Question about Sprint PCS Vision A640 by Samsung(r) Cellular Phone
Forwarding calls how can I forward my cell calls to my home phone or do I even have that option???? Thanks
    Sergeant:
    Champion:
  • 241 Answers
Look inside the menu you will see in connections DIVERT calls - that is usually set to your voicemail #, but you can change it to your home - it is call forwarding
Posted on Jan 25, 2008
6ya staff
SOURCE:
How do I get my home phone number to ring on my cell phone while I am on vacation
It's called "call forwarding" and the procedure varies from company to company. With many, dial * 7 2 on your home phone, then at the second dial tone dial your cell phone number. Answer your cell phone when it rings to confirm the call forwarding. To cancel call forwarding when you return from vacation, dial * 7 3 on your home phone.
If the above doesn't work then contact your landline telephone company for their instructions regarding call forwarding.
Aug 01, 2013 | Computers & Internet
Everytime I make a call it displays forwarding activated but I haven't forwarded any of my calls?
select settings on your phone icons, go to call options, and then check if you have call forwarding options and then disable or deactivate call forwarding option. If your phone doesn't display any option for call forwarding you need to consult your telco and ask if they have access in deactivating the call forwarding feature.:p
Nov 30, 2011 | AT&T Cell Phones
Where do i find the call barring password?
Home screen >> Phone application >> Menu >> Options
and there I have :
  • General Options
  • Voice Mail
  • Call Logging
  • Call Barring
  • Call Forwarding
  • Call Waiting
  • Smart Dialing
  • FDN Phone list
  • Hearing Aid Mode
any problem , check this site---http://www.i-softwarelabs.com/products/icallmanager.jsp or
http://i-softwarelabs.com/
thanks for rating good luck
Jan 27, 2011 | RIM BlackBerry Bold Smartphone
Can I divert calls from this phone to another phone? Thanks MArk David
  • Figure out if your particular cell phone model has the option to forward incoming calls. You can do this by visiting your cell phone manufacturer's website or reading the manufacturer's manual that came along with the purchase.
  • Access the "Settings" menu on your cell phone and select "Phone Settings" menu.
  • Select the "Call Forwarding" option in the "Phone Settings menu. This option is usually found at the bottom of the "Phone Settings" menu. Selecting the "Call Forwarding" option gives you access to call-forwarding controls.
  • Switch on the "Call Forwarding" slider. The default position is off.
  • Insert the phone number you wish to forward your calls to in the "Forward To" field. This field most commonly lies below the "Call Forwarding" slider.
  • Exit the setup menu by pressing the home button. You may be asked to confirm/save the changed settings depending on your cell phone model.
  • Make a test phone call to the cell phone number on which you just enabled the call rerouting option. If the call is forwarded and received on the number you entered, it means that the "Call Forwarding" option has been activated.
  • Oct 08, 2010 | Panasonic Cell Phones
    How to block number on moto krzr k1
    it depends on your carrier (and most of them dont)...you register cell with the dont call registry (for telemakets) and you can also tried this trick for those unwanted (done with ex..) if you have all the numbers for this person (such as home, job, cell and etc.) forward the calls...forward their cell to their home) they call you from their cell (they be calling there home)...forward home to job numbers...forward job numbers to their mothers cell/home...you got the picture...it works like a charm the only way they get you is through an unknown number...
    Jun 14, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
    How do I set call forwarding on LG Rumor 2 Black
    have the callers number in you cell...go to option once in phonebook...pick the number you wish diverted.....if you have the persons home,job and moms number....divert cell to mom...mom to job...job to their home and home to cell...cover all area where they may call you from....been there before...(they would have to call you from an unknown number
    Jun 09, 2010 | LG RUMOR Cellular Phone
    Call forward is "not allowed"
    This is a "Class of Service " option, in the system programing under class of service look for the option "call forward to external Destination" this needs to be set to allow.
    Oct 07, 2009 | Mitel Superset 4025 Corded Phone...
    I have the same problem. Any ideas??
    Hi, the setting is controlled by your mobile service provider. You will need to ring them and get them to extend the time which it will ring before going to your voicemail. Another option is to totally disable the voicemail function. On your blackberry, enter the phone screen, then press the blackberry logo button to open the menu then select options. Once in the options, select the call forwarding option. Change all settings to "do not forward". Please rate this solution if it helps. Thanks
    Jun 08, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
    Call Forwarding
    tell her to dial *72 followed by your home phone number then press send on your cell phone. she will hear a stuttering dial tone. the calls are now being forwarded. when you get ypur cell phone, press *73 then send to deactivate the call forwarding.
    wg
    Feb 07, 2008 | LG VX-8700 Cellular Phone
    Sprint PCS Vision A640 by Samsung(r) Cellular Phone Logo
    79 people viewed this question
    Top Sprint Cell Phones Experts
    Vernon Taylor
    john h
    Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
