Hitachi model # 57UWX20B, IT HAS WASHED OUT VIDEO ON ALL CHANNELS WITH VERTICAL PROBLEM, PIP WORKS OK, WILL NOT PLAY VCR TAPES OR GAMES, BUT IT WILL PLAY THEM ON PIP. I CHECKED ALL CONECTIONS AND CAPS, TUNER AND FLYBACK. WHAT COULD THE PROBLEM BE.
    Sergeant:
  • 308 Answers
The problem with the video from the VCR and Game console only being in the PIP window is likely cured by hitting the swap button (or its equivalent) on the remote control. With the Washed out video on all channels, that could be caused by defective capacitors on the CRT drive board, usually 470uF @ 10-16Volts . It could also be caused by dust buildup on the Lenses, and if the set was used in a room where people smoked, the mirror probably has a film of nicotene on it as well. I don't know what you mean by a vertical problem as well. If it involves retrace lines at the top and a shortening at the top and bottom, then I would suspect capacitors in the vertical circuit there as well. If it is a vertical jitter that you are experiencing, I would suspect bad solder connections in that same area.
Posted on Feb 02, 2008
I need help finding the code for my tv. i have a Philmore universal remote pm-rc13. My t.v is a white-westinghouse
Here is the code for your TV 0154 along with the advanced codes.
Advanced Codes for TV_0154TVs ------------------ <TV Group>
0154 244 ACM 165 Fine Tune Up 251 SAP 167 Surround Mute
244 Auto Chroma 244 MTC 231 Speaker In 168 Surround Vol dwn
251 Bilngual 234 PIP Location 233 Speaker Out 164 Surround Vol up
169 Fine Tune Do 228 PIP Select 247 Stereo 129 Component 2 (discrete)
TELEVISION. Uses with:
TUNER/CD/TAPE/PHONO/AMP..CDs................AUX2 088
TELEVISION...............TVs..................TV 154
VCR......................VCRs................VCR 047
VCR......................VCRs................VCR 104
On some models,
100|AM/PM|1-- may be 100/Enter;
Func|Sel may be Digicon;
Level Up|R may be Control Right, Level Up/Minute or Menu Up;
Level Dn|L may be Control Left, Level Dn/Hour or Menu Down;
Review|Qck View may be CH Recall or Quick View;
SetTime Fast may be Stereo Matrix;
SetTime Slow may be Time/Day, Set Up, Clear or Menu;
TV/Video/AV may be TV/AV, Video Mode, Input or A/V;
Wide|TV|Loud may be Stereo Matrix, Surround or Mode;
MTC|OBC|Auto may be ACM or Auto Chroma.
181 0...............0 185 1...............1
120 ENTER...........1-- 120 ENTER...........100
183 2...............2 187 3...............3
180 4...............4 184 5...............5
182 6...............6 186 7...............7
053 8...............8 057 9...............9
185 1...............A 123 A/B.............A/V
120 ENTER...........AM/PM 059 CHANNEL DOWN....AM/PM
183 2...............B 187 3...............C
249 RECALL..........CH Recall 059 CHANNEL DOWN....Channel Down
055 CHANNEL UP......Channel Up 122 PROGRAM.........Clear
250 STOP............Control Left 246 PLAY............Control Right
250 STOP............Cursor Down 059 CHANNEL DOWN....Cursor Left
055 CHANNEL UP......Cursor Right 246 PLAY............Cursor Up
180 4...............D 055 CHANNEL UP......Day
184 5...............E 120 ENTER...........Enter
182 6...............F 121 SHIFT STOP......Fine Tune Dwn
117 SHIFT PLAY......Fine Tune Up 248 PAUSE...........Function
186 7...............G 053 8...............H
250 STOP............Hour 057 9...............I
123 A/B.............Input 181 0...............J
059 CHANNEL DOWN....K 250 STOP............Level Down
246 PLAY............Level Up 122 PROGRAM.........Menu
250 STOP............Menu Down 246 PLAY............Menu Up
246 PLAY............Minute 116 SHIFT PAUSE.....Mode
245 MUTE............Mute 230 SHIFT FFD.......PIP Freeze
235 FAST FORWAARD...PIP On/Off 232 SHIFT REW.......PIP Replace
119 POWER...........Power 052 DISPLAY.........Recall
249 RECALL..........Review 248 PAUSE...........Select
122 PROGRAM.........Set Up 118 REWIND..........SetTime Fast
122 PROGRAM.........SetTime Slow 056 SLEEP...........Sleep
116 SHIFT PAUSE.....Stereo Matrix 118 REWIND..........Stereo Matrix
116 SHIFT PAUSE.....Surround 122 PROGRAM.........Time/Day
056 SLEEP...........Timer 181 0...............Timer Set
056 SLEEP...........Timer Start 116 SHIFT PAUSE.....TV
123 A/B.............TV/AV 123 A/B.............Video Mode
058 VOLUME DOWN.....Volume Down 054 VOLUME UP.......Volume Up
116 SHIFT PAUSE.....Wide
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Sep 29, 2009 | Televison & Video
Signal Problem
When the sound is working and the picture is not it indicates the main power supplies are working but the picture supply is not. The picture supply that powers the projection tubes is a high voltage generator and is very expensive to repair. Not even most tv techs now how to troubleshoot them. So, I cannot recommend you repair it yourself unless you are a trained high voltage tech.
