Question about Motorola Mobility RAZR V3
Razr buttons dont work
Help!! Just got razr as gift---got wet (darn). Replaced keypad and screen still buttons 8,right upper button, and bottom of middle main button dont work?? Any ideas?? THANKS A MILIION!!! mark
  • 1 more comment
  • markster989 Jan 25, 2008
    I took out battery, and took it apart and let it dry for a week, hitting it with hairdryer and later compressed air...
    can it be flex cable??? The layers of cable are "separating" at one corner...
  • markster989 Feb 02, 2008
    replaced keypad and flex ribbon and still the same........is it toast?? someone told me once about "freezing" to jumpstart the hard drive..have any of you heard about this?? thanks for all you have done...you guys are great!!!!
  • 871 Answers
Hi
if your still unable to fix it. be it your last choice and bring it to a service center, it'll e fixed in no time then you can use it.
Posted on Jan 25, 2008
    President:
  • 1,944 Answers
When you took the phone apart. Did you dry out everything and let it breathe for a while?
  • 2 more comments
  • Damen Wong
    Damen Wong Jan 25, 2008
    Just how bad did it get wet?
  • Damen Wong
    I would let it sit out and dry some more.
  • Damen Wong
    You should follow joshy999's advice and replace the cable. You can buy it from here and do it yourself if you want.
  • Damen Wong
    Damen Wong Feb 02, 2008
    Try refalshing your phone's firmware. It might solve the problem.
    Sergeant:
    Champion:
  • 241 Answers
Hi - I just posted to you, you will need to replace your KeyPad flex cable, this is what is damaged - the cost of the part is about $15 or so, and you will be better to have a professional shop do it for you, if you can't find someone let me know, we do those all day long.
  • 1 more comment
  • Josh
    Josh Jan 25, 2008
    Your flexcable is finished, there is some minor corosion or something like that, just bring it to a shop for the simple repair or you can order the part to do yourself
  • Josh
    Josh Jan 25, 2008
    Worst for worst if its not the Keypad flex, it's the button flex that controls all the buttons and connects all to the board
  • Josh
    Josh Jan 26, 2008
    YES, that is what i was saying in the first place - if you want to do the repair yourself, you should buy the Keypad flex and a Button flex, it should solve the trick.
    If you need help of where to buy, let me know
Can't use keypad, only the on/off button works
If your baby got a hold of it, it's likely there is water damage.
Check your battery. Most of the batteries have a sticker. depending on the brand it will be red or smudgy purple or something else if it was wet - no way to tell if i dont know what brand you have.
you can go to your local store and get them to plug in their cell brite and download the numbers to a new phone. If the phone will stay on for a few minutes and is on the home screen, they will be able to do this.
Jul 23, 2009 | Motorola Mobility RAZR V3
My inside screen will not show anything. i can receive and send calls bu dont know who im calling. ive never dropped it, gotten it wet, or damaged it in any way .help
To save contacts on a z310a that has a broken screen, do the following: 1.From standby, (make sure the backlight is lit up) press the center button once 2. Press down once to go to address book 3. Press center button to enter address book 4. Press RIGHT select button (upper right button with line through it) to select options. 5. Press down FIVE (5) times to go to Advanced 6. Press center button to go into Advanced 7. Press down FIVE (5) times to go to Copy To SmartChip 8. Press LEFT select button to enter 9. Press LEFT select button to select "Copy All" 10. Press LEFT select button to confirm. Wait a couple of minutes to make sure all your contacts were transferred.
Jan 08, 2009 | Sony Z310a Cellular Phone
Keypad acting up!
SURGICAL - you need to replaced the mobile flexcable in the phone also have the repair center flash the keypad flexfile back into the phone.
BRENNA - replaced the flexcable
VGETSON - you need to flash a file call keypad flex into the phone to correct the keypad freezing up on you.
Sep 27, 2008 | Motorola Mobility RAZR V3
Frozen screen on Motorola RAZR V3xx
erin - you need to replaced the flexcable and also reflash the phone.
ICS0924 - take the phone to a tech and have the firmware on the phone reflash.
janicek - the firmware need to be reflash so take the phone to a mobile service center to have that done.
guest - replaced the flexcable
Jul 09, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Only the power button works on my razr keypad, help
replaced the flexcable on the phone.
take the phone and have the phone flexcable replaced
Jun 07, 2008 | Motorola Mobility RAZR V3
My keypad won't work
Sounds like the power button is possibly stuck or broken. Razr's aren't very durable. Did it get wet or dropped recently?
Jan 23, 2008 | Motorola Mobility RAZR V3
Keypad
open it ang change if u dont want to change open keypad circuit and clean it with eraser.I AM SERIOUS.
Nov 24, 2007 | Motorola Mobility RAZR V3
Razr v3
maybe you should buy another housing, doesn't seems like fit on your phone!
Apr 06, 2007 | Motorola Mobility RAZR V3
Wet phon
If the screen is working, your phone seems fine, however, you must take this phone to someone who knows how to open the phone and clean the IC. The drink must have gone inside the phone due to which the keypad is not working. For the iPod, it seems the battery isnt charging anymore. Thats why it won't work when not connected to the power. So, get the battery checked.
Feb 28, 2007 | Motorola Mobility RAZR V3
Keypad will not work
This happened to mine after I got the Razor wet - I pulled the battery and the sim card, blew it out with a can of compressed air and it worked for about 8 months. Then it got hot out in my car and started doing the same thing - blowing it out hasnt worked again-
Jan 22, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
43 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
