Question about Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop
Monitor says no signal
I just put a new power supply in my computer because before it would flash amber light. now that a new one is in, it sounds like computer is working, fans are running. when it first starts up i get a series of beeps about 5 and then they stop, monitor says no signal, i tried unplugging and plugging all plugs
  • zoooster Jan 25, 2008
    i do not have another video card to test
    I put the old power supply back in and it seems to work the same as the new one but still no signal on monitor
If the beeps when u turn the pc on are longer than normal this can mean that something to do with the computers memory is malfunctioning. Check the memory processors, and memory related itmes in the pc to check for loose connections.
Posted on Mar 23, 2008
    Genius:
  • 1,067 Answers
Cheak ram u can get power 400 watts highter atx style with 2 rails but might be bad video card or it defulted to other slot
Posted on Jan 25, 2008
  • nick helpap
    nick helpap Jan 25, 2008
    do u have anther video cad to test or screen
Wont start up
Check physical connections first, check monitor cable if securely plugged in and then check power light of monitor. If power light on monitor is amber or yellow it means that monitor is not getting a signal from cpu/ tower. Try to do a power drain on the computer, remove power cable at the back of the computer and then press and hold the power button for 10 secs, after that plug in power cable again and restart the computer.Check if there is any connection if not then try to use another monitor, a known good one. If you get a video from another monitor it means monitor is already defective.
May 15, 2010 | HP Pavilion a1610n PC Desktop
Blinking amber light.I changed 2 motherboards out and still blinking amber. Changed the CMOS battery, same thing blinking amber. Swapped memory and removed all pci cards, same thing. The motherboard has a...
I'm not clear about the blinking amber light you are referring to. Is it on the computer or the monitor.
I checked Dell's web site for the service manual for this computer model, & found this document:
http://support.dell.com/support/edocs/systems/dim8300/sm/adtshoot.htm#1102195
If the blinking amber light is on the monitor, check the connection between it & the computer itself. Make sure the cable is not damaged & that it does not have any broken pins in the socket.
Dec 16, 2009 | Dell Dimension 8300 PC Desktop
Dell optiplex gx150 power button just flashes - help?
System seems to be in hibernate or standby mode and frozen in that state. Hold dosn power button for 5 seconds or until all signs of life shut down. Wait about 30 second and power up the system.
Jul 25, 2009 | Dell Optiplex GX270
4600C no power, flashing amber light
i have a dimension 4600c. same problem. amber flashing light no sounds. replaced my power source and its now working fine. bought one on ebay for $47
Apr 11, 2009 | Dell XPS 700 PC Desktop
My pc turn on before I press the switch button. Then after it starts. It wasn't able to log-in in windows. Instead, the monitor turn off automatically then the orange or amber light is flashing. I'm glad...
If the front Light is flashing amber, the systems power supply has gone bad. Request you to replace the power supply and the front I/o panel and power switch . The issue would be resolved.
Thanks
mandeep
Jun 15, 2008 | Dell Dimension 4600 PC Desktop
Does not power up
Is the amber light flashing on the monitor?
If so, you should get your power supply checked.
Jun 11, 2008 | Dell Dimension 2400 PC Desktop
Dell SX260...Wont Boot...Power Button Flashing Amber....grrrr!
Try these (un order of degree of difficulty) 1. Try replacing the battery on the system board. it is  typically a CR2032 button-style battery. This helps if the computer has been off for a long time.  2. Make sure all dust has been blown or vacuumed out of the computer. 3. Check to see if the USB pins are bent inside the connector on the back and the front of the computer. Straighten if possible. 4. Remove add-in cards, fans, shrouds, and heatsinks, then check the system board for leaky or mushroomed capacitors. If you would like, this may also be a good time to see if the processor is seated correctly or possibly short-circuited (burned black on the bottom, burnt or missing pins, etc). If it is any of these, you may need a new system board (motherboard) 5. It may be that you need a new power supply. Do your best to make sure that it will fit your computer case and have all the power connectors you need; they are not created equal.
May 05, 2008 | Computers & Internet
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Power goes green then back to standby
It sounds like this one needs component-level troubleshooting, probably in the power supply section.
Dec 29, 2006 | Mag Innovision LT765b 17" Flat Panel LCD...
Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop Logo
114 people viewed this question
Alun Cox
