Question about Canon PowerShot A530 Digital Camera
No power The camera will not turn on. We have replaced the AA batteries, still no power. This is my son's camera and while out of town he used it quite a bit. He said the camera was warm while using the video option. He quit using it, but was unable to get it to turn on. Is there something else we can try?
  • dcatiya Mar 13, 2009
    I have the same problem! My camera just turned off on me one day while taking pics. Even the lense is extended. I have tried to place new batteries into the camera, but still, nothing happens.. Can someone help me lol?
You may also want to check in case yours has this problem with the battery cover door, which is one cause for the camera to be hot and for short battery life: Safety Notice: PowerShot A530/A540 Overheats
Posted on Feb 27, 2008
    Master:
  • 619 Answers
Hi , some connection overheating disconnect solder need fixya recommended repair shop near just enter your zip code you will find service near you.
Posted on Jan 28, 2008
6ya staff
SOURCE:
It will say low battery or will not turn on
If your camera uses AA batteries, you should note the battery type your camera support, and many cameras only support Lithium AA batteries or Alkaline AA batteries, else there maybe note enough voltage, so the camera will note low power. If your camera uses special camera batteries, and maybe you should replace it for a new one.
Sep 05, 2011 | General Electric A950 Digital Camera
My camera won't stay on. Has a Internal memory full message.
This sounds like that you need to delete some images on your camera memory. You can try hooking the camera up to your computer and downloading the pictures to your computer or removing the memory card and using another memory card. You were not specific on what camera you have so some of my suggestions my not apply to your camera. Regarding the power problem try to replace the batteries if it uses conventional AA with digital AA batteries. Not all AA batteries are made the same because digital cameras require a lot of power If it uses rechargeable battery then try to recharge the battery.
Good Luck
Paul
Jun 30, 2011 | Cameras
I get no power when using fresh AA batteries or charged (Ni-MH batteries). Camera works fine when using AC power adapter.
Please make sure that you're using the LR6 AA sized batteries and also the terminals of the batteries are correctly inserted. Also make sure that the terminals of the battery compartment is clean without any obstacles or dirt. Also, try power reset and check if it helps.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
If the issue persists, try the factory resetting. SETUP MENU-->RESET ALL--> OK
This should resolve the issue.
Thanks for using FixYa.
Jun 06, 2011 | Fuji FinePix 3800 Digital Camera
Where do you put 3 AA batteries in the Disney Pix Click Wizards of Waverly Place digital camera? I can only find location to put 2 AA... and camera will not work.
  • They all seem to go in the same place. - some only seem to use two - this one uses three
The camera is powered by 3 AA batteries. Only use the battery specified by the manufacturer.
  1. Lift the rubber USB interface cover on the bottom of the camera and gently press the lever to the left.
  2. Lift the faceplate off completely and place it to the side of the camera.
  3. Insert the batteries using the battery polarity symbols (+/-) as a guide.
  4. Replace the faceplate by gently placing it back on the camera body.
  5. Replace the rubber USB cable connection cover on the bottom of the camera.
  6. Turn the camera on by pressing the Power button. To turn the camera off, press the Power button again.
  7. Note: If the camera is not used for one minute, it will automatically shut down. To restart the camera, press the Power button.
Apr 12, 2010 | Disney Pix Click Digital Camera
Camera will not turn on,tried new batteries still nothing.camera is kodak c813
1. Remove the batteries from the camera and then clean the battery contacts
2. Remove the memory card
3. Verify the batteries your using
Recomended batteries are
- oxy-alkaline digital camera batteries AA
- Ni-MH rechargeable digital camera batteries AA
- alkaline batteries AA
- lithium batteries AA
4. Make sure to use a brand new batteries or fully charge batteries
5. inserted the battery correctly
6. Place the camera in Auto Mode [it's the green camera on the dial mode.]
7. Turn on the camera
if issue was not resolved contact Kodak support line at 1 800 235 6325 (23KODAK) or visit the website www.kodak.com/go/stepbystep
Nov 17, 2009 | Kodak Easyshare C813 Digital Camera
Camera turns on for 2 seconds or wont turn on at all.
There is no hardware reset on this model. We have many situation on different make digital cameras that uses AA batteries that would not turn on with some other AA batteries due to Amp requirement on the batteries. Which means that some circuit design would work only with rechargable batteries because they have more power due to higher Amp power. So I would try rechargable batteries for the last resort. -James
Apr 12, 2009 | Fuji FinePix A820 Digital Camera
Sir my sonyDSC-40 Camera dot't power on. In power butten pressing time only one time bliking green LED.
Turn off the camera, remove the battery pack. Allow the camera to remain without power for 30 seconds. Reinsert the the battery pack. Turn on the camera.
Please make sure the Battery is fully charged before performing this steps.
Also try changing the Batteries of the Camera. "AA" NiMH, "AA" Alkaline, "AA"
Nickel-Metal Manganese are the compatible Battries for the Camera. Hope it works!
Dec 01, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Dimagez3 Battery Options
Hey bray598,
According to the manufacturer this camera comes with AA alkaline batteries so unless you bought defective batteries the ones you purchased should work fine. I would make sure the batteries are inserted properly, and make sure when you turn it on the battery cover and/or the memory card cover are closed. I hope this helps.
Sincerely,
Allan
Go Ahead. Use Us.
May 16, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
How can I increase battery life?
Transferring images from the camera to the computer requires a lot of battery power. It is recommended to use the AC adapter when transferring pictures to conserve battery life. If not using the AC adapter, make sure your batteries are fully charged and use the highest possible serial speed when connecting the camera to the computer. After transferring your images remember to shut off the camera, otherwise the camera will remain "awake" and will continue to wear down the batteries. The LCD display also uses much battery power and should be used sparingly when trying to conserve power usage. Battery life can be improved by using AA sized lithium batteries, rechargeable AA Ni-Cad batteries, or rechargeable AA Ni-MH batteries instead of AA sized alkaline batteries.
Sep 13, 2005 | Epson PhotoPC 600 Digital Camera
Canon PowerShot A530 Digital Camera Logo
99 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
