Question about Whirlpool Duet GHW9150P Front Load Washer
What does this cod mean?
Can you please tell me what this code means on my Duet Washer please. It flashes a H then it flashes a F not together one at a time. Thanks.
  • Anonymous Jan 25, 2008
    Flashes F 20...can't find my manuel....please help thanks!
  • 770 Answers
Post you email i will email you the PDF of the service manual but the only code i see is a F which equals FAULT the the "code" is H which is a no water detected entering the machine or Pressure switch trip not detected
Posted on Jan 25, 2008
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Can you tell me what F11 means and DL means ?
F11 means the washer thinks there is something wrong with the motor or motor circuit and FdL means the washer thinks there is something wrong with the door lock. These two together mean neither of those things. The problem is called cold solder joints. The solder joints on the CCU circuit board at the spade connectors and relays (5 of them) were not soldered as well as they should be which results in communication errors and different codes like you have. The CCU circuit board will need to come out (plastic case inside, top, back of the machine) and those joints I spoke about will need to be resoldered. If you can handle it great! if not, just remove the CCU in the plastic case and take it along with this response to a good appliance repair shop and they should be able to help you. Good luck.
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does f-24 mean?
inside the machine should be repairmans instructions. this includes explanations for all the error codes.
you will have to remove the front access panel
May 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer displaying a fault code.
check your manual. it will tell you what it means and what to do
Apr 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
F 70 is now flashing. Machine did not start and after repeatedly trying it finally flashed F 70 but my booklet does not tell me what it means.
unplug it and clean out ALL lint the lint sensor will trigger this code,start at lint trap,blower motor, and all the way to the outside vent
Oct 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashing codes
you have a communication problem between your door lock and your ccu board. Are you hearing a click click click before it fails? If so this is a relay inside your ccu board. Replace the board this will solve your problem
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The motor does not engage in at all
The F 11 code is a water fill code. Check the water to make sure both lines are on. If their on then turn off take hoses off the water inlet valves in the back and check the screens. If your screens are clean then you probably have a water inlet valve problem. Are you able to open the door to get your clothes out? If not I can tell you how to get it open.
Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer code
Hi Keitha1
I'm Harvey the Master Plumber
You want to know what code dL means on a whirklpool duet washer.
This is what works for me 99% of the time:
Simply unplug the washer for ten minutes. The onboard computer will reset and work like new.
Please understand that you are not being shortchanged. There are hundreds of codes and with this new computer tech. they mostly require a repareman. To save you money the manufacturer has designed it to reset itself after ten minutes to solve most problems. Try this first, you can always call a local pro later if you want.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I get a F and H code. What does that mean?
Please click on the following link for a detailed explanation of the "FH" error code.
It is rather involved, but it's easier to rule out the simple things first. Check for a siphoning issue, first, followed by the dran pump. In most cases this is a simple problem. If the problem goes beyond that, please let me know and I will give you further advice if needed. I hope this helps you.
Jun 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dront loader washer
you will have to remove kick plate to locate service info located at bottom.this should tell you what code means.
Jun 19, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
94 people viewed this question
Dan Webster
Dan Webster
Sal De
