My tv color is red - Televison & Video
  • 3 more comments
  • pwoodhou Feb 21, 2008
    color is dark orange getting worse. no red lamp light indicating bulb probs
    Sony Grand WEGA KDF-60XS955 60 in. Rear Projection HDTV Television
  • Anonymous Feb 21, 2008
    Samsung 110cm Rear Projection Tv
    my tv has suddenly got red shadows throughout all channels.
  • Anonymous Mar 06, 2008
    tv picture turned red. problem: green color bulb burned out. solution: buy new green center bulb for approx. $170.00 at local electronics dealer or online.
  • Anonymous Aug 27, 2008
    I have a Sony KP-51WS520, I cannot get the the color right from the video menu, after repeatedly adjusting the Hue. The set is about 4yrs old.
    The greens and reds are way off. If I add Red hue, the greens turn brown and the reds are still off, and when I add green hue the greens are fine but then everything else gets a yellowish tint, like skin tone?
    If I leave the hue at it's standard middle line position (on the yellow bar) the overall colors just look washed out.
    Can you help?
  • craigisaac Sep 21, 2008
    Song WEGA with no red color. All reds appear brown. Doesn't matter how much adjusting I do, the color red just does work. I have unplugged for 5 minutes and 4 hours...nothing. Please help...Thanks,
    Problem Solver:
  • 8 Answers
Posted on Jan 25, 2008
My sony TV trinitron wega 42 inch picture is red. Is there any solution to remove the problem?
The problem with your TV trinitron wega is at the color adjustment section. It is located at the color board mounted at the back of the picture tube. There are variable resistors that represents the color pattern in the picture tube. Adjust the red color to low level to lower the red color.
Nov 03, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/ could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
Movie has no red color only green and yellow
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
Sep 30, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
42 panasonic plasma TV I have no red color in tv
I unplugged all the cables that goes from the cable box to the tv and then plugged it back in. The color red canme back. It was easy.
Oct 19, 2008 | Televison & Video
PSP 6 pin gen 2 cable not working on tv?
you have the wrong cable. the cable you have is for HDTV's only.
by the ports on the TV, you have a standard TV.
The cable's colors are Red, Blue, Green, Red, and White. If you have a HDTV or these ports on the back of the TV, connect them like in the picture.
from what you said, it seems like your TV's port colors are Yellow, Red and White. If you only have these ports on the back (Yellow, red, white), you need this cable:
Aug 30, 2008 | Sony PlayStation Portable (PSP) Console
SONY 57' HDTV color projection TV, red color dominance on-screen
these tv's have a problem with bad crt's you could try to replace the red but a better choice would be all three
Oct 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
No red color
the red driver circuit is blown...may be cheaper to replace TV.
Jun 09, 2007 | Toshiba 36A43 36" TV
Televison & Video Logo
2,697 people viewed this question
Top Televison & Video Experts
