Question about Whirlpool LGV4634JQ Gas Dryer
Kenmore gas dryer
My dryer is working but do not stops when the cloth is ready and the position on the timer do not moves i replaced the timer but the problem still there. help please. thanks
  • 770 Answers
Is this in the auto mode or timed mode??
Posted on Jan 25, 2008
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
I have an older model...........maybe 8-10 yrs and i turned it on lastnight and this morning it was still running. the knob that is like the timer didnt even move???? i opened it up and the clothes were...
The gas turned off when the temperature is detectd by a thermal sensor. The timer is not working therefore the motor keeps running until you turned it off. The timer need to be replaced.
Apr 27, 2010 | Kenmore 72602 Gas Dryer
Dryer will not turn off is it the timer? the dial does not move
do you have heat?when the dryer heats up the timer doesn't move,when the heat shuts off the timer moves,when the heat comes back on the timer stops,the timer will not move if there's no heat.if you have heat it could be the timer.also run the dryer when it's cold for 15 to 30 minutes and check to see if the flame is still liting,there's a little cover on the front panel that you can pop off to see the flame,there's a set of gas coils on top of the gas valve that when they fail they will stop working when they heat up,when the coils cool down they will let the gas through and the flame will lite again,common problem with gas dryers and most likely your problem.also when was the last time you cleaned out the dryer,you need to blow out the vent line if it's a long run from the back of dryer to the outside i use a leaf blower to blow out the line,make sure the outside vent is clear so the air can blow through,next you need to clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is,you should do this once a year moreso with gas so you don't have a fire,also your clothes will dry on time and you'll have less problems with the dryer.let me know what you find.
Apr 18, 2010 | Kenmore 73952 Gas Dryer
It takes hours to dry the clothes. The dial moves
sounds like a bad timer. if it sticks every time replace they are expensive
Mar 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore 11070702990 Gas Dryer - Timer does not work
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore 1 10.74842400 gas dryer series MR2906966
Check resistor on or near timer with ohmmeter. Wiring diagram
should have correct resistance number. Always unplug unit first.
Mar 23, 2008 | Kenmore 73952 Gas Dryer
Whirlpool LGV4634JQ Gas Dryer Logo
56 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
