Question about PfaFF Creative 7570
Button holes what attacments are used and how to regulate size? I am trying to do this on fleese.
    New Friend:
  • 10 Answers
Are you using a Pfaff 7570 (or other Pfaff machine with Sensor)? If so, definitely use the sliding buttonhole foot and the sensor guide (slides below the needle plate from the back of the machine. This will keep your buttonholes consistent.
The size is regulated by the Stitch/Pattern Length button and Width button. Select the size you think you'll need (in millimeters).
Test sew your buttonhole on the EXACT same combination of fabric/layers & stabilizer that your garment is. Adjust the length/width of buttonhole if needed. I would recommend a bit wider buttonhole due to the thickness/puffiness of the fleece.
Hope this helps,
Posted on May 04, 2008
I have a Singer Confidence sewing machine trying to get button hole attchment to work, I get beeping, nothing moves,selected the button hole pattern, attached the foot what missing
Did you pull down the sizing lever on the sewing machine? Look at your manual, it will show you the lever that has to be pulled down for buttonholes. If, you have misplaced your manual, you can go on Singer's website and under support you can download your FREE manual. Also go on, put in Singer Confidence sewing machine and you will see some wonderful videos for your machine use. You have a very nice machine, btw..
Sep 08, 2017 | Singer Sewing Machines
How do I make buttonholes on the Bernina 180?
I don't know about your Bernina but mine you have to manually set the button hole size every time you do a new button hole size. Practice on a scrap bit of fabric. I think you push the buttonhole button - sew which I think does an end, push the button again, sew for the distance forward you need and push the button again, and sew the other end and push the button again and it should go back to the beginning. That's off the top of my head, I could be wrong but try it on scrap. I think it might then have set the size until you change stitch types and it should continue to do the same amount of forward and back stitches with each button press to tell it to go forward, end, back, end etc. But practice! My machine has trouble feeding the fabric evenly.
Sep 13, 2014 | Sewing Machines
Cannot reset buttonhole size
Assuming its a singer domestic machine
1.For a 1 step buttonhole, you will need to place and lock the actual button at the buttonhole foot holder(back end of the foot), the size will remain the same each time you sew a button hole.
2.For a 4 step buttonhole, the size is determine by sliding the foot against the line/marker which you can see on the foot itself each time you start to sew the button hole.
Aug 21, 2013 | Sewing Machines
Singer 7444. Can't use button hole. I have
try changing the needle
clean under the needle plate and in the bobbin area
and make sure you use every thread guide
Aug 11, 2013 | Sewing Machines
Just purchased a Singer 4423 machine, need more detailed instructions for buttonholes
when you press the button hole option & then pull the button hole lever
down it will rest against the button hole foot, having the button in the
button hole foot help the machine gage the size the button hole needs
to be, if the machine keeps on sewing & doesn't stop automaticily then
there is something wrong with the button hole option.
Jul 18, 2012 | Singer 4423 Sewing Machine
I have a sewing machine-single needle model 03914, but I don't how to put the needle for delicate fabric and for thick fabric?
Use size 60 for very fine (chiffon), size 70 for light weights like voile and cotton, 80 or 90 for medium weights such as a broadcloth, size 100 for denim and size 110 for something very heavy like a thick curtain or upholstery weight fabric. If you aren't sure what size to use, try pushing a needle into the fabric you are going to sew with your fingers, if it goes in easily and the hole it leaves is not noticeable then it is okay, if it leaves a big hole, then go down a size. If you use a needle that is too small on a fabric, then it is going to go blunt quickly or break.
good info here on needle sizes.
Apr 07, 2011 | Sewing Machines
I an having trouble making button holes. The
Make sure the plug from the buttonhole foot is going all the way in when you insert it. If that doesnt correct it, then the foot may be bad.
May 23, 2010 | Husqvarna Viking 1
My cs6000i won't sew button holes.
You may have to do 2 things press button hole and tell it the size button whole
Jun 21, 2009 | Brother CS6000i Computerized Sewing...
The buttonholer doesn't work right.
Most sewing experts will tell you that the best buttonholes are made with the Singer Buttonhole attachment that has been available since the 1930's. It makes perfect buttonholes every time. Everyone complains about the modern machines not making great buttonholes and not working correctly. Just do a quick search on eBay for one of these vintage attachments and your problem is solved once and for all. Don't waste all the time and money trying to get your machine fixed to only find it does not make good buttonholes...the best solution has always been the buttonhole attachments made by Singer, which the professionals use even with modern machines. They can be found in low or slant shank.
Oct 04, 2008 | Singer 2662
Buttonhole problem
When doing the button hole....after installing the button hole foot and lowering the foot....and adding the button so the automatic button hole size is lower the button hole lever it will touch the back of the button hole foot. this holds the button hole foot in the proper position...if this lever is not all the way down...the machine blips at you...check to see that it is down all the way...I hope this helps you..It truly does all that it advertises and is a great machine...BBill01
P.S. you can adjust width and length of the stich also...see instruction manual. pg 28-30
Jan 06, 2007 | Juki HZL-E80 Computerized Sewing Machine
Sewing Machines Logo
533 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
