Question about Altec Lansing Multimedia Computer Speakers
Rattle Problem w/ subwoofer
No idea the model number but my speakers are 7 years old, had them stored in a box in garage for a couple months. Its a 5 speaker surround sound system. Prior to that they were hooked up to my computer. Question is what makes the rattling "paper" sound in the subwoofer and how can I fix it?
  • daalmonette Jan 28, 2008
    There is only one subwoofer. It is made like a speaker (large, square, closed in wood). So I don't know how to get in the inside w/o tearing something up. Plus there is no comparing it since there is only one. But if I can get some hints on how to get inside then it'll take a look, at least, at what u mean. With the components.
  • 3 Answers
See the rear cone, spider and voice coil junction at rest and when cone is manually lifted outward/forward.Then you can easily tell if the spider has separated, as there is little pressure needed to move the cone manually, in and out of the gap. Compare that pressure to your good sub. If there is a notable difference in physical pressure to move either cone, you can rest assured that the spider is not moving or providing resistance to cone manipulation. This is a sure sign of spider/coil joint failure and can easily be sees as you conduct these tests. If that is what you see then repair it or change with new one
Posted on Jan 25, 2008
Need ported box specs for an old SKool 10 inch hollywood sound labs dual voice coil sub
Would need the model number. They made several different models over the years.
Oct 26, 2016 | Dual Car Audio & Video
What kind of cables for Boston Speakers?
You want stranded wire, speaker wire, 14 - 12 gauge
Oct 07, 2009 | Boston Acoustics VR950 Main / Stereo...
Subwoofer rattle
Try filling the inside of the enclosure with insulation [roof insulation will work ] or a small pillow just to see if its the box or the driver rattling if its the driver you might have to secure it to the enclosure with screws or something ,
May 18, 2009 | Atlantic Technology System 170 System
DAV-IS10 Speaker Blown
OK, Subwoofer model number is SA-WSIS10and you need middle speaker mounted on top under following part number..
1-826-658-11 LOUDSPEAKER (12 cm) (MIDDLE)
Available in Part Store.
Mar 23, 2009 | Sony DAV-IS10 System
What size enclosure (sealed)for Alpine 12"1242D(METAL Music)
  • 12" subwoofer with dual 4-ohm voice coils
  • Kevlar reinforced pulp cone with Santoprene™ rubber surround
  • cast aluminum frame with perimeter venting
  • frequency response: 25-500 Hz
  • power handling: 200-500 watts RMS (250 watts per coil)
  • peak power: 1,500 watts
  • sensitivity: 85 dB
  • top-mount depth: 7-5/8"
  • sealed box volume: 0.57-1.0 cu. ft.
  • ported box volume: 0.75-2.0 cu. ft.
  • For rock, i actually have 2 seperate 12's in slot port boxes i built facing forward. Facing forward reduces a little resonance and spl, but keeps alot of that annoying rattle off your tag lol
    Hope this helps :)
    Dec 10, 2008 | Alpine Type-R SWR-1242D Car Subwoofer
    2nd Basslink, still no power-on. Please help
    this is in response to the post below:
    I just bot a basslink t and i wired it up and nothing it just keeps blowing the fues in the unit i got mine on ebay2.gif so i dont know if i can use the warranty dose anybody have an ida for me- britter623
    I got a used basslink about a month ago and had the exact same prob kept blowing fuses...found out that the voice coil had blown on the infinity...so I had a brand new dvc polk 10 sittin in the closet, I swapped them out, put the polk in the place of the infinity sub, however, the magnet is much larger, hence, dual voice coil, it would rattle sooo much from the passive radiator against the magnet, also could not turn the gain up at all due to the rattle. I got the bright idea to build a "custom fiberglas enclosure for the polk and incorporate the infinity's parts(amp/control) I finished the box finally last night and hooked it up this morning, no power, no lights, no nothing! s@#%, F&@%! ANyone had a prob w/the amp not having the lights turn on, no power??? Hope that helps about your fuse blowing issue.
    Jul 15, 2008 | Infinity BASSLINK Car Subwoofer
    When you put the new foam, maybe the cone went off center. Get a new kit, and re-do the job with more care. Check to make sure that the spider is okay, and that the speaker coil is not warped or anything like that.
    There are speaker companies the professionaly rebuild speakers. They are better equiped and have the jiggs and facilities to properly rebuild the speaker from the coil up.
    If you really want your speakers, you should consider giving the complete set out for rebuilding and testing.
    Jerry G.
    Apr 27, 2008 | Audio Players & Recorders
    SUBWOOFER
    Sounds like the power supply in the subwoooooooofer box is dying.
    Replace the whole thing . It's going to be the best way out.
    Oct 25, 2007 | Sony STR-DE345 Receiver
    906 people viewed this question
    Top Altec Lansing Audio Players & Recorders Experts
    Carlos L. Burgos
    Carlos L. Burgos
    Sharps s
    Level 1 Expert
    Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
