Question about Ricoh Aficio GX3000 All-In-One Printer
Ricoh GX3000 When I power on my Ricoh GX3000, I get an err 999.
  • zxczxc1 Jan 29, 2008
    Same problem here. I guess problem is in the pump, because there are some airbubble in the tube between colortank and nozzle.
  • strapioca Jan 24, 2009
    I have 2 printers gx 3000. The first I've bought started the 999 error just one month after the warranty period, so I used the ticket of the second one to have it repaired free. Now, 3 or 4 months after the warranty period of the second one, also this printer presents the same problem (err 999). Is this a case or are these printers programmed to be damaged just after the warranty period?
    Ho 2 stampanti gx 3000. La prima ha presentato questo errore proprio un mese dopo la scadenza della garanzia, così la ho fatta riparare usando lo scontrino di acquisto della seconda. Ora dopo che è scaduta da 3-4 mesi anche la garanzia della seconda, si è presentato lo stesso problema anche su questa periferica. E' una coincidenza o queste stampanti sono programmate per rompersi proprio dopo la scadenza della garanzia?
    Scholar:
  • 132 Answers
ERR (990) or ERR (999) are both error messages which are displayed when a sensor does not work normally due to dirtiness. For example, either may be caused by a dirty maintenance unit or clogged ink nozzles. It may be possible to resolve the issue by cleaning the device
look here for instructions:
http://www.ricoh-usa.com/support/knowledgebase.asp?tsn=Ricoh-USA
Posted on Feb 17, 2010
When i power the printer it shows me remove misfeed top cover, and yet there`s no visble misfeed.
when i do a job sometimes its fixed but my recent problem is that it prints Blank Pages yet I`ve just replaced the cartriges! how do I fix This problem?
Andru
Posted on Oct 03, 2008
  • djandru Oct 06, 2008
    I just opened the back slot(extreme left) of my Ricoh printer GX3000
    and found lots of ink dispensed in there, what do i do with it? Am
    thinkin of pouring it hoping this will help my printer to start working
    again! it`s currently printing blank pages , Any ideas out there?
    Thanks guys?
  • 45 Answers
The maintenance motor HP sensor failed to detect the motor at the home position.
• Maintenance HP sensor connector loose, broken, or defective
• Maintenance motor connector loose, broken, or defective
graciano@megasoft.pt
Posted on May 27, 2009
  • Graciano Leitao May 27, 2009
    just try to clean the path of the heads
Your printer would require service from a Ricoh repair centre or agent, as this normally occurs when the ink purge unit encounters a problem, and the end result is damage to the main controller board, that to my knowlege is not repairable and requires the board to be replaced.
Hope this helps.
Posted on Apr 30, 2008
Driver brother aficio GX3000 not support windows 7
Good day,
this printer should be supported by Windows 7. How did you try to install it?
If pluggin in is not good you may want to download and install driver from this website:
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=24849&ricohmodelid=6538&url=http%3A%2F%2Fsupport.ricoh.com%2Fbb%2Fhtml%2Fdr_ut_e%2Fre%2Fmodel%2Fgxe330%2Fgxe330en.htm
Let us know if you solved your problem
Aug 21, 2011 | Ricoh Aficio GX3000 All-In-One Printer
Gx3000 printer showed remove misfeed top cover, there are no paper in printer
inside it will be small pice of paper, remove it. and will be normal.
May 28, 2011 | Ricoh Aficio GX3000 All-In-One Printer
Ricoh Aficio GX3050 Gel sprinter - error999
BULLETIN NUMBER: J001/J003/J006/J007/J010/J011 – 021 07/02/2008
APPLICABLE MODEL:
GESTETNER – GX3000/GX3050n/GX5050n
LANIER – GX3000/GX3050n/GX5050n
RICOH – GX3000/GX3050n/GX5050n
SAVIN – GX3000/GX3050n/GX5050n
SUBJECT: SC999 OCCURS
SYMPTOM:
An SC999 (Maintenance Stepper Motor Home Position Error) occurs.
CAUSE:
Some of the ink in the machine has dried, and as a result the maintenance stopper motor cannot rotate or
the levers come loose.
NOTE: The following conditions make it easy for the ink to dry up (See Appendix 3 for more details):
- Low humidity
- Long intervals between machine usage
- Total period of usage is long
- Low Print Volume
 COPY QUALITY
Fixed ink Stepper Motor
Right Flushing Gate
Levers
Tech Service Bulletin No. J001/J003/J006/J007/J010/J011 – 021
Page 2 of 5
SOLUTION:
Production Countermeasure:
The shapes of some parts in the Maintenance Unit have been changed in two steps ("Step 1" and "Step 2"
below).
NOTE:
See Appendix 1 for the details of the Step 1 and Step 2 modifications.
See Appendix 2 for the visual differences among the unmodified unit, the Step 1-modified unit, and
Step 2-modified unit.
See UNITS AFFECTED for the Serial Number cut-in of Steps 1 and 2.
Field Countermeasure:
1. Cycle power OFF/ON.
2. Install one of the modified Maintenance Units ("Step 1" or "Step 2").
NOTE: For customers experiencing a SC999, have them contact 1-800 Ricoh38 for replacement.
Feb 02, 2010 | Ricoh Aficio GX3050 GelSprinter
I have a brand new Ricoh GX 3050sfn. When I cnonect it and turn power on, I get system error s001. What can I do?
The travel lock is on open the top and on the front left underside there is a switch push it back and it should work fine
Dec 20, 2009 | Ricoh Aficio GX3000 All-In-One Printer
I replaced the ink waste tank on my Ricoh GX3000 - then it asked for new yellow ink cartridge and I replaced that. Now I have an error code 990 and I can't get rid of it.
bonjour,
allume ton imprimante,puis retire toutes tes cartouches.
eteint l'imprimante.
rallume l'imprimante et remet les cartouches.
le code d'erreur 990 indique de l'air dans les tuyaux.
ça devrait marcher!
Oct 05, 2009 | Ricoh Aficio GX3000 InkJet Printer
Where gen I get an apple driver
check this link:
http://www.ricoh.co.nz/downloads/index.php
Sep 14, 2009 | Ricoh Aficio GX3000 All-In-One Printer
Error 999 on gx3000 what can i do to fix it please
Your Cross-Referencing software. Click for more details!','98','',this);" onmouseout="StartTimer();" href="http://www.imagerzone.com/ForumsPro/viewtopic/wordclick.php?wid=98">printer would require service from a Ricoh repair center, this normally occurs when the ink purge unit encounters a problem, and the end result is damage to the main controller board, that to my knowlege is not repairable and requires the board to be replaced.
Aug 19, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio GX3000 All-In-One Printer Logo
4,032 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
