a wrong feedback thereby shutting off the player.
You need to check the power supply to start with and if all these seems OK , the main board is a suspect.
Feb 05, 2011 | RCA DRC8052N DVD Recorder
Dvd will not eject. tray will not open. pressing open causes "hello hello". is there a way to manually force the tray to open without damaging the dvd?
The DRC8052N / DRC8052NB / DRC8052NC DVD recorder (sorry cab209, not a PC) has had a LOT of problems. So many that RCA doesn't even list it on their site! There was a firmware upgrade that supposedly fixed this, but I'm having trouble finding it on the web.
As to how to remove DVD:
1) Try unplugging the machine and leaving it unplugged for 10 to 15 minutes. then (without plugging it back in) press the power button repeatedly. (I know it sounds goofy but it came from customer support. Theory: to drain all power) Plug it back in and try to eject.
2) Another owner suggested holding down the HDMI button on the remote. The "hello" mesage is an initialization/power-on routine, so my guess would be it was powered off with the disc in it?
3) Unplug it. Remove the cover (two silver screws on each side and three black screws on the back). Slide the cover off (to the rear). Take the four small screws out of the top of the drive (marked LOADER on mine. Lift out the DVD. Reassemble.
While you have it apart..... You might also look at the circuit board next to the drive in the center of the unit. It has a bunch of capacitors (black or blue, cylindrical, w/ X or Y stamped in the end). If any of these are no longer flat on the X or Y end or have yellow 'goo' on or around them, they have failed and are the source of your problem. They can be replaced, but it may be more cost effective to replace the entire unit.
Jim
Jan 02, 2010 | RCA DRC8052N DVD Recorder
Hi there, I have a RCA DRC8052N and I did get the stuck on ''Hello'' message and was able to reset by pressing the power button for 10 Secs. I was just wondering which Capacitors are responsible for this?...
Found the ground wire solder point on the main board and it needed to be re soldered. Tested for continuity and put it back together and it worked.
No more intermittent cut offs.
Dec 29, 2009 | RCA RS2663 Shelf System
Rca drc8052nb only says ''hello'' on screen, can anyone help?
RCA DRC 8052NB does nothing but displays "HELLO"
Among the voltages available from the power supply is a 3-volt source. The first capacitor after the diode is a 1000 microfarad, 6.3-volt unit. There were no signs of leakage of overheating, but I changed it anyway. Voila! the unit came to life. Hope this helps.
Jan 06, 2009 | RCA DRC8052N DVD Recorder
Rca drc8052n
both the tv and dvd must have s video connections. if not use the rca
Sep 28, 2008 | RCA DRC8052N DVD Recorder
Dvd player
Just called again and wanted to do a soft reset by pressing the power button and the stop button together. then try to open it, if not then turn the unit off and leave it off for 30 min then plug it back in and try opening it then. if still doesn't work then send it back and pay the $169 heheheheh crazy!
Nov 22, 2007 | RCA DRC8052N DVD Recorder
RCA DRC8052N DVD Player
Press title then hit 01-It takes you to the first chapter in the movie
Nov 15, 2007 | Televison & Video
Rca drc8060n
BTW - I did open the unit up, and my hunch is that it is a power supply issue. Also, the DVD drive appears to be a standard 5.25" IDE drive made by Philips. It might be worth salvaging for use in a PC if drivers and/or firmware exist for it.
Oct 19, 2007 | RCA DRC8060N DVD Recorder
RCA DRC8052N DVD Recorder Logo
687 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
