Question about Panasonic NV-GS15 Mini DV Digital Camcorder
Fail to get pc recognise my camcorder panasoninvgs 10
USB port not recognising camcorder but working wel for flash driver
    Problem Solver:
  • 7 Answers
plug in the camera and then restart your computer
make sure the camera is in the correct mode (you need it to be in the "PC" position for importing images and in the video recording mode for Webcam function
if you are importing photos then look in "My Computer and if you see "removable disk" or similar your photos are in there somewhere
for Webcam just open MSN messenger and check for a little webcam icon under your avatar
Hope this helps:
Posted on Feb 21, 2008
My PC (or friends) doesn't recognise my Databank usb2.0 64GB flash
Try the stick in another device and report back if you can read and write to the stick on that device.
Plug other USB things into that port to see if the port is good.
Although rare, some USB things allow themselves to be inserted backwards.
Oct 19, 2012 | Watches
MicroSD HC memory card is not recognised in pc as wel as mobile also? how can i solve my pbm?
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if its not working on your mobile it might be faulty
hope this helps you
Apr 15, 2012 | SanDisk 4GB microSD High Capacity Memory...
Hi i have an everio gz-mg 135 and when i connect it to my pc to back up files the message "usb device not recognised. One of the usb devices attached has malfunctioned. Windows does not recognise...
- Make sure you have been installed JVC driver on your PC - If your PC has multi ports USB, just try other ports to make connection - check your firewire, it may be malfunctioned . Try other USB cables
Jan 16, 2011 | JVC Everio GZ-MG130 Camcorder
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
Cannot be recognised on my USB ports
The CD supplied does not have drivers on it. This is a flash player so your PC should recognise it automaticaly.
If this is not happening, please try installing an MTP Porting Kit via the website.
Jul 14, 2009 | Samsung YP-S3JAB Digital Media Player
PC does not recognise Camcorder when connect via USB Cable
my pc does not recognise my camcorder gr-d63 when connected
Dec 28, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Usb ports
Check to see if your flash drive or printer needs drivers in order to work properly. If not, then it could be the drivers for the usb ports or you have faulty usb ports. They're supposed to catch it at the factory, but it happens from time to time on new machines.
Jun 20, 2008 | Toshiba Satellite A135 Notebook
Computer not recognising USB driver
OK, please reinstall the driver. If there is still a problem please advice. Arpi
Mar 18, 2007 | Sony DCR-DVD803E Pal DVD Camcorder
My XP Media Center PC does not recognise the scanner
Your USB ports on your computer may be bad. Do other devices work if you plus them into the same USB port? You can try plugging the scanner into another PC with USB ports. If it works in the other PC, then that points to the original PC's USB ports. You can try buying an add-on USB port or using other USB ports on the PC. If it still does not work, then there may be a problem with the USB port on the scanner, and the scanner itself may need to be serviced.
Oct 16, 2006 | Symbol CS1504 Handheld Barcode Scanner
Panasonic NV-GS15 Mini DV Digital Camcorder Logo
95 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
