Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
TV VOLTAGE PROBLEM
WHY IS MY JVC TV PUTTING OUT 59 VOLTS AT THE COMPONENTS ON THE BACK OF MY TV?
  • 2 more comments
  • misikint1958 Feb 27, 2008
    With A DMV,
  • misikint1958 Mar 06, 2008
    AC, Because My DVD Player. And Cable box. Component Wires Had 59 Volts. Thank You. For Your Help!!!!
  • misikint1958 Apr 06, 2008
    Still need to know what parts you are getting this power from, whether it's AC.It AC Suddenlink Or COX.Is The One Did Test On TV.That How I Found Out About It.
    Still need to know what parts you are getting this power from, whether it's AC.Yes.Suddenlink or Cox is the one test TV.
  • 979 Answers
Are you talking about the connections on the back of the set? And how are you measuring this? AC or DC?
Posted on Feb 19, 2008
  • 1 more comment
  • Michael Borelli Feb 27, 2008
    Still need to know what parts you are getting this power from, whether it's AC or DC and what reference you are using for ground. Some AC component stray is actually normal depending on your ground reference used. Current leakage should be less than 35 mA for safety's sake.Is the set properly polarized at the AC plug? Oh yeah, what prompted you to whip out meter probes to the back of this set. Do you have an unusual problem with the TV?...accordianman
  • Michael Borelli Mar 07, 2008
    Okay, I'm going to go out on a limb here, and go ahead and just think that you had a technical problem that warranted you checking for stray/incorrect voltages. You didn't say if someone had been shocked or if you had a unit breakdown, so would you be so kind as to not be so flippant when I try to understand what you need. To try to answer you original problem, the basic reason you might have such a reading from any chassis to earth ground (Can I assume this is how it was measured? Very important here!) would be to say that one or more of these conditions exist. Incorrect polarity of AC mains/plug, improper wiring of any extension cord (wiring reversed,etc) incorrect wiring of mains supply at service drop, or actual defect of any of the components' power supply. Once again, there may be a small or residual voltage that exists on some chassis, but the current rating must be as I stated before. Now, one more thing, and I'll wait for your answer. Does this incorrect/ bothersome reading occur on the frames of any of these components, or do you see it at the terminals' hot leads?....accordianman
  • Michael Borelli Apr 06, 2008
    Does everything work as it should, or not?...accordianman
6ya staff
SOURCE:
My LG 42LH5000 TV is not turning on. A few days ago suddenly switched off and now it doesn't turn on. The red LED is always on. If I unplug it turns off and when I plug again the LED is red again.
I had the same problem with Samsung. A web search located the issue being the capacitor. Take out the back and look for the capacitor near where the power line enter the TV. It was a 100 uF at 4050 volts capacitor. checked the DC voltage to be 381 volts. Got two old capacitor from an old TV - one was 150 uF at 400 volts and one was 220 uf at 400 volts. It turned out that it needs two in parallel (making 370 uf at 400 volts. Took out the under rated 100 uf and replaced it with these two. Checked the voltage to be 390 volts. That did the job. Samsung must have tried to save money by putting in a 100 uf at 450 volts. .
Oct 30, 2017 | LG Televison & Video
Both headlights dim 2002 mercury sable
Get a load test on both. There are 2 components to checking the system voltage and amperage. You can have good voltage but low amperage which will cause issues. 12.75v is low. A battery fully charged should be closer to 13.8v and charging should be around 14.4v
Oct 28, 2016 | 2002 Mercury Sable
I have a 37" JVC LCD TV Model # T370HW02 and the left half of the picture if filled with vertical colored lines for approximately 30 minutes after the set is turned on then the picture clears up and s
The problem with your TV is the screen tabs this is where the electronics bond to the screen a technician may be able to fix it with compression pads otherwise it a new screen
Apr 11, 2017 | JVC Jlc37bc3000 37 Lcd Tv 1080p
Sabre 37in multisystem TV has blinking yellow light and won't turn on. Now in Europe, 220V. Should work fine.
TV's operate on 110 volts, not 220 volts. You need more than just an adaptor to plug in your TV. You need to use a voltage converter to bring the voltage down to 110 volts. But since you already connected your TV up to 220 volts, damage has already occurred to the sensitive electronic components and you need to get it repaired.
Sep 15, 2011 | Sabre LCT371BKA LCD TV
What is needed to converge a 65 inch JVC and an approximate cost?
U have all the tools,also u can do basic soldering work like take out ICS and putting back in ICS chips on a electronic circuit board and take out small electronic components parts and replaces all those small dead components parts resoldering it back on to a circuit board?Yes?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a whole complete convergence kit will also included a DVD tutoring disc belonging to ur DLP tv make and model u are buying will cost u like $70.U do the labors to fix it ur self.Or the tvs shops will cost u like $300-350 for parts and labors.
Aug 28, 2011 | JVC AV-56WP74 56" Rear Projection...
JVC AV-48WP55 won't pwer up.
Start at the wall plug. Did a breaker trip for that outlet? Next use a multimeter to check voltage at the power input to the TV where the power cord connects to the mainboard. Be sure you are checking AC voltage. Next check DC voltage at the power switch on the inbound side of the switch. The power switch is usually after the transformer and AC to DC circuit. If you are getting power to all three places, check the other side of the on/off button. This will eliminate most of the power-related circuit. Also, look for blown capacitors, or burned areas around the power circuit.
Nov 28, 2017 | JVC AV-48WP30 48" Rear Projection...
Rca tv
Sounds like your high voltage section, or your main power supply is shot. DO NOT OPEN THE BACK OF YOUR TV.
The chassis of the TV ( any metal inside the plastic outer shell ) is Electrically HOT ! The High voltage section has upwards of 30,000 ( thirty thousand ) volts running to the picture tube...so DON'T TOUCH ANYTHING.
THe Humming noise is the TV Drawing a lot of current and trying to work. Don't continue to let it try or it will be an even more expensive fix....pull the plug !!
WHAT YOU SAW:
  • "The picture could condense to very thin and then go back to orginal size"......this means that the vertical high voltage section was collapsing (the high voltage for this part of the picture has failed ) and coming back ( normal picture )........this means that some part in the HV section was on its last legs. Now it has no legs.
Best thing you could do is take it to a shop. I have a 32" JVC of the same era and love it. It has given me no problems at all, and even though the price of a new "Tube" TV is extremely low, the picture quality isnt anywhere near as good as your old JVC. Personally, I would at least get an estimate to repair. Good luck....Rob
Mar 17, 2008 | JVC AV-27230 27" TV
JVC AV-32f704
the problem is your high voltage section in the main board of you tv,try to resolder the the circuit and components near the flyback
Sep 01, 2007 | JVC AV27F476 27" TV
No picture but sound is perfect
Sounds like the video output has a problem. Maybe missing the 200 volts from the High voltage transformer. The vertical circuit may have an issue. Either way it's hard to diagnose without looking at it. If you need a technician contact JVC online at: http://maps.jvc.com/cAscList/ Good Luck
Apr 29, 2007 | JVC AV-36FA44 36" TV
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
59 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
