Question about Estate TGDS740JQ Gas Dryer
Squealing dryer We just replaced the belt and felt seal on the dryer drum. The seal is not folded or creased in any way. The belt seems to be on correctly. When we start the dryer, it turns about 10 times then shuts itself off. If I restart it, it runs continously but will make a high ptiched squeal. This lasts for a few minutes, then it runs without the squeal. The squeal might start up again or it might not. What are we missin? THANKS
  • 8,617 Answers
Sounds like the drum bearings are going bad, or at the very least need lubrication. thats what your problem is.
Posted on Jan 25, 2008
Maytag Performa pdet920ayw has a horrible squeal. The drum is metal to metal with the blower housing
It seems like defective slider , ,check out each carefully and replace if needed such as roller, front seal or rear seal or loose blower fan blade assembly
Feb 26, 2015 | Maytag Dryers
New Drum Install - Rubbing
Ken, Don't know if this will be of any help or not, as I've never seen a dryer drum with the felt seal on the front. All of the machines I've repaired, (and that's a bunch), had the felt seal on the rear of the drum, with the front being supported by the configuration of the front panel where the door is located. Mostly the front of the drums were supported by small strips of teflon, or cork, as slides, but that's it. Never had one with felt in front. Is it possible the drum is in backwards?
May 17, 2014 | LG DLE5977 Electric Dryer
I changed the belt, it sounds like it works now but drum does not roll????
Hi and welcome to FixYa. I am Kelly.
Things to check..
1. Belt and ilder pulley properly positioned?
Use this link to make sure you have it correct:
2. Make sure the drum felt seals are not rolled / folded over. If it is folded / rolled slide the shanke of a screwdriver under the felt and rotate the drum 360 deg until it straightens out. (Front and rear seals.)
3. Make sure the drum rollers are resting in the drum groove and not behind the drum
These manuals will be a big help: (page 25)
(Page 10 below link)$FILE/L-58.pdf
Thanks for choosing FixYa,
Apr 01, 2011 | Whirlpool Dryers
Hi, I have a Beko DRCT70W tumble dryer and the belt keeps breaking. I've replaced it twice in the last month, so I think there must be another fault with the dryer which is causing this. The drum...
hi folks the beko tumble dryers have a felt seal that runs along the front of the drum that wears through causing load on the drum, belt and motor causing the belt to melt and snap, replace the felt you will have no more issues, i got mine off of ebay pretty cheap
Feb 08, 2011 | Dryers
Clothes getting stuck in front of dryer the model wasn't listed below mode is LDE8404ACE
If your clothes are getting stuck in the front of the dryer, it could mean more than one thing.
Your front felt seal is faulty, broken, or out of position.
After years of use, the front felt seal on the dryers break down,come loose, or become faulty. It is also sometimes caused by wear in the drum rollers, and this causes the felt seal to become worn.
You will need to replace the front felt seal and possibly the drum rollers.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum, felt seal and belt. It is a good time to check and replace the felt seal. You could stop there but I recommend that you do the following:
Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they are worn or have flat spots on them replace them.
If the drum rollers don't have flat spots on them and is not worn, then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in.
I will include these two websites for parts and further help:
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 14, 2009 | Maytag PYE2300AY Electric Dryer
My Maytaag dryer has a loud intermittent squeal. It will often work for 10-15 minutes with a quiet squieak or no noise, then the loud squeak starts up. I can turn the dryer off, but the squeal immidately...
I think the drum drive belt is slipping because it occurs more with a large load. Other possibilities are: A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair including belt replacement:
Sep 21, 2009 | Dryers
The dryer squeals (metallic sound) while drying clothes.
check wear pads around front of drum or rear depending on brand. Ge's are particularly prone to scraping sounds, but still one of my preferred brands. IF a ge, did it get any dents around the sides or back? The drum is close to the sides and a dent in right place will do it. Also the rear panel can push the drum forward rubbing in front.
Ge - wear strips in front, plastic bearing in rear center, replace both, inexpensive.
Whirlpool- felt pad and wear strip in front, felt seal in rear with roller support. check rear seal lube rollers
Maytag -roller in front and rear with front and rear felt seals. some designs have front drum support posts with wear pads. ck these.
Frigidaire (include some sold under GE name) rear bearing cup (plastic)-lube, front feltpad with wear plates if plates gone get new pad/wearplate asm.
Maytag and ge nomenclature tags are in rear .
Jul 19, 2009 | Dryers
Whirlpool duet dryer felt seal replacement
The drum may to be removed to install the new felt gasket but the old drum can then be reinstalled. The felt gasket seals the joint where the drum rotates at the inside back panel. It is likely that the inside back panel can be removed when the dryer is placed front-down and the outside back panel is removed. In that case the drum does not have to come out.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When activated the drum makes a low pitched squealing sound. drum seems to wobble
please replace felt around drum thank you for useing fixya RATE ME
May 16, 2009 | Dryers
Kenmore 417.81042000 Electric dryer has loud squealing sound
My dryer of the same model number had the same issue. The teflon/plastic wear points are worn out or have fallen off. They are about $22.00 plus shipping at the site below. Disconnect the power, lift (with force) the top off at the front of the dryer and you will have access to remove and replace.
Felt glide assembly - Upper felt seal with three glides attached. Comes with adhesive.
Part Number: AP2150497 made by FRIGIDAIRE
Oct 30, 2008 | GE DBL333EA Electric Dryer
Estate TGDS740JQ Gas Dryer Logo
237 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
