Question about Vtech ia5845 Twin Cordless Phone
Can't Connect Displayed
  1. Base unit doesn't connect but satelite unit does Tried all the disconnect but still doesn't work
  • alexsill Apr 19, 2008
    Can't connect displays on both handsets when "phone" button is pressed even though the base is plugged into the phone line and both handsets are fully-charged and plugged in the electricity. I am beginning to suspect I purchased a defective phone. Has anyone experienced a similar problem and found a way to get the phones working? Thanks! -Alex-
  • 65 Answers
CAN’T CONNECT
1.Displays when one handset is on a call and the other handset presses PHONE.
2.Displays when base power is off and PHONE is pressed.You’ll
also hear a sad tone.
3.Displays when an out-of-range dial fails to connect.
RINGER OFF
The handset
THIS IS SECTION OF MANUAL. MAKE SURE THE OTHER HANDSET IS NOT ON. PRESS THE OFF KEY JUST IN CASE.
Posted on Jan 29, 2008
6ya staff
SOURCE:
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
80GB frozen with "Do not disconnect" displayed on screen.
you have to send to apple eng. or els call me i can help u sir 9177110844
Sep 15, 2009 | Apple iPod MA446LL/A MP3 Player
ADDING A BUZZER TO A CHAMBERLAIN BASE STATION
I have never worked with that unit beofre, but I can take a shot. Visit your local car audio dealer, and pick up a LVT (low volatage trip)..Open up the base station, and disconnect the signal wires to the buzzer/speaker. Use those wires to feed the low voltage turn on in the LVT. THe LVT acts just like a relay, but requires much less voltage to trigger. So in theory if you use the LVT it shopuld power up your external speaker properly when the station is triggered, and is a fairly simple install.
Aug 07, 2009 | Chamberlain Wireless Perimeter Alarm
Uniden XS 1210 cordless phone won't connect to base unit
try connecting both phones via the base that is working and see if they recognize each other. Let me know if that works.
Jul 21, 2009 | Uniden Cordless Phone
Handset can not connect to base unit ATT E-2126
AT&T 2.4 cordlessE2126 handset will not reset to base
Apr 01, 2009 | AT&T E2126 2.4 GHz Cordless Phone
D51A PD IS DISPLAYED ON MY ATT E2562 HANDSET. ANY
My E2562 handset 1 would not detect base and displayed D51A PD whenever I tried to manually register it. This fixed it:
1. Remove battery from handset.
2. Unplug base and unplug phone connection(s). Wait 30 seconds.
3. Plug in base.
4. Plug in phone connection(s) to base.
5. Put battery back in handset. Handset 1 should then auto register with base.
Mar 15, 2009 | AT&T 2230 Cordless Phone
Bluetooth disconnects after 5 minutes
I know this sounds silly, but try having your cell phone more than a couple feet away from the base of the DECT phone. Bluetooth can have issues when they are really close together. I have mine setting about 6ft away without problems.
Jan 21, 2009 | GE Lands Phones
Motorola 580 handset not working
My handset does not connect to the base station. It flashes momentarily, but does not find the base. The base station has a humming noise when the phone line is disconnected and the talk button is depressed. Hum is also present when the phone line is reconnected. The problem was resolved by replacing the 9VDC power supply. The hum disappeared and the handset immediately connected to the base.
Oct 31, 2007 | Motorola Mobility MA580 (612572111116)...
VOIP will not connect to Skype
pl go to computer oip icon will be displayed right click presson autoplay it will say interference by other device press ok you are in business all the best ramram
Oct 01, 2007 | Philips VOIP3212 IP Wireless Phone
Vtech ia5845 Twin Cordless Phone Logo
191 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Ekse
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