The cost of repair - my wild guess - would be around $300. However, the real cost can only be determined by someone who can make an accurate diagnosis - which will require a hands-on approach the problem.
If you have any other problem please ask me..
Goodluck,
Please don't forget to rate me as fixya..
Feb 09, 2008 | Televison & Video
Washed out video on all channels/power lights blinks no power
hi,
You could probably do the replacement by yourself.
First, go to the owners manual and make sure you have gone through the convergence set up. See page 45 of the manual. When pushing the magic focus button be sure that the set does inaugurate the convergence routine.
Your model has hundreds of parts listed at the www.partstore.com site; I did not search for the STKs but what you can do is find the part number on the case of the convergence ICs and search for it. They cost around $30 to $50 each and there are two of them of the same part number (usually). They must be mounted with great care.
Why would this happen again? Could be a poor design, could be poor mounting of the stks and heat transfer was not adequate, could be out of spec parts, etc.
Expect to take a couple of hours at least to do the replacements.
CAVEAT: We cannot be sure it is defective STKs, so do all the checking and testing you can to pursuade you that they are the real culprit - again.
If you go to http://www.freelists.org/archives/techassist/02-2005/msg00303.html and do a word search on "stk" you will find many interesting comments by others about replacing them and various other convergence comments.
Also, if you go to http://www.schematicsforfree.com/archive/?path=Video%2FProducts and look down the Hitachi list you will see a convergence file that may be helpful in doing the convergence...... It is for an older set, but I believe the procedure is about the same for your model. (This is in the manual setting area, not the Magic Focus automatic procedure).
If anything herein is confusing, please ask more questions. Good Luck with the repair.
Dont forget to rate me as fixya..
Jan 29, 2008 | Televison & Video
Can't record from camcorder to VHS tape on LG Model VCR
ok,uve gone OUT of cam and IN to VCR player?,then press play on cam and record on VCR,u should see whats recording as long as your on your normal video channel
Aug 17, 2009 | LG V181 DVD Player/VCR
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
Recording from camera to VCR
1st setup ur VCD with TV and playback it to view on TV. If picture is coming, thats OK.
2nd plug ur camcorder in VCR input and select VCR input according to plug in and monitor the camcorder picture on TV through VCR. If its ok, now u r ready to record the picture from camcorder to VCR.
Jun 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
Hitachi VCR and Phillips Magnavox TV
Mentor, sounds like it`s wired incorrectly or your using RCA cables (yellow, red, white ends) out of the vcr into the tv, If your using RCA cables the tv`s "input" (on the remote) has to be switched to "video input 1 or 2" etc to see the vcr tape. If you want to see the vcr`s picture on channel 3/4 you have to tell me if your using a cable or sattelite box and then I can tell you how to wire it with the coax cable, let me know, BMW Rider
Feb 07, 2008 | Televison & Video
Picture in picture
i am not familiar with this model, but on most sets you will have a button on the remote to activate pip, when active you should be able to adjust channels on the small display with the remote and cycle through inputs. depending on the tv you will either have 2 inputs for your cable/sat/tv feed, or will have 1 with a dual tuner.
check the connections in the back for a second cable input, or hook up a dvd/vcr/game console/etc to test the pip.
start dvd or tape playing, press pip button to display the mini-screen, then use the tv/vcr or input button to cycle through the modes and see if one pops up. most tvs that have pip will also have a swap button on the remote, it may be labeled with text, or it may just look like one screen overlaying another, press that one to swap between displays.
hope this helps,
trin
Nov 16, 2007 | Samsung PCJ522R 52" Rear Projection...
This model is the W528 VCR, but my manual includes both models
Does it do this with other television sets? If so, then it indicates the problem resides in the VCR. Rolling as you describe suggests either the VCR isn't producing a clean enough vertical sync pulse in the video signal, or the TV circuitry isn't processing the pulse properly. First, try cleaning the heads (not just the video head, but also the audio/control head which is to the right of the rotating video head. If this doesn't fix the problem, an electronic problem is likely. Unless this is a high dollar unit, repair is not recommended, as VCRs of the last 10 years or so are essentially disposable. I've done some looking on the 'net regarding copy protection, and it doesn't look like this is an issue here.
May 02, 2007 | Toshiba W522 VHS VCR
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
